Page 3 of 5 1 2 3 4 5
Re: 572 Hemi Saga [Re: fast68plymouth] #2855820
12/05/20 08:26 PM
12/05/20 08:26 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Originally Posted by fast68plymouth
As for the pic orientation...... what seems to work for me, when uploading from my phone.....
Have the pic stored in the phone so it’s oriented correctly when holding the phone vertically.
And hold the phone vertically while you’re browsing the pics to upload them.
Sometimes I’ve had to rotate and save the pics, again........ even when they were correct originally.
Let’s try it with one of yours......
Thanks Dwayne, I just tried it and we'll see with the two pics I'm gonna post.
Yesterday was a bit of a struggle--I fired the Hemi on the dyno after spending the entire day and then some hooking it up on the dyno. It fired unbelievably quickly and I start running through all of my usual checks --terrified of of oil leaks especially the rear main on the B/RB's and all seems to be going well. My carb guy Guillaume Bordeau shows up as he went through the brand new carbs a month or so ago and we proceed to attempt a pull. I set the rpm too low @ 3500 and when I load it it blows through the absorber and just hangs at 5500 rpm. The torque doesn't look right at 651 ft/lbs so I know something is up with the dyno. Long story short I spent most of today (Sat) replacing the absorber mechanical seal and we get back into business by about 1:30 p.m. First test from 5000 rpm-5500 rpm is a success and we do bunch of other stuff like a plug change (was running the old plugs)--fool around with the widebands, etc....
Long story longer the engine runs really really nice--doesn't leak a drop of anything and I'm impressed with the cam the previous builder used. It makes almost 17" of vac @1100-1150 rpm (solid roller) We ended the day with 710-715 tq (probably 750 at peak) and 708 hp with awesome manners and consistency. I'd like to load it at a lower rpm and capture the actual peak torque but I don't think I will be able. The graph shows the before and after differences nicely. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 572 Hemi Saga [Re: RAMM] #2855957
12/06/20 11:53 AM
12/06/20 11:53 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Couldn’t pull it lower after the seal change?
Re: 572 Hemi Saga [Re: fast68plymouth] #2856036
12/06/20 01:36 PM
12/06/20 01:36 PM
RAMM Offline OP
RAMM  Offline OP
No lower than 4900 rpm. Any ideas Dwayne? I know you have an SF. I have the 871 absorber, it was far better but something is still off. I think it may be the inlet assembly valve not allowing suction. J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2856095
12/06/20 03:20 PM
12/06/20 03:20 PM
So. Burlington, Vt.
So. Burlington, Vt.
Does yours not have the low rpm/high load “boost” line?
Not that you should need it for that combo, but using it would answer the question as to whether or not it was an inlet volume issue.
Servo valve has full range of motion?
Re: 572 Hemi Saga [Re: fast68plymouth] #2856833
12/07/20 10:37 PM
12/07/20 10:37 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I wonder if a pair of shear plates would help with the power any. I wish I could try it on my 572. Glad you are happy with your build. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 572 Hemi Saga [Re: astjp2] #2856941
12/08/20 09:06 AM
12/08/20 09:06 AM
an8sec70cuda Offline
That's a nice improvement. I'm sure the owner will be much happier w/ it now!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 572 Hemi Saga [Re: RAMM] #2857002
12/08/20 11:43 AM
12/08/20 11:43 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Really nice looking engine J, that should really make your customer happy.
One question, what are the cam specs?
I'd sure like to see it pull lower as others mentioned, but glad for any info at all.
Rich H.
Esse Quam Videri
Re: 572 Hemi Saga [Re: ZIPPY] #2857476
12/09/20 06:52 AM
12/09/20 06:52 AM
gregsdart Offline
gregsdart  Offline
Impressive!👍
Re: 572 Hemi Saga [Re: ZIPPY] #2857499
12/09/20 08:54 AM
12/09/20 08:54 AM
RAMM Offline OP
RAMM  Offline OP
So I've been working on it since Monday. Yesterday I machined a coil bracket, lashed the valves, re-torqued the heads, compression test all cylinders while plugs were out--205psi across the board-150 psi first crank,hooked up electric chokes to +12v, removed the electric water pump, installed the serpentine drive kit and installed the MSD 6Al2 programmable. Warmed it up and made a couple of tests--its much stronger with an ignition curve in it--It is now about 20ft/lbs stronger and making 735hp and climbing. Going to disassemble the absorber today and try and figure out what is going on. I spoke with Superflow yesterday and they weren't a whole lot of help although they said my dyno should hold 800-900 ft/lbs @ 3000 rpm--which I have NEVER been able to do. I'm starting to wonder if this absorber had tight enough tolerances to begin with--we bought it new in June 2009. All I have for cam specs is a photo the customer supplied we with. Thanks, J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2857522
12/09/20 09:46 AM
12/09/20 09:46 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
How is your water supply to the absorber?
My builder had to upgrade his pump and supply line to his Stuska to hold the GP Hydroplane engines he's building. The absorber is supposed to be capable. 15 hp pump with a 3" supply line. Also had to add air supply capacity to the tune of 8000 cfm.
Supercharged 468 on Methanol.
Should be loud...
Kevin
Re: 572 Hemi Saga [Re: Twostick] #2857527
12/09/20 10:11 AM
12/09/20 10:11 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I wonder if you won't see even more power once the dyno is figured out. Seems odd it would essentially peak at 5500 and flatline from there.
Nice progress!
Re: 572 Hemi Saga [Re: RAMM] #2857553
12/09/20 11:10 AM
12/09/20 11:10 AM
So. Burlington, Vt.
So. Burlington, Vt.
Jesse....... does your dyno have the boost valve?(I think all 902’s have it)
Does it not make any difference?
I haven’t dynoed a high torque/low rpm combo in a long time, but I don’t think the one here would hold 800ft/lbs@3000 without it being open.
Re: 572 Hemi Saga [Re: RAMM] #2857579
12/09/20 12:11 PM
12/09/20 12:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Thanks!
That helps quite a bit, with the inevitable comparisons that come to mind.
Looking forward to the next installment up
Rich H.
Esse Quam Videri
Re: 572 Hemi Saga [Re: Twostick] #2857602
12/09/20 01:17 PM
12/09/20 01:17 PM
RAMM Offline OP
RAMM  Offline OP
The water supply is way overkill in this case. I have a 20hp 3Ph centrifugal pump that I bypass a lot of water back to the 1550 Gallon reservoir to maintain 45 psi line pressure--I can and have cranked it up to 65psi+. It doesn't work that way with a Superflow anyways. The SF has a suction inlet which uses a little impeller to fill the absorber . You should be able to dunk this thing in a lake and have the absorber work properly. This particular model (871) absorber is rated for 2500 hp/2000lb/ft and so is the load cell. Thanks for the questions though Kevin. J.Rob
Re: 572 Hemi Saga [Re: fast68plymouth] #2857606
12/09/20 01:27 PM
12/09/20 01:27 PM
RAMM Offline OP
RAMM  Offline OP
Oh yes of course I have the boost valve--I think all 901/902's have it because SF's crappy priming system never works all that well. So you fire and engine and have to run and open the boost valve and then close it. I've only ever had it prime a handful of times with out assistance. Oh and yes I've replaced the mechanical seal now 4 times in it's 11 years of use. The boost valve only seems to make a difference on smaller less powerful engines at least that I can notice. Oh and thinking back to EMC testing days--When the contest RPM was 2500-6500 I would always choose a smallblock and this dyno always struggled with 430+ tq @ 2450-2500 rpm.
Would you mind looking through some of your past tests of large cube combos and sharing your data and thoughts especially about the lower RPM end of the scale. I really think this unit should be capable of performing a pull from 3800-6000 rpm without any issue. I could be wrong though. I do remember being very impressed my first time at EMC (2009) with how easily the DTS could pull down our 471 TR to 2300-2400--and remember thinking "Our brandnew 902 couldn't do that I don't think" Thanks for the help guys. Maybe I should change the thread title to SF-902 Dyno Saga--since the engine has been flawless and the dyno has not. LOL J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2857635
12/09/20 02:47 PM
12/09/20 02:47 PM
So. Burlington, Vt.
So. Burlington, Vt.
The dyno here is a 1997 vintage 901.
When it was ordered then, the boost valve was an option.
The dyno shop I worked at in the early 90’s had a 1986 sf-901...... and that one didn’t have the boost valve.
The prime solenoid has a very small pathway through it, and gets clogged somewhat easily.
I don’t think it acted up on this one until it was about 12 years old.
I took it apart, cleaned it out..... and it worked fine for several more years.
I’ve done it once or twice more since then, and it needs to be done again.
Opening the boost valve on this dyno makes a very noticeable difference on how low you can pull the big tq/low rpm combos.
I almost never need to use it for the typical stuff I build.
I’ll see what we have for sheets with high tq/low-ish rpm.
The only thing I have handy is a mild 505 from a few years ago..... which was 592tq@3200....... and I didn’t use the boost for that motor.
Quote
I know we’d be able to do that here with that motor........ and likely without the boost.
As it turns out I do have a run here from a 572 wedge street motor with EZ 295’s on it, and about 10* more cam than your Hemi build........ from 3800-6100.
This run is with an ootb 337 intake and a Mighty Demon 850 carb, and my dyno headers.
Those are 2 - 2 1/8 x 4, so they’re not helping the numbers down near the bottom.
By 3800, the absorber is pretty happy...... so this is no problem at all.
The real high tq/lower rpm stuff would be something for a boat with a roots blower on it....... and I dont have any of those sheets here.
But I’ll see if I can dig something up.
One last thing....... and forgive the dumb question....... but I’m going to ask it anyway.......
You have adjusted the capacity valve...... right?
Re: 572 Hemi Saga [Re: INTMD8] #2857679
12/09/20 03:42 PM
12/09/20 03:42 PM
So. Burlington, Vt.
So. Burlington, Vt.
Well...... not necessarily.
The HP line is just math......... the TQ line is measured........ and the TQ curve is already dropping pretty steadily.
The only way the “dyno” could really be the cause of that is if the load isn’t being transmitted into the load cell correctly(which I suppose is possible).
That’s not to say the curve couldn’t be improved with “tuning” though.
Re: 572 Hemi Saga [Re: fast68plymouth] #2857703
12/09/20 04:28 PM
12/09/20 04:28 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Just seems odd to me it would have a nearly perfect flat HP "curve" over a 600rpm range (and possibly more if pulled higher)
Re: 572 Hemi Saga [Re: fast68plymouth] #2857765
12/09/20 07:07 PM
12/09/20 07:07 PM
RAMM Offline OP
RAMM  Offline OP
Thanks for the help Dwayne that's awesome. That 57I2 of yours looks like Ron's.
Yes I had the capacity valve backed out all the way. Good news though toward all apart started over found the servo was indexed incorrectly and made a couple other changes. Dyno is working awesome now. Thanks for all the help. J.Rob
Re: 572 Hemi Saga [Re: RAMM] #2857777
12/09/20 07:40 PM
12/09/20 07:40 PM
So. Burlington, Vt.
So. Burlington, Vt.
Glad you got it figured out.
Power numbers seem good....... with a vastly improved curve compared to the “before” combo.
The fuel flow dropping off at the top end seems a little odd though.
(Fuel cell running low?)
It was using a way more fuel on the first sheet you posted.
Let’s give this a try......
