Page 1 of 4 1 2 3 4
OT. Electrician question #2849985
11/22/20 03:37 PM
11/22/20 03:37 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
I have a question for the electricians here please. I recently purchased an abandoned gas station / car wash. It has been empty for at least 10 years. I am going to convert it to a different use, and I want to strip out all of the fixtures in wiring related to the gas pumping operation and convenience store coolers and equipment. But I want to keep the lighting and outlets and furnace, well pump, and the essential wiring in place. There is four or five different panels, and wires everywhere. The electrical power lines from the pole to the building have been cut off, so there is absolutely no power to the building at this point.
So what kind of apparatus can I use to most easily identify the circuit breakers and wires that lead to the essential fixtures, and which ones lead to the stuff that I want to rip out?
My plan is to get the demo done without the use of the electrician, then get a licensed electrician in to make any needed reconnections before getting the power hooked up again. I can run a generator or something to have some temporary lighting in there, but I'm looking for something, possibly battery-powered, that can allow me to trace circuits. Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: OT. Electrician question [Re: Hemi_Joel] #2849990
11/22/20 03:51 PM
11/22/20 03:51 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Re: OT. Electrician question [Re: DrCharles] #2849991
11/22/20 03:53 PM
11/22/20 03:53 PM
New State
kidmopar Offline
kidmopar  Offline
New State
" I recently purchased an abandoned gas station" ............
I HOPE ? shruggy work There are NO in-ground fuel tanks ? eek panic
Re: OT. Electrician question [Re: kidmopar] #2850011
11/22/20 04:38 PM
11/22/20 04:38 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Damn HJ ... kidMop ain’t KIDDING !!
You are now IN DA LOOP if there are tanks that have been or ARE leaking eek
Re: OT. Electrician question [Re: kidmopar] #2850019
11/22/20 04:50 PM
11/22/20 04:50 PM
Minnesota
Minnesota
Most of the wires are in EMT. I would need a tool that works well in that instance.
Doc, do you want to buy some large used storage tanks? Just pay the removal fee, and the shipping and they're yours!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: OT. Electrician question [Re: Hemi_Joel] #2850023
11/22/20 04:55 PM
11/22/20 04:55 PM
Minnesota
Minnesota
I bought the property from the county. It was a tax foreclosure. They have been sitting on it for at least 10 years while they have pollution tested it in every way possible. They had every phase of environmental study done, drilled a bunch of test wells and monitored them, had the tanks emptied and cleaned, and the MPCA recommend no environmental remediation. I have all the paperwork from that. so I have a choice of either filling the tanks in with sand, or getting them yanked out of there. All of that is factored into the purchase price. The only reason I bought it is because it's two and a half acres adjacent to my roofing company parcel. It's hard not to buy adjoining land on a major state highway when it becomes available cheap.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: OT. Electrician question [Re: Hemi_Joel] #2850042
11/22/20 05:13 PM
11/22/20 05:13 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I would try one of the tracers. You need one with pretty decent power - I would think. I have not used one. Because of the conduit, you would need to get to the fixtures/devices to tell or get to actual wires. Hook the tracer to the incoming lines. If 3 phase, you probably need to short the 3 phases together and hook up the tracer phase to ground.
If not obvious, you shut all the breakers off and turn them on one by one till the tracer beeps. Alternatively, you can short out each fixture/device and measure resistance on the incoming lines, but I would try a tracer.
It is very doable but will take some time.
Good luck!
Re: OT. Electrician question [Re: Hemi_Joel] #2850045
11/22/20 05:19 PM
11/22/20 05:19 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
GOOD you covered yur @$$ !
HJ ... you got me thimking... I could sure save somjue big $$$ buying resin and gel coat that way !
Me thimks SAND is the best option !
Re: OT. Electrician question [Re: dOc !] #2850062
11/22/20 06:12 PM
11/22/20 06:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Is there anything on file at the City/County level from electrical permit(s) ?
Or is that electrician still in business ?
I assume nobody labeled anything in the boxes, or it's illegible at this point ?
Sounds like it could be a really cool toy shop...
Re: OT. Electrician question [Re: topside] #2850072
11/22/20 06:30 PM
11/22/20 06:30 PM
Minnesota
Minnesota
It's in a small town that farms out the permits and inspections to a private company. But maybe? I think electric permits come from the state, but I don't think they require plans/schematics to be submitted.
But I subsribe to the wisdom of "Never ask the government for anything. You just might get it"
Re: OT. Electrician question [Re: Hemi_Joel] #2850090
11/22/20 06:52 PM
11/22/20 06:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Depending on the age, code requires many things. labeled breaker boxes being one of them. I'll bet that your property is old enough not to have that though. It will once you finish what you are fixing to do.
Lots of changes to the electrical code over the years and many jurisdictions have adopted the National Electrical Code, which lays out all these requirements. Prior to that is was whatever the locals said it needed to be.
Re: OT. Electrician question [Re: Sniper] #2850122
11/22/20 08:12 PM
11/22/20 08:12 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Hook up a car battery to the bus bar and start tracing
Re: OT. Electrician question [Re: CYACOP] #2850130
11/22/20 08:29 PM
11/22/20 08:29 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That is genius
Re: OT. Electrician question [Re: Hemi_Joel] #2850210
11/23/20 12:48 AM
11/23/20 12:48 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What is the reason for wanting to "rip" any wiring etc out, other then remove unneeded fixtures? I'm having a hard time thinking of good reasons, based on what you have shared so far.
Re: OT. Electrician question [Re: jcc] #2850228
11/23/20 01:31 AM
11/23/20 01:31 AM
5thAve Offline
5thAve  Offline
THe down side of having the power cut like that is they'll usually need to do an inspection and bring things up to code before they will connection again.
If you trust the wiring that's there you could hook up a portable generator to the panels and turn the breakers on one at a time to see what they do. That will also give you some power for lights and to get some things done. Definately not safe to do tho if tresspassers have been in there or if things have been torn out or the building has any damage.
Since no-one has said it yet lets see some pictures of this place.
Re: OT. Electrician question [Re: Sniper] #2850239
11/23/20 02:11 AM
11/23/20 02:11 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
The buss bar would energize every circuit. I'd do similar, but remove every neutral from the lug and connect the battery to each neutral and find what is energized. Doing so one could reattach every necessary neutral, and tap off/cut off each not needed. Lable each circuit as you i.d. it as well.
The nice thing about doing it that way is the battery could be attached to an outlet and test back at the box, larger circuits could be i.d.'d that way as well.
Just need to make sure all the neutrals are removed from the lugs, in the main, and any subs.
Re: OT. Electrician question [Re: srt] #2850251
11/23/20 03:08 AM
11/23/20 03:08 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
you could use the new " future " electrical contractor to do a sweep for you. he would be the one fixing it all down the road anyhow ... it would not take much to check it all and it could save you more money if they find issues that you miss..... codes are not the same everywhere so you may or may not get by...someone up to date will know this and the inspectors !!
Re: OT. Electrician question [Re: srt] #2850259
11/23/20 03:38 AM
11/23/20 03:38 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Doesn't account for any two or more phase circuits as they may not have a neutral.
Re: OT. Electrician question [Re: jcc] #2850265
11/23/20 04:51 AM
11/23/20 04:51 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Tracing out wiring can be done with a simple volt/ohm meter and no power. Quite easy.
The conduits going to the fuel pumps should be in ridged GRC and have explosion proof sealing fittings so those ones should be easy to identify.
https://www.gordonelectricsupply.co...h09gSDftjU5TZbt8dDANvgIMiexoCePwQAvD_BwE
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: OT. Electrician question [Re: jcc] #2850275
11/23/20 07:39 AM
11/23/20 07:39 AM
O
oldjonny Online content
Don't argue with me.
oldjonny  Online Content
O
Huh? Say What? There is Single Phase and Three Phase...no "two or more phase".
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Page 1 of 4 1 2 3 4
