Re: Delalum control arm bushings 63 B-body
[Re: Stanton]
#2851966
11/26/20 07:30 PM
11/26/20 07:30 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
You're gonna press aluminum bushings into steel UCAs ... the aluminum will corrode a start to disintegrate in no time. What are you trying to gain from this? I think that kind of stuff only happens in Wisconsin and Canada. Or if you are a vampire and are going to live for 1000 years. Are you a vampire?
[Re: Stanton]
#2852042
11/27/20 12:34 AM
11/27/20 12:34 AM
Posts: 592 Sullivan, Ohio
Max Wedge Savoy
Sullivan, Ohio
You're gonna press aluminum bushings into steel UCAs ... the aluminum will corrode a start to disintegrate in no time. What are you trying to gain from this? This is a purpose built car, it will see no adverse weather conditions. I have successfully used these in a GM application with outstanding results.
[Re: Max Wedge Savoy]
#2852059
11/27/20 06:21 AM
11/27/20 06:21 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
https://bergmanautocraft.com/product/bac-delrin-lower-control-arm-bushings/These are lowers , not sure who does uppers . I would like to hear feedback on these and uppers if available . For daily driver/strip use . I imagine they must last better than stock Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: fbs63]
#2854194
12/02/20 10:04 AM
12/02/20 10:04 AM
Max Wedge Savoy
Sullivan, Ohio
If they don't have to be stock appearing tubular uppers with heim joints are stronger and more adjustable. It has to be a stock control arm.
