Page 2 of 3 1 2 3
Re: Lowering a D100 [Re: dart4forte] #2842393
11/06/20 01:30 AM
11/06/20 01:30 AM
Western Colorado High Desert
moparmarks Offline OP
Originally Posted by dart4forte
Originally Posted by moparmarks
They look cooler and handle better. Why does everyone raise their 4wd? it's just what you do.
Plan is using the van LCA's which I have
Flipping the perches on a truck 8.75 rear which I have.
Mini tub the rear for 15" meats
Adding sway bars, have a front one, and maybe adjustable UCA's.
I’m running 15x10 cop wheels on the back of mine with a 275/60 tire. Fills the wheel well with no rubbing. I bet that with a custom offset you could run a 15x11.
Where did you get a 15x10 cop car wheel?
I have 15x8 cop car wheels with 275/60/15 and there is about a 4" space to the springs. I haven't set a bed on it yet but pretty sure the tub doesn't go to the springs.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Lowering a D100 [Re: moparmarks] #2842406
11/06/20 02:46 AM
11/06/20 02:46 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have 15x8 cop car wheels with 275/60/15 and there is about a 4" space the springs. I haven't set a bed on it yet but pretty sure the tub doesn't go to the springs.
No, like I said the 15x10 fits withe 275/60. Got the wheels from Summit.
https://www.summitracing.com/parts/wvi-69-5012052
Abe Lincoln
Re: Lowering a D100 [Re: doggs330] #2842507
11/06/20 11:36 AM
11/06/20 11:36 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
Originally Posted by doggs330
Yes, those control arms should work. Same part number for all classes of vans from 79-03. This thread will cover the process. It really should be made a sticky.
https://board.moparts.org/ubbthread...o-lower-your-1972-1993-dodge-pickup.html
I am seeing some discrepency with this thread and the thread that people are saying should be a sticky. That one is written like a story and not like instructions (like How To articles) so it's kind of confusing. I appreciate that there is good info in the "How to lower your 1972-1994 Dodge" but the OP, Kevin I, says to use 72-93 van LCA's and to not use the Van ball joints but to use D100 ball joints.
This thread suggests you can use up to a 1994-2001 Van LCA and there is no mention of having to switch ball joints. Do you have to swap ball joints on these later, 1994-2001, Van LCA's or not?
Thanks.
Instagram : @5_points_racing
Re: Lowering a D100 [Re: JP8] #2842515
11/06/20 11:58 AM
11/06/20 11:58 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Thanks.
No, I said you can use the front springs from a 1994 to 2001 Dodge 1500. You can use the van LCAs 1973 to I belive 1978 or maybe later however not both together. I chose using the LCAs from a 1974 B100 instead of going to springs. That lowered the front approximately 2 inches. I was told that adding the lowered springs and using the van LCAs would create a bind at the upper ball joint.
Also, from what I’ve read on using the Dakota dropped spindles there’s some tie rod issues that would need to be addressed.
So, to sum up what I just said I would go ahead and use the B100 LCAs on the front. That will give you that 2 inch drop. From there you can experiment by cutting one coil at a time to see how much more drop you can get before running the risk of binding the upper ball joint. If you went that route I would have a spare set of stock springs so you can go back if you went too far.
Bottom line, not easy to lower our trucks as it is with the Chev C10s
Abe Lincoln
Re: Lowering a D100 [Re: dart4forte] #2842518
11/06/20 12:05 PM
11/06/20 12:05 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I forgot to mention another warning. With lowering the front end two inches you have to take into consideration tire height along with wheel width. You may create another set of problems. I run a 15x7 cop wheel with a 255/60/15 and have not experience any rubbing. However, with adding the larger wider wheel/tire I need to address possible frame cracking in the vicinity of the steering box.
Abe Lincoln
Re: Lowering a D100 [Re: moparmarks] #2842596
11/06/20 03:48 PM
11/06/20 03:48 PM
Dearborn, Michigan
jstollfu Offline
jstollfu  Offline
Dearborn, Michigan
Been there..
Re: Lowering a D100 [Re: dart4forte] #2842631
11/06/20 05:07 PM
11/06/20 05:07 PM
San Diego
JP8 Offline
JP8  Offline
San Diego
Ok, the original thread from Kevin I says up to 1993 van LCA with a D100 ball joint. Thanks for the input.
Re: Lowering a D100 [Re: moparmarks] #2842657
11/06/20 06:37 PM
11/06/20 06:37 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
the "looks cooler" part is debateable.
Re: Lowering a D100 [Re: volaredon] #2842667
11/06/20 07:09 PM
11/06/20 07:09 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I guess it can be said that driving a Volare is cool and that too would be debatable
Different strokes for different folks.
Abe Lincoln
Re: Lowering a D100 [Re: jstollfu] #2842693
11/06/20 08:17 PM
11/06/20 08:17 PM
E
earlymopar Offline
earlymopar  Offline
E
Sweet looking truck jstollfu.
Re: Lowering a D100 [Re: volaredon] #2842738
11/06/20 09:45 PM
11/06/20 09:45 PM
It is. That is why I've always said the only one you need to impress is yourself. Your impressed with Volares and I am with lowered 72-80 trucks.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Lowering a D100 [Re: volaredon] #2842832
11/07/20 01:55 AM
11/07/20 01:55 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
Don is a sad, sad person. He comes into forum posts on the internet to let people, who don't care about his opinion of truck stance at all, know that he doesn't like the subject matter. Good for you Don! Nobody cares.
Re: Lowering a D100 [Re: JP8] #2842933
11/07/20 11:26 AM
11/07/20 11:26 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Every forum has a Don
Abe Lincoln
Re: Lowering a D100 [Re: dart4forte] #2843290
11/07/20 10:24 PM
11/07/20 10:24 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
I hate lowered trucks, if you want something low buy a freakin' car... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Lowering a D100 [Re: Rhinodart] #2843323
11/08/20 12:14 AM
11/08/20 12:14 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
What is it with these losers coming into forums and being Karens? Nobody asked your opinion Karen (Rhinodart and Don). The title should have let you know that nobody is going to care what you have to say in regards to lowering a D100. Literally, nobody in this chat cares that YOU don't like lowered trucks.
Do you really think anyone in here is going to say to themselves, " You know what? These two random losers don't like lowered trucks. I think I won't lower mine now."?
It's like walking into a sporting goods store and getting on the loudspeaker and proclaiming to all the sports enthusiasts shopping there, " I don't like sports.". Nobody here cares what you think.
Don't be a Karen!
This is Don.
This is Rhinodork
Re: Lowering a D100 [Re: Rhinodart] #2843324
11/08/20 12:17 AM
11/08/20 12:17 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
twocents Keep your change. Nobody asked you.
Re: Lowering a D100 [Re: JP8] #2843352
11/08/20 04:15 AM
11/08/20 04:15 AM
Like I use to tell my ex-wife. Yes honey your entitled to your opinion but I'm entitled not to hear it if I didn't ask for it. twocents
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Lowering a D100 [Re: moparmarks] #2843353
11/08/20 04:30 AM
11/08/20 04:30 AM
Actually Rinodart is a friend and he is probably just getting back at me for the blowing a tranny post I made on his thread. He's not a loser. He is just from Chicago . catfight
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Lowering a D100 [Re: moparmarks] #2843396
11/08/20 10:44 AM
11/08/20 10:44 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Blowing a tranny? eek
Abe Lincoln
Re: Lowering a D100 [Re: moparmarks] #2843410
11/08/20 11:14 AM
11/08/20 11:14 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
Want to lower my 78 D100 and I have a 91 B300 van and also a 92 D250 for parts. Can I use those LCA's and if so what all do I need to do?
So back on topic, I would like to hear from anyone who has simply used 1994-2001 drop springs. If these are an option I don't see why there wouldn't be some feedback or pics, but I don't see any. I just bought some 1992 B250 Van lower control arms from Rock Auto so I'll start heading down that path for now.
Page 2 of 3 1 2 3
