Re: Street miles / longevity on super thin rings
[Re: hemienvy]
#2841728
11/04/20 02:38 PM
11/04/20 02:38 PM
Posts: 2,730 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Super thin to me meaning less than .043" . Good compression check after 10,000 miles ? Info anyone ? .043" would be huge in todays engines that go 180,000 miles
2011 Drag Pak Challenger
[Re: cudadoug]
#2842052
11/05/20 09:07 AM
11/05/20 09:07 AM
rickseeman
Stuttgart, Arkansas
Fuel management plays into this, I think. The OE stuff that can go +250k miles on thin rings are EFI. I agree with that.
[Re: rickseeman]
#2842094
11/05/20 11:57 AM
11/05/20 11:57 AM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
Fuel management plays into this, I think. The OE stuff that can go +250k miles on thin rings are EFI. I agree with that. Yes, and probably other things too. Maybe ringland depth, ring- land clearance, cylinder finish, materials of consruction, piston to wall clearances - hot and cold, skirt lenght, motor rpm, compression/cylinder pressure, and probably a bunch of other quality and quality control aspects.
[Re: BSB67]
#2842375
11/06/20 12:11 AM
11/06/20 12:11 AM
Posts: 6,163 Melbourne , Australia
LA360
I would see no reason at all to run a 5/64" or 1/16" ring in this day and age.
0.043" would be the thickest I'd want to go if I had the choice.
Alan Jones
[Re: fastmark]
#2842451
11/06/20 09:13 AM
11/06/20 09:13 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I can’t think of a reason that piston weight would have any bearing on ring wear/ problems.
[Re: scottb]
#2842522
11/06/20 12:25 PM
11/06/20 12:25 PM
Posts: 6,033 Salem
Grizzly
Moparts Proctologist
Salem
OEM engines are tuned for low-end, upshift sooner, and do 1500 rpm on the highway, that's why they last so long. Already mentioned, precise timing and fuel injection also helps them last forever.
My opinion, if you don't have overdrive, have anything over a 3.08 rear end, and run a carb, thin rings would not last as long as stock rings.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2842527
11/06/20 12:44 PM
11/06/20 12:44 PM
Posts: 722 Lake Villa Il
INTMD8
Lake Villa Il
^ Most common oem engines are low rpm but the high rpm oem engines out there run thin rings and don't seem to wear out fast.
[Re: INTMD8]
#2842621
11/06/20 04:28 PM
11/06/20 04:28 PM
Posts: 6,033 Salem
Grizzly
Salem
^ And how long does a Viper, Mustang, or Challenger spend at 3500 rpm out on the highway or in town for that matter? Almost never. Maybe 5% of the time in town. How long does a 340, 440, 426 with 3.91's spend at 3500 rpm? All the time. Double the engine speed is double the wear.
Mo' Farts
[Re: Grizzly]
#2842626
11/06/20 04:40 PM
11/06/20 04:40 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
I have 2 drag weeks and a total of maybe 3500-4500 miles on some 1.5MM rings. Car leaked down 3% after its first test drive and it still leaks down the same as of a month ago. 4.10s no overdrive but it does have EFI. This was a CNC machined block with a Diamond hone from Shady Dell back in 2015.
68 Barracuda Formula S 340
[Re: Grizzly]
#2842627
11/06/20 04:41 PM
11/06/20 04:41 PM
Posts: 4,806 Wichita
GY3
Wichita
Are 3.0, 1.5 and 1.5mm ring packs considered thin?
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: Grizzly]
#2842634
11/06/20 05:19 PM
11/06/20 05:19 PM
INTMD8
Lake Villa Il
^ And how long does a Viper, Mustang, or Challenger spend at 3500 rpm out on the highway or in town for that matter? Almost never. Maybe 5% of the time in town. How long does a 340, 440, 426 with 3.91's spend at 3500 rpm? All the time. Double the engine speed is double the wear. I was talking about high rpm factory engines. (stuff that turns 8,000+) My Ferrari runs 4,000 rpm on the highway, engine is 26 years old. Tons of other factory engines that turn big rpm with thin rings. Of course they were designed to do that, just saying I don't think thin rings necessarily mean the engine is wearing out super fast.
