Page 1 of 3 1 2 3
Options for Overdrive Auto Trans - Ebody #2854285
12/02/20 12:55 PM
12/02/20 12:55 PM
East Aurora (Buffalo) NY
RoadRunner Offline OP
What are the options for getting an additional gear or two in an automatic transmission for e-body? Is surgery of the floor pan or cross member required to fit them in? My last project was a four speed, so never messed with automatic e/b body cars. Looking for possible options on a 70 Challenger.
Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Options for Overdrive Auto Trans - Ebody [Re: RoadRunner] #2854318
12/02/20 01:26 PM
12/02/20 01:26 PM
IMGTX Offline
IMGTX  Offline
I am using an A518 in my 70 Challenger.
I trimmed the case and made a rear mount of my own. A few pic are here in this thread.
https://board.moparts.org/ubbthread...4/re-four-speed-overdrive-automatic.html
I am using the whole Magnum 5.9 EFI, Trans wiring, and ECU from a 95 Ram Truck. If you want to keep your Carb there are controllers that kick the overdrive in based on vacuum and a couple other factors.
Good info here.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/140864/re-727-to-a518-swap.html
If you are gong Big block and want to use an A518 then here is some info.
https://board.moparts.org/ubbthread...8-overdrive-conversion-lots-of-pics.html
Otherwise Passon sells a 4 speed overdrive manual and there is always the gearvenders unit.
Re: Options for Overdrive Auto Trans - Ebody [Re: IMGTX] #2854335
12/02/20 01:42 PM
12/02/20 01:42 PM
BDW Online content
BDW  Online Content
I’ve been running a 518 for 3 yrs and love it.
I built my own controller, not hrd.
PM me if interested in a simple pdf info package I put together.
Everything you need to know here:
http://www.cuda-challenger.com/cc/index.php?topic=84774.0
Re: Options for Overdrive Auto Trans - Ebody [Re: RoadRunner] #2854365
12/02/20 02:20 PM
12/02/20 02:20 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have a 518 behind the Hemi in my 70 Cuda. No floor mods necessary. I didn't use a lock-up. There is a button on the console for activation and an adjustable vacuum switch for automatic OD drop out. I had A&A build a valve body for it.
Very happy with it and would do it again in a minute. My only regret is not doing it sooner.
Master, again and still
Re: Options for Overdrive Auto Trans - Ebody [Re: DaveRS23] #2854385
12/02/20 02:58 PM
12/02/20 02:58 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
To the Fellow who came up with the idea to notch the transmission case to make it fit: my hat is off to you. up Used to be a significant butcher job before the case notch.
44rh for me: more power to the wheels. twocents
Mo' Farts
Moderated by "tbagger".
Re: Options for Overdrive Auto Trans - Ebody [Re: RoadRunner] #2854406
12/02/20 03:29 PM
12/02/20 03:29 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
There is also the Silver Sport 4-speed automatic... I believe its based on the GM 4L60 tranny... I've heard good things from pleased customers... I'm considering it myself.
Re: Options for Overdrive Auto Trans - Ebody [Re: Mopar Mitch] #2854528
12/02/20 08:21 PM
12/02/20 08:21 PM
BDW Online content
BDW  Online Content
Probably the best option if cost is not a factor, looking at $6k or more.
I’m all in at $2.5k you could go cheaper if you don’t want/need the automatic control.
Still by far the best money spent, car is so much more enjoyable to drive.
Only 2500 RPM at 80mph, 3.73 gears
Re: Options for Overdrive Auto Trans - Ebody [Re: BDW] #2854553
12/02/20 08:54 PM
12/02/20 08:54 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Did I miss somewhere clarifying big or small block ?
If you are running a big block, I highly recommend TranzTech in Dubuque Iowa. They installed a 518 in my 65 C body and it is by far the best thing I have ever done for that car as far as drivability. I'm running 496 ci around 500 hp and so far it is doing well ! Just can't say enough about their work.
My install was a little complicated since I first had to convert the column from cable shift to linkage etc. (One year only) they worked with all that and everything works perfectly !
Re: Options for Overdrive Auto Trans - Ebody [Re: RoadRunner] #2854585
12/02/20 10:05 PM
12/02/20 10:05 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Running a 46rh ,, 518 in my 68 Charger, yes I know its not an E body :), 512 lowdeck, it is one of the best things I did to my junker, I had to trim the upper part of the torsion bar x member & build a custom trans x member. I converted my stock shifter to a cable. mine is also a lock up converter 4.1 gear
Re: Options for Overdrive Auto Trans - Ebody [Re: Grizzly] #2854642
12/03/20 01:47 AM
12/03/20 01:47 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I believe that was 1wildRT that came up with the notching.
Re: Options for Overdrive Auto Trans - Ebody [Re: autoxcuda] #2854648
12/03/20 02:56 AM
12/03/20 02:56 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
To me, the down side of the 518 is the crappy 2.45 first gear ratio is a carryover from the 727. The 700R4/4L60E has a 3.06 first gear but second is a tall 1.62. That is a wide spread, sort of reminds me of the 833 OD 4 speed.
Re: Options for Overdrive Auto Trans - Ebody [Re: Kern Dog] #2854653
12/03/20 04:27 AM
12/03/20 04:27 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought the Mopar OD’s had low gear sets in them compared to old 727’s. ??
Re: Options for Overdrive Auto Trans - Ebody [Re: BDW] #2854660
12/03/20 06:48 AM
12/03/20 06:48 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Unless there's been a price increase? I've done the SST GM 4L60 for just under $5K for the Mopar BBlk set up complete kit
Mike
Re: Options for Overdrive Auto Trans - Ebody [Re: RoadRunner] #2854752
12/03/20 11:58 AM
12/03/20 11:58 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
And yet another option is to run a 2004R from Extreme Automatics with a lock up converter. I did have to cut the center loop out of my torsion bar cross member and reinforce it. Their Stage 3 trans will hold up to 1000 hp/850 ft lbs of torque. Uses a Reid bell housing to bolt up to small block, big block and Gen 3 Hemi's.
The gear ratio's are perfect with a 2.76 first and a .66 overdrive. With the lock-up on a 3800 rpm stall converter, its like having a 5th gear. Best functioning transmission I've ever driven. One wire for lock-up.
I painted mine black, and have never been asked if its a GM trans, Shhh.
Re: Options for Overdrive Auto Trans - Ebody [Re: Kern Dog] #2854792
12/03/20 01:27 PM
12/03/20 01:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
2.45,1.45,1.0, .69 even with a 3.54 gear my car pulled great, 1.55 60ft, VERY mild 512. 4100lb pig
Re: Options for Overdrive Auto Trans - Ebody [Re: CSK] #2854803
12/03/20 01:51 PM
12/03/20 01:51 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Agree.
Taking off in first or the first to second gap is not an issue unless you have a real dog like a slant six.
A 545rfe with a 5.7 is a party in first and second. Once that thing hits third, the party is over: 1.5, 1.6ish ratio 2nd gear to 1:1 third is a big jump.
Mo' Farts
Re: Options for Overdrive Auto Trans - Ebody [Re: Mopar Mitch] #2854858
12/03/20 04:17 PM
12/03/20 04:17 PM
None
71rm23 Offline
71rm23  Offline
None
Over $6 grand for it AND GM base tranny????? eek I can afford it but looking at it, is it feasible? If I pull the trigger for OD, I can't see having a GM anything on my car it has to be Ma Mopar. IMHO
Re: Options for Overdrive Auto Trans - Ebody [Re: 71rm23] #2854888
12/03/20 06:28 PM
12/03/20 06:28 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
My street car would Grenade a 4l60
Re: Options for Overdrive Auto Trans - Ebody [Re: CSK] #2854892
12/03/20 06:54 PM
12/03/20 06:54 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
$6k can buy me A LOT of gas..It would take me YEARS to recoup the investment . even at 5 or 6 miles per
Bearing in mind I plan to drive the snot out of the car locally. BUT,,,,,,,and/if I should decide to make a longer distance trip. I'll rent a truck and trailer for a few days
Re: Options for Overdrive Auto Trans - Ebody [Re: gtx6970] #2854906
12/03/20 07:27 PM
12/03/20 07:27 PM
I never thought about costs versus return on fuel. Car will have a decent build 440. I haven't finalized the build options as I tend to always want to go overboard. But stock stroke and 0.30 over pistons. I have a completely done set of 452 iron heads with minor smoothing, no porting. And a set of used Edelbrock heads. Not sure which way to go there. Drivetrain is not numbers matching and I started to think about making it more modern with fuel injection, more gears in the transmission, and other changes. The idea is to do that versus buying a modern muscle car. I'd love a manual, but was leaning towards keeping it an auto.
Thanks for all the suggestions. Certainly some options to think about.
2023 Ford Mach 1
Page 1 of 3 1 2 3
