Re: 6 Pack tunnel ram
[Re: polyspheric]
#2852530
11/28/20 12:55 PM
11/28/20 12:55 PM
Posts: 4,764 Moved to N.E. Tennessee
GomangoCuda
what it would cost to cast a few of those tops
Ten times what you would pay for it At least that since I would have fabricated one myself a long time ago if I really wanted one. I was just curious.
[Re: cudaman1969]
#2852573
11/28/20 02:34 PM
11/28/20 02:34 PM
Posts: 3,112 Michigan
A727Tflite
Or made out of plastic-carbon fiber Hardwood and a router. Been done several times back in the 70’s. And the calibration process on the Weiand was done in Michigan, and that was a scary process that an engineer came up with.
[Re: A727Tflite]
#2852617
11/28/20 04:00 PM
11/28/20 04:00 PM
Posts: 8,368 fredericksburg,va
cudaman1969
fredericksburg,va
Or made out of plastic-carbon fiber Hardwood and a router. Been done several times back in the 70’s. And the calibration process on the Weiand was done in Michigan, and that was a scary process that an engineer came up with. Might look into that but no domestic types, maybe gum but I’m thinking imported with a very dense grain (heavy & $$). I’ll check my supplier next time I need some materials. Also the Carters carbs line up nicely sitting on the front and back bolts of the two barrels (outermost bolts)
[Re: cudaman1969]
#2852635
11/28/20 04:43 PM
11/28/20 04:43 PM
GomangoCuda
I seem to recall 7 ply baltic birch plywood. 20 years ago when I was thinking about making a top for 2 sideways Holley's I was going to make a spacer out of wood or nylon with an aluminum top. Then I realized I would probably need thermocouples and O2s in all 8 cylinders to figure out the extreme stagger that manifold needs. That is why a new, unused manifold and both tops are still in a rubbermaid bin.
