Page 2 of 7 1 2 3 4 5 6 7
Re: Why aren't there more forced induction cars? [Re: pittsburghracer] #2846040
11/14/20 10:59 AM
11/14/20 10:59 AM
gregsdart Offline
gregsdart  Offline
A 408 smallblock with 7 psi boost from a whipple would be my choice. E85, F.I., and it will feel and drive like a 540 mildly cammed stroker, except it will be FASTER!
Re: Why aren't there more forced induction cars? [Re: gregsdart] #2846043
11/14/20 11:25 AM
11/14/20 11:25 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I often think about this and believe I missed the boat. I've got $15k into building a very mild 512 and I'm happy with it, but keep coming back to forced induction. The 400B I picked up to serve as the base of the build I could have re-ringed and tossed a ProCharger onto cheaper than the stroker route. I don't do anything competitive, so it would be a sub 6k RPM build with moderate timing. Forced induction is an itch though that'll eventually get scratched though even if it has to be my upcoming brand X project.
Re: Why aren't there more forced induction cars? [Re: MarkZ] #2846055
11/14/20 11:58 AM
11/14/20 11:58 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: Why aren't there more forced induction cars? [Re: feets] #2846131
11/14/20 03:44 PM
11/14/20 03:44 PM
Feets, it ain't hard in todays world to make a low deck 400 block pump gas N/A stroker motor make over 700 on pump swill, why go to a power adder?
Re: Why aren't there more forced induction cars? [Re: Dragula] #2846139
11/14/20 03:58 PM
11/14/20 03:58 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Those Canadians build some Bad A$$ cars for sure up
Re: Why aren't there more forced induction cars? [Re: Cab_Burge] #2846153
11/14/20 04:10 PM
11/14/20 04:10 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Because it will run nicer, last longer, require less maintenance, and the power has a much wider range.
Re: Why aren't there more forced induction cars? [Re: TRENDZ] #2846164
11/14/20 04:29 PM
11/14/20 04:29 PM
confused
Me thinks more pressure, more HP, on the pistons, rods and bearing makes them live less, not longer work shruggy
Re: Why aren't there more forced induction cars? [Re: Cab_Burge] #2846189
11/14/20 05:08 PM
11/14/20 05:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
confused
Cab most of them jump on them once in awhile maybe a few times a month, wax it, and go to a car show or car cruise. Should last forever and the car show guys go crazy over blowers and turbos. 😜
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Why aren't there more forced induction cars? [Re: Cab_Burge] #2846193
11/14/20 05:12 PM
11/14/20 05:12 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
To many people feel the same thing. That’s what’s so disappointing.
No way to make great wide range power naturally aspirated without huge cubic inches. You can build a narrow power range naturally aspirated engine out of commonly available parts, but you will need big cam, big spring rates, high rpm.
I assure you that a properly tuned 800 hp turbocharged low deck engine with a smallish cam will outperform and outlast any 700 hp naturally aspirated engine that could be built on any similar budget.
Re: Why aren't there more forced induction cars? [Re: Cab_Burge] #2846233
11/14/20 07:03 PM
11/14/20 07:03 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
confused
Popular misconception.
Piston loads go up in a rather minor way but the forces are greater for a longer period of time below peak. Denser air burns longer so the area under the curve is greater.
As I said earlier, at the end of the exhaust stroke the forces are lower and you're less likely to throw a piston into the head.
- Stu Harmon
Re: Why aren't there more forced induction cars? [Re: TRENDZ] #2846237
11/14/20 07:12 PM
11/14/20 07:12 PM
ma.
roadrunner34 Offline
ma.
In the process of adding an F2 onto my 540. Cost is definitely a factor. Nothing just bolts on. Mounting brackets are pretty much adapted chevy stuff. When you start making serious steam its time to decide what you want to do about a transmission. The cost of being different I guess.
Re: Why aren't there more forced induction cars? [Re: pittsburghracer] #2846246
11/14/20 07:30 PM
11/14/20 07:30 PM
North America
K
kwikblownhemi Offline
K
North America
confused
I put mine together in 1978 using parts bought from alcohol and fuel racers. Some of the drive parts I modified or made. It has never been to a car show. I have fun with it. There are lots of reasons why people don't like forced induction. There are lots of reasons why they do. Sort of like whether people do or don't like Mopars.
Re: Why aren't there more forced induction cars? [Re: kwikblownhemi] #2846250
11/14/20 07:45 PM
11/14/20 07:45 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
I don't get why there are not more. I started using a D1 ProCharger on my 440 in 1999. I progressed to turbos and have not owned a NA performance car since. Current cars are a 71 Demon w/ 477 Hemi with 88mm Garrett turbo and a 2012 GT500 with a 2.9 Whipple. At least the people with the modern Mopars are receptive to forced induction.
Re: Why aren't there more forced induction cars? [Re: blowndart] #2846258
11/14/20 08:03 PM
11/14/20 08:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I bought a good block after I went 140 mph with a stock block.
Cab that's in the 1/8 mile. 1/2 track for you.
Now same combo in a aftermarket block is running over 160 in the 1/8.
Its a bracket motor with a turbo cam.
Been together 4 years. Stock block motor that went 140 is still together. On stand waiting on a streetcar project.
Then I have a set of twins and a billet hemi 1/2 way together for the next step in performance
Re: Why aren't there more forced induction cars? [Re: feets] #2846265
11/14/20 08:25 PM
11/14/20 08:25 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted by feets
Why are there so few turbo and blower cars out there? I can understand class rules and such but if you're out there trying to run a street strip car it's much easier to make power and the cars are far more streetable in many cases.
Build a typical 9:1 engine making 450 hp and it'll run forever. Add 7 lbs of boost and you're over 600 hp. Slide that up to 10 lbs of boost and you're crowding 800.
Engines like this do not need exotic parts. They run fine with flat hydraulic cams and stock stamped rockers. There's little need to run them over 6000. Knowing that RPM is what kills engines you can see they lead a relatively easy life as far as internal forces go.
In fact, when rods fail it's usually on the exhaust stroke where the crank throws the piston into the head and the rod can't snatch it back down. In a turbo car there is pressure in the exhaust and that actually helps reduce the force on the rod a wee bit.
Fuel injection is nice but you can get blow through carbs all day long.
Yes, there's a little more plumbing involved but it's not that hard.
Thoughts?
I am thinking it is probably because you gayed it up so bad in the early 2000s everyone went Vortec or nitrous. : D
Re: Why aren't there more forced induction cars? [Re: Jeremiah] #2846293
11/14/20 09:28 PM
11/14/20 09:28 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Thoughts?
laugh2
C'mon, he got into the 14's didn't he?
'63 Dodge 330
11.19 @ 121 mph
Re: Why aren't there more forced induction cars? [Re: FastmOp] #2846305
11/14/20 09:49 PM
11/14/20 09:49 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Where the bleep bleep progress pics at?
Re: Why aren't there more forced induction cars? [Re: Cab_Burge] #2846311
11/14/20 09:57 PM
11/14/20 09:57 PM
gregsdart Offline
gregsdart  Offline
for streetability nothing beats a twin screw style blown motor. Idle like a kitten puring, run like a scalded cat! I got sold on blowers when i put one on a 300hp 2006 mustang and it went 115 mph in the 1/4 on stock tires and still got 25 mpg on the hiway.
Re: Why aren't there more forced induction cars? [Re: gregsdart] #2846337
11/14/20 10:53 PM
11/14/20 10:53 PM
Dragula Offline
Dragula  Offline
$5500 for the Mopar dual kit....
https://www.youtube.com/watch?v=ysajjZ5Aayc
Re: Why aren't there more forced induction cars? [Re: Dragula] #2846351
11/14/20 11:50 PM
11/14/20 11:50 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Because no one makes an intake to install a whipple type blower on a Gen 2 hemi with fuel injection for less than $10K
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
