Re: Anyone got any extra X-mass money to lend me?
[Re: Dragula]
#2849207
11/20/20 07:25 PM
11/20/20 07:25 PM
Posts: 20,205 Park Forest, IL
slantzilla
Park Forest, IL
I'm about an hour and a half away from it if you need it checked out.
[Re: racerx]
#2849275
11/20/20 09:45 PM
11/20/20 09:45 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
It i had the money to give you it would be for a stroker small block with Indy heads( or better) so you wouldn't have to keep beating on 600 inch hemi’s to keep up with what you could get done with my suggestion.....lol
[Re: theraif]
#2849784
11/21/20 10:58 PM
11/21/20 10:58 PM
Superfreak
Superfreak
[Re: ]
#2849793
11/21/20 11:26 PM
11/21/20 11:26 PM
slantzilla
Park Forest, IL
With that torque curve you probably don't need much stall.
[Re: theraif]
#2849796
11/21/20 11:51 PM
11/21/20 11:51 PM
Posts: 4,700 Wichita
GY3
Wichita
dont why this seems odd coan 3500 stall converter Not that it's close to being comparable but we run 10.0's @ 133 with 1.36 60 ft. using an 11" converter rated at 2800 stall. It's all about the combination.
[Re: GY3]
#2849832
11/22/20 08:17 AM
11/22/20 08:17 AM
Posts: 570 UK
rb446
UK
dont why this seems odd coan 3500 stall converter Not that it's close to being comparable but we run 10.0's @ 133 with 1.36 60 ft. using an 11" converter rated at 2800 stall. It's all about the combination. Yep certainly don't need no loose converters with an adder. My '69 all iron 440 6-pk stock bottom end Cuda from back in 1990 ran an 8" 4800stall as NA but when I hit it with a 175hp Big Shot kit off the line it went to 7000 in an instant and I just caught the 2nd gear shift at around 7300, ran a 9.96@134 and it turned past 7500 through the traps, sh^t the life out of me with 2000gms of rod/piston flying around at those rpms with its 4.88/32" tyre combo but it lived to fight another day, only did that 1 run.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
