Re: Need opinion on block filler for cracked water jacket
[Re: B1MAXX]
#2857202
12/08/20 05:31 PM
12/08/20 05:31 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
[quote=W.I.N. racing]From experience I can tell you that Block filler (HardBlock) will not prevent water from weeping through those cracks.
I agree with the above. I had a 440 block with similar cracks I filled the block with the Moroso block filler past the cracks and it still seeped.. I tried using block filler to stop water jackets leaks on a customers old Mopar cast iron top fuel block that had interior coolant leaks from grinding for clearances around the mains from a different owner. I ended up having to use a liquid block sealer from Goodson that had to be pour into the block and then sealed up under pressure with a torque plate and water pump block off plates for 20 minutes and then baked in a oven at around 350 F for 20+ minutes after draining the sealer out of both sides one side at a time. It was reusable and it did a good job on fixing those coolant leaks. I did both sides first and then had the block cooked by a local powder coating shop, we pressure checked it at 30 Lbs. for 20 minutes before putting it back together. The customer put that motor in a car and it is still running today as far as I know
[Re: racerx]
#2857378
12/08/20 10:21 PM
12/08/20 10:21 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Disclaimer: I have never personally done this but I know of two individuals that have welded cast iron blocks with this stuff. Cast Iron Welding Rod
[Re: 6PakBee]
#2857683
12/09/20 03:48 PM
12/09/20 03:48 PM
Posts: 8,253 fredericksburg,va
cudaman1969
fredericksburg,va
Disclaimer: I have never personally done this but I know of two individuals that have welded cast iron blocks with this stuff. Cast Iron Welding Rod Sounds like silver solder, what’s used in home AC systems. Makes a strong joint
[Re: calrobb2000]
#2857695
12/09/20 04:18 PM
12/09/20 04:18 PM
Posts: 1,073 oregon
greendart408
oregon
hi
i have a friend that has a 440 block with a crack just like those !
it is actuau a 493 cu stroker .
we sealed it with a external epoxy .
if you pm me i will get the brand .
we cleaned the block paint off with a die grinder with wire brush , then hand scoured it with 60 grit sand paper .
put pressed epoxy on firmly and let it cure .
no more leaks ! 2 years + .
his crack extended to the freeze plug hole .
he races the car 6 - 8 times a year . <street car>
I witnessed my boss fix an exact crack as the op in his buddies freshly built 383 in a rr. Moroso a b epoxy, was still good yrs later when his buddy sold it.
[Re: B G Racing]
#2857734
12/09/20 05:41 PM
12/09/20 05:41 PM
Posts: 201 PA
Scully
PA
We are just south of Pittsburgh and we weld blocks and other cast parts If all went well with no other cracks what would a weld up cost for a job like this, just ballpark.
[Re: Scully]
#2857780
12/09/20 07:43 PM
12/09/20 07:43 PM
Posts: 3,076 Michigan
A727Tflite
wrong post
