Page 2 of 6 1 2 3 4 5 6
Re: 572 Hemi Saga [Re: RAMM] #2848654
11/19/20 01:13 PM
11/19/20 01:13 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'm just sitting here looking forward to the next installment.
Rich H.
Esse Quam Videri
Re: 572 Hemi Saga [Re: ZIPPY] #2848922
11/20/20 07:12 AM
11/20/20 07:12 AM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Thanks, It's coming along nicely but now I am in need of some .070" thick head gaskets. The flat land of the piston is .028" above deck.
Any one know of some Cometic C5447-070 available? Or I am into machining the pistons a touch. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 572 Hemi Saga [Re: RAMM] #2848961
11/20/20 09:26 AM
11/20/20 09:26 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Call Cometic, they will make them any way you want....
Re: 572 Hemi Saga [Re: RAMM] #2849016
11/20/20 11:04 AM
11/20/20 11:04 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted by Dragula
Sounds like the valve springs are shot.....When ever the power falls off a cliff like that, its always been valve springs.
Normally I would agree but this was different. I put the air hat on to see if CFM fell off at higher RPM's it didn't. I have also never seen valvesprings go away and then come back 500rpm later and hold on a further 1000rpm. J.Rob
Harmonic spring distortion at that particular RPM? (probably not the exact technical term I'm grasping for)
Kevin
Re: 572 Hemi Saga [Re: RAMM] #2849027
11/20/20 11:22 AM
11/20/20 11:22 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Jegs has them
Re: 572 Hemi Saga [Re: cudaman1969] #2849123
11/20/20 02:06 PM
11/20/20 02:06 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Thanks for posting...everyone knows you're a capable builder and your cust is in good hands. So even though there is low-hanging fruit he'll be happy I'd guess.
Re: 572 Hemi Saga [Re: cudaman1969] #2849433
11/21/20 09:13 AM
11/21/20 09:13 AM
RAMM Offline OP
RAMM  Offline OP
Jegs has a ship date of Dec 21 for those. I can't stall that long. J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2849609
11/21/20 02:24 PM
11/21/20 02:24 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Not sure who would have the gaskets. When I ordered cometics for mine it took a month to get them.
Re: 572 Hemi Saga [Re: INTMD8] #2854963
12/03/20 08:16 PM
12/03/20 08:16 PM
RAMM Offline OP
RAMM  Offline OP
Getting very very close to dyno time now. Hope it runs the way it should. J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2854967
12/03/20 08:20 PM
12/03/20 08:20 PM
RAMM Offline OP
RAMM  Offline OP
How do you stop the picture from rotating 90 when you post? I've resized, rotated, saved, renamed etc.... It looks fine until I post it..What gives? J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2855098
12/04/20 07:20 AM
12/04/20 07:20 AM
Dragula Offline
Dragula  Offline
Hope you changed the valve springs...
Re: 572 Hemi Saga [Re: Dragula] #2855104
12/04/20 07:38 AM
12/04/20 07:38 AM
RAMM Offline OP
RAMM  Offline OP
Yes, Love Isky springs--9365PLUS in there now. Hope they are happy in this combo. J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2855124
12/04/20 08:24 AM
12/04/20 08:24 AM
Dragula Offline
Dragula  Offline
More times than I can count, when a Hemi engine won't rev, its been the springs. I think all the street miles on mine is the issue. Looking to put a spray bar in the valve cover for the intake springs. I like the carb setup, what size are those?
Re: 572 Hemi Saga [Re: RAMM] #2855180
12/04/20 10:51 AM
12/04/20 10:51 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Did you happen to flow the heads before and after the filler work?
Re: 572 Hemi Saga [Re: fast68plymouth] #2855324
12/04/20 03:28 PM
12/04/20 03:28 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
All ears
Re: 572 Hemi Saga [Re: fast68plymouth] #2855374
12/04/20 05:33 PM
12/04/20 05:33 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Yes, and I would be interested to know before/after port volume as well.
Re: 572 Hemi Saga [Re: INTMD8] #2855398
12/04/20 06:06 PM
12/04/20 06:06 PM
RAMM Offline OP
RAMM  Offline OP
Ran into dyno issues, engine is healthy. They are 600cfm, flow 720 dry @ 20.4
Didn't flow the heads but they are no anomaly, probably 350-360 cfm. I added almost 10cc of filler.
J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2855636
12/05/20 10:50 AM
12/05/20 10:50 AM
central il.
second 70 Offline
second 70  Offline
central il.
I see you're running the marine intake. Are you planning on trying the stage V also? Interested to see the difference since I'm running a stage V currently and have a new marine sitting in a box.
Also a picture of bottom of stage V.
Thanks Mike
73A9AA6E-2B23-4971-B5EE-B6458E7DF904.jpg1394C74F-A2E6-4224-826E-54C3A0A8A84A.jpg9BD7C6A9-C82C-4C70-A26D-19E8FEC92945.jpg
Re: 572 Hemi Saga [Re: RAMM] #2855673
12/05/20 11:47 AM
12/05/20 11:47 AM
So. Burlington, Vt.
So. Burlington, Vt.
As for the pic orientation...... what seems to work for me, when uploading from my phone.....
Have the pic stored in the phone so it’s oriented correctly when holding the phone vertically.
And hold the phone vertically while you’re browsing the pics to upload them.
Sometimes I’ve had to rotate and save the pics, again........ even when they were correct originally.
Let’s try it with one of yours......
Re: 572 Hemi Saga [Re: second 70] #2855814
12/05/20 07:12 PM
12/05/20 07:12 PM
RAMM Offline OP
RAMM  Offline OP
No plans to try the Stage V intake although that looks like a real nice intake-thanks for the pics. This gentleman just wants a real nice Hemi that looks good, starts/idles and can drive 100 or more kms on pumpgas--I'm sure he won't mind having enough power to boil the hides when the urge strikes. Thanks again, J.Rob
