Re: 572 Hemi Saga
[Re: RAMM]
#2848654
11/19/20 01:13 PM
11/19/20 01:13 PM
Posts: 18,048 S.E. Michigan
ZIPPY
S.E. Michigan
I'm just sitting here looking forward to the next installment.
Rich H.
Esse Quam Videri
Re: 572 Hemi Saga
[Re: ZIPPY]
#2848922
11/20/20 07:12 AM
11/20/20 07:12 AM
Posts: 1,057 The Great White North
RAMM
Thanks, It's coming along nicely but now I am in need of some .070" thick head gaskets. The flat land of the piston is .028" above deck.
Any one know of some Cometic C5447-070 available? Or I am into machining the pistons a touch. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: 572 Hemi Saga
[Re: RAMM]
#2848961
11/20/20 09:26 AM
11/20/20 09:26 AM
Posts: 12,493 Taxes & Virus's R-US, NY
Dragula
Any one know of some Cometic C5447-070 available? Or I am into machining the pistons a touch. J.Rob Call Cometic, they will make them any way you want....
Re: 572 Hemi Saga
[Re: RAMM]
#2849016
11/20/20 11:04 AM
11/20/20 11:04 AM
Posts: 6,640 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Sounds like the valve springs are shot.....When ever the power falls off a cliff like that, its always been valve springs. Normally I would agree but this was different. I put the air hat on to see if CFM fell off at higher RPM's it didn't. I have also never seen valvesprings go away and then come back 500rpm later and hold on a further 1000rpm. J.Rob Harmonic spring distortion at that particular RPM? (probably not the exact technical term I'm grasping for) Kevin
Re: 572 Hemi Saga
[Re: cudaman1969]
#2849433
11/21/20 09:13 AM
11/21/20 09:13 AM
RAMM
Jegs has a ship date of Dec 21 for those. I can't stall that long. J.Rob
Re: 572 Hemi Saga
[Re: RAMM]
#2849609
11/21/20 02:24 PM
11/21/20 02:24 PM
Posts: 724 Lake Villa Il
INTMD8
Lake Villa Il
Not sure who would have the gaskets. When I ordered cometics for mine it took a month to get them.
Re: 572 Hemi Saga
[Re: INTMD8]
#2854963
12/03/20 08:16 PM
12/03/20 08:16 PM
RAMM
Getting very very close to dyno time now. Hope it runs the way it should. J.Rob
Re: 572 Hemi Saga
[Re: RAMM]
#2854967
12/03/20 08:20 PM
12/03/20 08:20 PM
RAMM
How do you stop the picture from rotating 90 when you post? I've resized, rotated, saved, renamed etc.... It looks fine until I post it..What gives? J.Rob
Re: 572 Hemi Saga
[Re: Dragula]
#2855104
12/04/20 07:38 AM
12/04/20 07:38 AM
RAMM
Yes, Love Isky springs--9365PLUS in there now. Hope they are happy in this combo. J.Rob
Re: 572 Hemi Saga
[Re: RAMM]
#2855124
12/04/20 08:24 AM
12/04/20 08:24 AM
Dragula
More times than I can count, when a Hemi engine won't rev, its been the springs. I think all the street miles on mine is the issue. Looking to put a spray bar in the valve cover for the intake springs. I like the carb setup, what size are those?
Re: 572 Hemi Saga
[Re: RAMM]
#2855180
12/04/20 10:51 AM
12/04/20 10:51 AM
Posts: 14,545 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Did you happen to flow the heads before and after the filler work?
Re: 572 Hemi Saga
[Re: fast68plymouth]
#2855374
12/04/20 05:33 PM
12/04/20 05:33 PM
INTMD8
Lake Villa Il
Did you happen to flow the heads before and after the filler work? Yes, and I would be interested to know before/after port volume as well.
Re: 572 Hemi Saga
[Re: INTMD8]
#2855398
12/04/20 06:06 PM
12/04/20 06:06 PM
RAMM
Ran into dyno issues, engine is healthy. They are 600cfm, flow 720 dry @ 20.4
Didn't flow the heads but they are no anomaly, probably 350-360 cfm. I added almost 10cc of filler. J.Rob
Re: 572 Hemi Saga
[Re: RAMM]
#2855673
12/05/20 11:47 AM
12/05/20 11:47 AM
fast68plymouth
So. Burlington, Vt.
As for the pic orientation...... what seems to work for me, when uploading from my phone.....
Have the pic stored in the phone so it’s oriented correctly when holding the phone vertically. And hold the phone vertically while you’re browsing the pics to upload them.
Sometimes I’ve had to rotate and save the pics, again........ even when they were correct originally.
Let’s try it with one of yours......
Re: 572 Hemi Saga
[Re: second 70]
#2855814
12/05/20 07:12 PM
12/05/20 07:12 PM
RAMM
No plans to try the Stage V intake although that looks like a real nice intake-thanks for the pics. This gentleman just wants a real nice Hemi that looks good, starts/idles and can drive 100 or more kms on pumpgas--I'm sure he won't mind having enough power to boil the hides when the urge strikes. Thanks again, J.Rob
