68 b body heater fan question #2856580
12/07/20 02:41 PM
12/07/20 02:41 PM
Southeast PA
5wndwcpe Offline OP
5wndwcpe  Offline OP
Southeast PA
I'm putting together a long resto project (68 B body) and am in the middle of installing the dash. As I replaced the harness with an M&H piece, I'm testing all of the electrical bits before bolting the dash in for good. The question I have is with the fan motor, when I turn the ignition switch to run, the fan switch on the heater control gives you a low speed, medium speed and a high speed but no off, regardless of the switch position. Is this normal ? I can't say as I remember. This is a heater only car (no A/C ).
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: 68 b body heater fan question [Re: 5wndwcpe] #2856632
12/07/20 03:46 PM
12/07/20 03:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine turn off, whether 68, 69, or 70.
Maybe I should say they stay off, because I can't recall the last time I used heat/defrost in one of them.
Whether that's accomplished with the switch itself, I can't say.
But that would seem the easiest way.
Re: 68 b body heater fan question [Re: topside] #2856642
12/07/20 03:54 PM
12/07/20 03:54 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i have a 69 b-body.fan shuts off
Re: 68 b body heater fan question [Re: bonefish] #2856655
12/07/20 04:32 PM
12/07/20 04:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
First guess is a defective switch if they don't turn off.
Re: 68 b body heater fan question [Re: 5wndwcpe] #2856657
12/07/20 04:34 PM
12/07/20 04:34 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Does your fan switch have 4 detent's? As I recall the fan switch should have off, low, med,high, 4 detent's.
Re: 68 b body heater fan question [Re: NITROUSN] #2856763
12/07/20 08:22 PM
12/07/20 08:22 PM
Southeast PA
5wndwcpe Offline OP
5wndwcpe  Offline OP
Southeast PA
It turns out the switch was not seating fully in the off position. It felt like it was, but electrically, not so much. Exercised it a bunch of times and all is well.
Thanks for the replies.
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
