Re: Passon 5 speed. Whos running one? [Re: mopars4ever] #2856526
12/07/20 01:18 PM
12/07/20 01:18 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
I'll be installing mine this spring. I'll create a post so you can all follow along. I have to do a conversion from auto. So there will be more then just a a833 swap. Wish me luck
Re: Passon 5 speed. Whos running one? [Re: 70VcodeCoronetRT] #2856695
12/07/20 06:19 PM
12/07/20 06:19 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Yea I'm of the opinion they have too many unhappy customers for that kind of money.
I was one Email away from pulling the trigger on an 855. It's too bad, I like Jaime, and wanted to support the cause. With the huge wait times, and apparent problems, parts availability in the future is a big concern.
The new Tremec is more work, but, will probably have better customer service.
https://americanpowertrain.com/the-all-new-tremec-tkx-is-here/
Re: Passon 5 speed. Whos running one? [Re: RealWing] #2856862
12/07/20 11:20 PM
12/07/20 11:20 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Originally Posted by RealWing
I have one in my 6.1 Hemi 1969 Barracuda. I was #4 on the "list".. https://www.hemmings.com/stories/article/modernized-mopar-1969-plymouth-barracuda
Make sure you use a manual transmission GL4 oil and not GL5. Mine is a little notchy going into 3rd when cold but otherwise it works great.
HOWEVER, others have experienced significant problems https://www.forabodiesonly.com/mopar/threads/a855-5-speed.442999/
Thanks for posting that. Just read it all. Guess we were lucky the one we got shifted well. I'd not heard of shifting problems till now.
I will say this. Not an excuse for the transmission problems people are having. There's no excuse for that. But this transmission is way more complicated than an engine block and blocks are in short supply. Really hope they are able to sort it all out.
Re: Passon 5 speed. Whos running one? [Re: MoonshineMattK] #2857393
12/08/20 10:51 PM
12/08/20 10:51 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Another option.
Passon also has a wide ratio 4 speed Hemi (18 spline) gear set. That's the route I'm going. My 470" should be able to overcome the bigger steps between gears smile Was hoping to do it this fall but JUST NO TIME. Ugh.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Passon 5 speed. Whos running one? [Re: 71TA] #2858887
12/12/20 11:28 AM
12/12/20 11:28 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
If you do go with a tremek avoid American powertrain. Many broken promises and deadlines on delivery. And I'm not sure they really know what they're talking about either.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
