Re: 600hp target 408 / 416 stroker off the shelf cam
[Re: fast68plymouth]
#2854307
12/02/20 01:11 PM
12/02/20 01:11 PM
Posts: 11,731 Portage,michigan
B3422W5
Portage,michigan
I don’t think I asked, but I’m pretty sure they’re running it on pump gas.
They were baselining the motor with the std Victor intake and a shop carb, and are swapping to an Edelbrock EFI system. I believe it’s going on a street car. Be curious to see that motor go down the track. Sounds extremely optimistic to me, especially based on other trick flow stuff that has went down the track i know about. Thats pretty much saying it would make 630-640 with compression. That’s healthy W5 type power.
[Re: B3422W5]
#2854311
12/02/20 01:16 PM
12/02/20 01:16 PM
fast68plymouth
So. Burlington, Vt.
C’mon Don.......”extremely optimistic”?
What should it make?
#2854314
12/02/20 01:20 PM
12/02/20 01:20 PM
B3422W5
Portage,michigan
What should it make? My W5 motor made a “ true” 640, based on 135 mph@3350. 13.3 compression, 273@50 roller, “ big” headers, victor, etc, etc. If this motor is around 10 to 1 with that street roller i would suspect 540 -550 true Moroso power. That would be my guess as optimal
[Re: B3422W5]
#2854326
12/02/20 01:31 PM
12/02/20 01:31 PM
fast68plymouth
So. Burlington, Vt.
Well, as someone with 30 years of dyno testing to call upon, I’m confident that if I built a 10.5:1 416 with TF heads, that cam, intake and headers....... it would easily exceed 550hp.
People like to quote the Moroso chart when it fits their narrative...... until you mention “Stock” or “Super Stock”....... then for some reason it doesn’t apply.
If we say the Moroso Chart is more accurate and reliable than a modern dyno, then I guess my friends 400 Pontiac, with its unported heads, .420 lift cam, stock intake and Q-jet makes around 545hp........ even if it makes nowhere near that on the dyno.
Just throw away the dyno...... a $10 Moroso slide rule is all you need for the most accurate power figures.
#2854333
12/02/20 01:38 PM
12/02/20 01:38 PM
B3422W5
Portage,michigan
If we say the Moroso Chart is more accurate and reliable than a modern dyno, then I guess my friends 400 Pontiac, with its unported heads, .420 lift cam, stock intake and Q-jet makes around 545hp........ even if it makes nowhere near that on the dyno. narrative, really? Way back when everybody was posting ET, Weight and Mph and Ryan and several other guys called out the horsepower i remember thinking... man, i have a pooch, 640... ouch... So no, its not a narrative, just a “ standard” lots of guys on here have used for years. And i know you know that. That was kinda uncalled for. From what i have actually seen at the track, well done eddies seem to run eerily the same as Trick flows. And i cant remember( if ever) hearing of a 600+ horsepower pump gas Eddie motor. But.... i dont race dyno’s either
[Re: 11secdart]
#2854342
12/02/20 01:48 PM
12/02/20 01:48 PM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
My 408 has been 10.70 in my 3150 lb. Dart.. 539 hp. 502 tq. on dyno .. 408.. 4 inch stroke R3 Block, 9 1/2 to 1 compression for pump gas, out of box Indy 360-1 heads and intake, 600 lift mechanical cam. 1 7/8 inch headers, AED prepped 750 HP carb. easy low 10s / high 9s with more compression, roller cam and a little head work. I am very impressed with the torque from the 4 inch stroke, I went from a 4.88 gear to a 4.10 and my 60 fts stayed the same. I went 10.40 with a 5.9 Magnum block, 30 over , 590 lift cam, 11 1/2 to 1 compression , W2 heads, Victor W2 intake, 750HP carb, 1 7/8 headers 549 hp. 450 tq. on dyno. I am redoing it now for lower compression/ pump gas expecting between 500-520 hp. Will be a backup motor still expecting high 10s. Both combos ran thru mufflers and with a 904 and 4900 Stall Ultimate prepped 8 inch converter , car is throttle stopped down to run 11.50s. Thread hijack!!!...Nice car...always liked it! Back to the orig post...based on what you have for parts, I'd go get a junkyard Eagle 5.7L and retrofit as you like to reach your goals. Go visit the gen3 Forum and digest some of that IMO.
[Re: B3422W5]
#2854343
12/02/20 01:49 PM
12/02/20 01:49 PM
fast68plymouth
So. Burlington, Vt.
From a recent thread: The car picked up 5 tenths and 11 mph from the converter swap. At the performance level of the car in that post, that 11mph represents about 150hp on the Moroso Chart. I wonder how much extra hp the motor made with the new converter. You think it seems reasonable that a 416 with TF heads, roller cam, nice headers, good intake, nice carb would make the same power(550-ish)as a 412” Pontiac with stock heads, intake, carb, and a .420” cam? Interestingly....... you don’t seem to have any problem with the vailidity of these dyno numbers....... yet I don’t think that motor has been on the track yet: You should read about the motor my engine builder won a competition with. Stock stroke, 11.66 compression 360. Made 773. Then 737 with mufflers on a 90 degree day at the competition to win it. Yep, heads matter.
#2854361
12/02/20 02:13 PM
12/02/20 02:13 PM
B3422W5
Portage,michigan
From a recent thread: The car picked up 5 tenths and 11 mph from the converter swap. At the performance level of the car in that post, that 11mph represents about 150hp on the Moroso Chart. I wonder how much extra hp the motor made with the new converter. You think it seems reasonable that a 416 with TF heads, roller cam, nice headers, good intake, nice carb would make the same power(550-ish)as a 412” Pontiac with stock heads, intake, carb, and a .420” cam? Interestingly....... you don’t seem to have any problem with the vailidity of these dyno numbers....... yet I don’t think that motor has been on the track yet: You should read about the motor my engine builder won a competition with. Stock stroke, 11.66 compression 360. Made 773. Then 737 with mufflers on a 90 degree day at the competition to win it. Yep, heads matter. He is actually putting it in his Coronet wagon over the winter to race it next year. That motor was on a dyno he uses, A dyno at BES, and the dyno at the competition. Who knows what it will run, not a combination anybody has used before. That motor was built specifically to fit a competition parameter, not to make the most power possible out of. Otherwise he would have used more cam and compression, and cubes. But stroker smallblocks with factory replacement heads, tons around to compare to. Yiu should come to a Mopar race event some times, you will see tons of them, and see what they actually run
[Re: B3422W5]
#2854367
12/02/20 02:23 PM
12/02/20 02:23 PM
fast68plymouth
So. Burlington, Vt.
I’ve dynoed piles of motors that went into cars that go to the track.
I know first hand that some people have cars that just don’t work very well, for whatever reason. That doesn’t mean the dyno is lying. The motors that I’ve tested that run right on the number, and the ones that have beat the Moroso Chart........ and the ones that don’t even come close........ are all being tested on the same dyno.
There are waaaay less variables to contend with in the dyno room, vs the endless myriad of variables between different cars, tracks, weather...... not to mention the owners/drivers skill in maintaining, tuning, and driving the car...... then throw into the mix whether or not the overall “combo” is well matched.
#2854376
12/02/20 02:34 PM
12/02/20 02:34 PM
B3422W5
Portage,michigan
There are waaaay less variables to contend with in the dyno room, vs the endless myriad of variables between different cars, tracks, weather...... not to mention the owners/drivers skill in maintaining, tuning, and driving the car...... then throw into the mix whether or not the overall “combo” is well matched. Agree with you. And i have seen “ 800 horse” motors that run 10.50’s in cars with nothing wrong with them Other than the dyno numbers they were given My point is a 600+ horse pump gas stroker with replacement heads in a typical bracket(3000-3100) pound A body is a 9 sec car. I just don't ever see such stuff, or at least ultra rarely. The reason i brought up the dyno competition motor was because Andy posted about a 700 horse Chevy motor, if you go back and reread the thread. Just to show Mopar stuff is capable as well
[Re: B3422W5]
#2854452
12/02/20 05:41 PM
12/02/20 05:41 PM
Posts: 31,100 Oregon
AndyF
They were baselining the motor with the std Victor intake and a shop carb, and are swapping to an Edelbrock EFI system. I believe it’s going on a street car. Be curious to see that motor go down the track. Sounds extremely optimistic to me, especially based on other trick flow stuff that has went down the track i know about. Thats pretty much saying it would make 630-640 with compression. That’s healthy W5 type power. Track times don't mean much, especially for street cars or novice bracket racers. Lots of street cars have 10 second power but 12 second tires. I don't have any trouble accepting that TF heads on a 400 inch SB Mopar can make 600 hp. Just because nobody at your track runs 9's with a TF headed SB doesn't mean it isn't possible. The 700 hp LS7 with a small cam is a different animal. That number isn't what I'd expect from that cam.
[Re: AndyF]
#2854499
12/02/20 06:57 PM
12/02/20 06:57 PM
B3422W5
Portage,michigan
They were baselining the motor with the std Victor intake and a shop carb, and are swapping to an Edelbrock EFI system. I believe it’s going on a street car. Be curious to see that motor go down the track. Sounds extremely optimistic to me, especially based on other trick flow stuff that has went down the track i know about. Thats pretty much saying it would make 630-640 with compression. That’s healthy W5 type power. Track times don't mean much, especially for street cars or novice bracket racers. Lots of street cars have 10 second power but 12 second tires. I don't have any trouble accepting that TF heads on a 400 inch SB Mopar can make 600 hp. Just because nobody at your track runs 9's with a TF headed SB doesn't mean it isn't possible. The 700 hp LS7 with a small cam is a different animal. That number isn't what I'd expect from that cam. I didnt say it wasn't possible. But its very unlikely with a very mild street roller and low compression. Not talking street cars or “ novice” bracket cars. To clarify, a dyno can say anything. Lets just say i wouldn't believe such numbers until i saw some MPH numbers at the track, and leave it at that. Such numbers i have yet to see at the track.
[Re: rb446]
#2854527
12/02/20 08:21 PM
12/02/20 08:21 PM
B3422W5
Portage,michigan
Saw that. So if you kept the compression the same, the cam and heads the same, how much extra horsepower would it make with more stroke. As an example, i am making a similar change myself right now Had a 360 with basically stock eddie heads. Ran fine for what it was 10 to 1 compression. 118 and change at 3300 My engine guy told me my 418, with having him port the heads, raise compression to 12.5 to 1, otherwise no changes other than go to single plane over air gap( excellerator) i could see maybe 80 horse gain. Same cam, etc, etc. but tons more torque That is making the heads much better, and 2.5 points in compression( huge difference, guessing nearly 1/2 of that gain) to gain 80 horse. What would i gain with heads the same and compression the same?
[Re: Brian Hafliger]
#2854599
12/02/20 10:55 PM
12/02/20 10:55 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We also use a 1025 4150 carb instead of the dominator, which drives much better for street/strip car.
Brian Hafliger
#2854627
12/03/20 12:14 AM
12/03/20 12:14 AM
B3422W5
Portage,michigan
We also use a 1025 4150 carb instead of the dominator, which drives much better for street/strip car. Nice! What compression and what camshaft? Has it been in a car?
[Re: one bad fish]
#2854779
12/03/20 12:53 PM
12/03/20 12:53 PM
Posts: 1,178 Indy
FlyFish
Indy
Fly fish...... 904>727. Simple mopar math ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) . Great sounding combo until we got to that dump truck trans lol Yeah, I realized that I slowed my car down about 20 years ago...problem is, I would have to change trans, converter, and drive shaft to convert back to a 904....all that to save a tenth or 2 in the 1/4....not going to happen anytime soon. I'll be happy "only" running 10 flat with my dump truck trans, lol.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: B3422W5]
#2854829
12/03/20 03:18 PM
12/03/20 03:18 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We also use a 1025 4150 carb instead of the dominator, which drives much better for street/strip car. Nice! What compression and what camshaft? Has it been in a car? When we sold it, yes it was going into a car but never heard from the owner after the sale! Was bummed about that.
Brian Hafliger
