Re: 727 low gear sets
[Re: racerx]
#2173386
10/13/16 04:35 AM
10/13/16 04:35 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I'm seriously considering it, for the Barnyard Viper...but like the Coronet above it's very heavy. I understand exactly what Doug is saying but in a heavy street car, where it's preferable to run less gear for street driving, I think it could be a worthwhile advantage.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: racerx]
#2173509
10/13/16 11:46 AM
10/13/16 11:46 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
Speaking from 904 land but its close I guess. I ran a low gear 904 with a nitrous 360 that ran 11.30s. It usually 60'd 1.52-1.53. I changed from the low gear 904 to a standard ratio 727 and it lost .1 in the 60 and .3 overall(slower). So take into consideration some of that ET was lost to the 727 but I bet that .1 in the 60 was the low gear set. I used the same converter buy just had Turbo action make it fit a 727. My car at the time scaled 3525 with driver.
68 Barracuda Formula S 340
[Re: racerx]
#2173715
10/13/16 04:02 PM
10/13/16 04:02 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
My old A/SA stocker had to weigh 3520 with me in it to race legally, I switched it from the stock 2.45 Mopar OEM 1st gear set to the Mopar 2.77 helical low gear set and swapped the rear gears from 4.89 ratio to 4.56. That change picked the 60 fts up and it made the car go into high gear sooner due to the lower 1st and 2nd gear ratios, which was not a bad thing If your not spinning the tires now I would swap them in a heart beat I did the math on the starting line ratio (2.45x4.89=11.98, 2.77x4.56=12.63 plus the torque converter multipication, which remained the same on both gear sets) before doing the swap, that car was a 1963 Plymouth Belevedere two door sedan with the low compression 415 HP motor and steel front end, it had right at 50% weight on the front and back tires with me in it This was in 1988 before radial drag tires had been made and sold, that car was on bias ply 9x30 drag slicks and hooked up very well, 1.48 60 ft times best is what I remember now I'm putting a 4 speed street car together right now and I did the math on using either a standard NP 833 with the stock 2.66 1st gear ratio tranny with a 3.73 rear gear ratio Dana 60 or use a NP 833 O.D. tranny with the 3.09 1st gear ratio and .64 in overdrive, I went for the fuel mileage and less RPM going down the road when crusing Hopefully it won't be a big tire spinner in 1st gear
[Re: racerx]
#2173745
10/13/16 04:36 PM
10/13/16 04:36 PM
Posts: 326 Alberta
Wookie316
Alberta
My 71 weighs 3825, add me and we're at 4100. Yeah I'm a big guy! I have a CRT tranny with a low gear set. My tank runs 10.60's in the 127 range. 60 foot is 1.47-1.48 most of the time. I have 60'd as low as 1.44. The old girl leaves pretty hard for the size. I have a 9.5 converter from Lenny and a 4.30 Dana on a 30x10.5 Hoosier radial slick. I never had a regular gear set with this combo to compare. But this is what my car is doing now.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: racerx]
#2852143
11/27/20 12:31 PM
11/27/20 12:31 PM
Posts: 2,933 A shed in England
Tig
A shed in England
I discussed this with John Cope and One of the guys at Southlands way back when. I really wanted to change them but...... "If you have a marginal / inconsistent 60ft this may make things worse or, make the wheelstand worse" (SLR). I stuck with the standard ratios I do know folk who have changed and picked up in the 60ft and et. I know it worked on our small block and 904...... but if that motor has more than 320hp I'd be surprised.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2852176
11/27/20 01:33 PM
11/27/20 01:33 PM
Posts: 11,650 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
2.77 to 2.45 is a fairly substantial change in SLR. 12-15% depending on rear gear. Try it. Swapping low gear ratios and testing will teach you some things.
Changing SLR 10% and finding the sweet spot made a big difference in my situation. Big. 60s, reaction times, consistency. All of it. Suspension adjustment is key in all of this. SLR is extra important if you lack the adjustability to tune to the gear ratio (4 link, good shocks, etc).
[Re: CMcAllister]
#2852394
11/27/20 11:09 PM
11/27/20 11:09 PM
Posts: 4,073 Mo.
racerx
Mo.
Changing SLR 10% and finding the sweet spot made a big difference in my situation. Big. 60s, reaction times, consistency. All of it. Suspension adjustment is key in all of this. SLR is extra important if you lack the adjustability to tune to the gear ratio (4 link, good shocks, etc). According to Wallace cal's right now with 2.45x4.10=10.05 they say you want to be in the 9,10.11 rang the car is pretty consistent .with 2.77(2.77x4.10=11.35)seems i'll be on the edge of spinning. Some have talk about stroke and converter slippage when discussing low gear sets and i can see that having a effect on the low gear mortification.Trying to figure out how aggressive the 2.77 is over the 2.45.
[Re: racerx]
#2852437
11/28/20 03:46 AM
11/28/20 03:46 AM
Cab_Burge
I did that to my 1963 Plymouth 415 HP M.W. NHRA Stocker in 1988, switch the rear gear ratio from 4;89 to 4:56 and swap the stock 2.45 low gear set and the second gear to the Mopar helical 2.77 low gear set and the 2nd gear ratio that set up came with. I'm sure it help the car run faster and quicker but that swap was not a A/B/A test, the car had set for 4 yrs after me blowing up the motor really bad in 1984 and letting it sit until November of 1987 before fixing it and racing it again in 1988. The new motor, trans and gear sets were all installed at the same time I have one of Pro Trans older SS/AH 727 in my shop, it has all of the tricks used back in the early 1990s, aluminum drums front and rear, straight cut custom ratio gear sets and so on, hopefully I'll be able to use it soon
[Re: racerx]
#2852473
11/28/20 10:13 AM
11/28/20 10:13 AM
Posts: 570 UK
rb446
UK
3800@line RR, 11.35 SLR, 2.77x4.10, 10x29 Hoosiers, c-trac/mono's, dead hooks and picks them up to 1.43 60's to date f/braking, its only a 10.35 1/4ET car, the converter is somewhat tight@3600-4200 max torque is@4400 , seems to work ok, whether we'd go faster with a 2.45 and a looser converter is debatable, I know we'd pick up with more flash as it is now.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: racerx]
#2852519
11/28/20 12:26 PM
11/28/20 12:26 PM
Posts: 570 UK
rb446
UK
Here's the car on a hit with only a handful of runs on it early season....watch from 2hr. 43min. 20secs in and again@9hrs 40 mins> https://www.youtube.com/watch?v=l7eQ4wVUEzs
