Canceled.Thinking of building a cheap track car.
#2846580
11/15/20 02:02 PM
11/15/20 02:02 PM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
So I'm buying a few cars from a friend that were burned in a fire. Now mind you, these cars were burned outdoors in a grass field and the interior did get toasted/destroyed, but were not like inside of a garage fire where where it gets soo hot that the cars warp into puddles. After checking them out, the Bodies are fine, but anything else was not usable. Now I was only going to use the body shells, fenders, k-members and 8 3/4 housing and replace everything else. Though I probably won't get to start building til my other 3 projects are done (probably 2024/25) and will give me time to figure out the build and use my large stash of leftover parts sitting in my yards. Any ideas on what you guys are thinking on cheap track car tech/specks? I do plan to have a cage welded in by a certified welder, so that part of the worries should be handled.
Re: Thinking of building a cheap track car.
[Re: migsBIG]
#2847539
11/17/20 12:41 PM
11/17/20 12:41 PM
Posts: 22,696 Bitopia
jcc
Bitopia
My suggestion, go with any a body, they are plentiful and best priced, spend money on engine last, after car is on the track, seat time is weakest link in the equation, so whatever gets you on the track first is best, safety is next, then tires, brakes, suspension, trans, then motor. A lot of above can be transferred to a Gurney clone, after you wad up the first A body. Perfection is the enemy of success.
[Re: jcc]
#2847966
11/18/20 06:02 AM
11/18/20 06:02 AM
migsBIG
San Jose,CA
Those are some good ideas. I'm 6'3 and shoulders are pretty wide, so no a-bodies. Though he has about a dozen e-bodies there, I like the satellite due to: A. more head. room B. I have lots of b-body parts lying around. C. I perfer these type of cars. D. The car is cheaper than the cost of used rims. Don't think I will do a Lemon's race. There are races out here you can join for the whole day on open track day. There are at least 2 near enough me in California so I could trailer or drive it there for the races. Though they make more structural parts for e-bodies, those parts are expensive and and add up quickly. My goal for the satellite is clean it out, media blast it (or dip), swap doors, trunklid, hood and hood. Slather it with LOTS of bondo and add the cheapest white paint that can be sprayed without the use of a rattle can.
[Re: migsBIG]
#2848027
11/18/20 10:34 AM
11/18/20 10:34 AM
jcc
Bitopia
I hear, you, yes & no early a bodies, but the later ones IMO have as much or more headroom as the ebodys, further, in most track car settings, you will (?) and I do, mount the aftermarket drivers seat as low as possible, I'm not 6'3" but I like my head away from the roof just as a matter of comfort. The A bodies are my least favorite solution, other then their practicality.
Good Luck, have fun.
[Re: Kern Dog]
#2848632
11/19/20 01:30 PM
11/19/20 01:30 PM
migsBIG
San Jose,CA
I have a 70' Cuda, normally sitting in it and in my former 1968 Dart, I had a maximum of one inch head clearance. The worst part of this car is if I'm wearing a hat with that little button on top, & hit a speed bump, that would make contact with the roof and the hat button would bang the top of my head and be very painful! Then imagine trying to wear a helmet. Not safe for for me. Now my 1972 Charger and 1972 Roadrunner, I have 2. 5 inches of clearance. With the lower race seat I plan to put in, I am hoping to have enough clearance to clear to roof/bars with a full helmet. My problem isn't that just that I'm tall, but my torso is longer that most people. When I sit down, even next to tall people, I am still a full foot higher than anyone sitting in the same seat.
[Re: migsBIG]
#2848819
11/19/20 08:54 PM
11/19/20 08:54 PM
Posts: 168 San Diego
JP8
San Diego
How to tell if you’re an A-body or B-body person?
Instagram : @5_points_racing
[Re: migsBIG]
#2848820
11/19/20 08:56 PM
11/19/20 08:56 PM
JP8
San Diego
Now I know how to spot you at Spring Fling
[Re: migsBIG]
#2848884
11/20/20 12:33 AM
11/20/20 12:33 AM
Posts: 31,042 Oregon
AndyF
When I built my Duster I put the seat on the floor and pushed it back a few inches and now I have plenty of head room and leg room. I don't fit in a Duster very well if I have to sit on the stock seat.
[Re: migsBIG]
#2849172
11/20/20 06:18 PM
11/20/20 06:18 PM
jcc
Bitopia
I have a 70' Cuda, normally sitting in it and in my former 1968 Dart, I had a maximum of one inch head clearance. The worst part of this car is if I'm wearing a hat with that little button on top, & hit a speed bump, that would make contact with the roof and the hat button would bang the top of my head and be very painful! Then imagine trying to wear a helmet. Not safe for for me. Now my 1972 Charger and 1972 Roadrunner, I have 2. 5 inches of clearance. With the lower race seat I plan to put in, I am hoping to have enough clearance to clear to roof/bars with a full helmet. My problem isn't that just that I'm tall, but my torso is longer that most people. When I sit down, even next to tall people, I am still a full foot higher than anyone sitting in the same seat. Maybe a "Gurney Bump" is right for you? http://race-car-replicas.com/parts/gurney-bubble#:~:text=110.00,as%20the%20%22Gurney%20Bubble%22.
[Re: jcc]
#2849386
11/21/20 06:40 AM
11/21/20 06:40 AM
Posts: 16 London England UK
Matt_Snowball
London England UK
You can lower the floor under the seat by a good few inches without affecting ground clearance . I'm 6'4 with a long back and there is now plenty of height in my 'Cuda
[Re: Matt_Snowball]
#2849798
11/22/20 12:00 AM
11/22/20 12:00 AM
migsBIG
San Jose,CA
LOL, that’s soo funny there. Sadly, that is what I look like in cargo shorts!
The lowering of the floor is a great idea. I could get a couple inches just from that, it would help greatly. A after market seat would probably save another inch or two, so it’s well worth considering. I was concerned with exhaust clearance as the car is going to be low, but that might not be an issue if I don’t run extra big pipes.
[Re: migsBIG]
#2849801
11/22/20 12:18 AM
11/22/20 12:18 AM
AndyF
You have to approach the project as a "do what it takes" rather than "must preserve the Mopar". If you do what it takes then you cut the floor for extra head room and you cut the floor for more exhaust room and put tubs in it for more wheel room and stuff like that. Most Mopar guys won't cut stuff up which is why the projects take so long and cost so much. If you're willing to just cut the stuff up and move it around then you can make the car work for you.
Just don't be dumb about it like this guy.
[Re: migsBIG]
#2850230
11/23/20 01:38 AM
11/23/20 01:38 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
What are you wanting to do? HPDE days or something like SCCA Vintage Racing. HPDE doesn't require a roll cage but any racing does. Granted always safer with a cage. At least Satellite is a 72 so aftermarket is better. I would do Hotchkis TVS, largest T Bars and about as 500 hp engine for HPDE and autocross. Vintage race car clone would be cool.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: Matt_Snowball]
#2850233
11/23/20 01:45 AM
11/23/20 01:45 AM
jcc
Bitopia
You can lower the floor under the seat by a good few inches without affecting ground clearance . I'm 6'4 with a long back and there is now plenty of height in my 'Cuda That seat lowering took a lot of effort, looks nice, what tranny are we seeing there?
