Re: Need opinion on block filler for cracked water jacket [Re: an8sec70cuda] #2857142
12/08/20 03:52 PM
12/08/20 03:52 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Hard to tell in the pic but if that crack goes to the soft plug hole, the stitch method may not work.
Re: Need opinion on block filler for cracked water jacket [Re: an8sec70cuda] #2857144
12/08/20 03:54 PM
12/08/20 03:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the way I would try first.. stitch first then weld if needed
wave
Re: Need opinion on block filler for cracked water jacket [Re: B1MAXX] #2857202
12/08/20 05:31 PM
12/08/20 05:31 PM
Originally Posted by B1MAXX
[quote=W.I.N. racing]From experience I can tell you that Block filler (HardBlock) will not prevent water from weeping through those cracks.
I agree with the above. I had a 440 block with similar cracks I filled the block with the Moroso block filler past the cracks and it still seeped..
I tried using block filler to stop water jackets leaks on a customers old Mopar cast iron top fuel block that had interior coolant leaks from grinding for clearances around the mains from a different owner.
I ended up having to use a liquid block sealer from Goodson that had to be pour into the block and then sealed up under pressure with a torque plate and water pump block off plates for 20 minutes and then baked in a oven at around 350 F for 20+ minutes after draining the sealer out of both sides one side at a time. It was reusable and it did a good job on fixing those coolant leaks. I did both sides first and then had the block cooked by a local powder coating shop, we pressure checked it at 30 Lbs. for 20 minutes before putting it back together.
The customer put that motor in a car and it is still running today as far as I know up
Re: Need opinion on block filler for cracked water jacket [Re: Scully] #2857277
12/08/20 07:31 PM
12/08/20 07:31 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Had a crack like that from a block left outside in a car,purchase some KW block seal and that stuff seal that crack up right before my eyes ran that block for another 14 years before replacing it.
Re: Need opinion on block filler for cracked water jacket [Re: racerx] #2857378
12/08/20 10:21 PM
12/08/20 10:21 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Disclaimer: I have never personally done this but I know of two individuals that have welded cast iron blocks with this stuff.
Cast Iron Welding Rod
Re: Need opinion on block filler for cracked water jacket [Re: Scully] #2857443
12/09/20 01:31 AM
12/09/20 01:31 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i have a friend that has a 440 block with a crack just like those !
it is actuau a 493 cu stroker .
we sealed it with a external epoxy .
if you pm me i will get the brand .
we cleaned the block paint off with a die grinder with wire brush , then hand scoured it with 60 grit sand paper .
put pressed epoxy on firmly and let it cure .
no more leaks ! 2 years + .
his crack extended to the freeze plug hole .
he races the car 6 - 8 times a year . <street car>
Re: Need opinion on block filler for cracked water jacket [Re: calrobb2000] #2857676
12/09/20 03:38 PM
12/09/20 03:38 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We are just south of Pittsburgh and we weld blocks and other cast parts
Re: Need opinion on block filler for cracked water jacket [Re: 6PakBee] #2857683
12/09/20 03:48 PM
12/09/20 03:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Sounds like silver solder, what’s used in home AC systems. Makes a strong joint
Re: Need opinion on block filler for cracked water jacket [Re: calrobb2000] #2857695
12/09/20 04:18 PM
12/09/20 04:18 PM
oregon
greendart408 Offline
oregon
Originally Posted by calrobb2000
hi
I witnessed my boss fix an exact crack as the op in his buddies freshly built 383 in a rr. Moroso a b epoxy, was still good yrs later when his buddy sold it.
Re: Need opinion on block filler for cracked water jacket [Re: B G Racing] #2857734
12/09/20 05:41 PM
12/09/20 05:41 PM
PA
Scully Offline OP
Scully  Offline OP
PA
If all went well with no other cracks what would a weld up cost for a job like this, just ballpark.
Re: Need opinion on block filler for cracked water jacket [Re: Scully] #2857780
12/09/20 07:43 PM
12/09/20 07:43 PM
A727Tflite Offline
A727Tflite  Offline
wrong post
Re: Need opinion on block filler for cracked water jacket [Re: Scully] #2857853
12/09/20 10:14 PM
12/09/20 10:14 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Try Lock-n-Stitch as you can do it yourself.
I have used this product on my 440 when two cracks popped up in the water jackets. Cost at the time was around $100-$150 all in if I remember correctly. Knock on wood, but mine has been fine since fixing it around 8 yrs ago and I got a stout piece that puts out about 580HP.
Re: Need opinion on block filler for cracked water jacket [Re: jb500] #2858394
12/11/20 09:50 AM
12/11/20 09:50 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
^^^^^^this^^^^^^^^^^^^ done it several times without a single failure. One I did in 2006 is still running, and never leaked a drop. Irontite plugs.
Re: Need opinion on block filler for cracked water jacket [Re: Scully] #2858963
12/12/20 02:19 PM
12/12/20 02:19 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Usually $500+/- it all depends on the block condition and process
