Re: Take a ride 5.15 at 132
[Re: bonefish]
#2856418
12/07/20 09:50 AM
12/07/20 09:50 AM
Posts: 34,961 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Looks like it pulls really hard in first 100 feet .. good job !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: dvw]
#2856471
12/07/20 11:34 AM
12/07/20 11:34 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
T I love the sound. Couldnt see the tach through your face shield. .What rpm? Doug This would be the race pack from that pass
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2856500
12/07/20 12:23 PM
12/07/20 12:23 PM
Posts: 4,699 On the parachute mount
n20mstr
You have a dump valve? are you opening it at the shifts? seems to drop a lot of rpm at each shift Thats some high rpm too....close to 10?? Nice pan vac Impressive for sure all motor small block,
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2856520
12/07/20 01:03 PM
12/07/20 01:03 PM
WHITEDART
bean town ....Ca
You have a dump valve? are you opening it at the shifts? seems to drop a lot of rpm at each shift Thats some high rpm too....close to 10?? Nice pan vac Impressive for sure all motor small block, .. yes we run a dump valve in the trans the converter is still a tick tight this is a brand new combination for us.. . I think if we can ramp the timing in quicker there is some ET left on the table.. just looking at the data in first gear alone there is a bunch..
[Re: WHITEDART]
#2856553
12/07/20 01:56 PM
12/07/20 01:56 PM
n20mstr
You have a dump valve? are you opening it at the shifts? seems to drop a lot of rpm at each shift Thats some high rpm too....close to 10?? Nice pan vac Impressive for sure all motor small block, .. yes we run a dump valve in the trans the converter is still a tick tight this is a brand new combination for us.. . I think if we can ramp the timing in quicker there is some ET left on the table.. just looking at the data in first gear alone there is a bunch.. Sure for ET, if you can push that RPM up after the converter grabs , you will pick up 330 et. That and open the dump valve on the 2-3 shift to get the RPM up so it doesnt take so long to recover. But im rambling here, you know what you doing. Looks like a lot of potential
[Re: n20mstr]
#2856575
12/07/20 02:27 PM
12/07/20 02:27 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Mighty impressive. If the air had been 1200-1500 feet it may have run an 0’
