Re: 511 tf270 cam, header, Intake, gear selection?
[Re: viperblue72]
#2843132
11/07/20 05:46 PM
11/07/20 05:46 PM
Posts: 876 Arizona
PolyDart
Arizona
Very nice build. Is the times in your signature with this motor?
Sort of. I made some big changes since I put the ET in my signature. Our local track closed so I retuned the engine to run on pump gas. I went from 13:1 compression to 10.5:1 while at the same time ditching my OOTB Stealth heads for a set of TF 270s and the deep port matched intake. Cam is the same, but advanced 4 degrees at the recommendation of Bob George. The old combo would hit a wall at about 5500 rpm. The Stealth heads just wouldn't let the 512 breath past that. I have hit 7000 rpm with the new combo and it was just singing along. Not sure when I'll be taking it to the track to see what it will do. I have no doubt the car will now be in the 9s so I hope I can get one really good pass in before they kick me off the track for not having all of the "stuff" needed to run 9s legally. I'm done racing since I moved to this rural community specifically for it's race track. It's just going to be a fun street/show car now.
[Re: AndyF]
#2843133
11/07/20 05:53 PM
11/07/20 05:53 PM
Posts: 876 Arizona
PolyDart
Arizona
Yeah that is a healthy cam for the 270 heads, should make plenty of power up top that is for sure. Looks like you polished the motor plate? Did that take a lot of work? The top was already very smooth when I got it from you. I just hit it with some Mothers polish on the top edge. The face isn't polished, but I did hit it with gray Scotchbrite to even out the sheen.
[Re: viperblue72]
#2843136
11/07/20 05:58 PM
11/07/20 05:58 PM
Posts: 876 Arizona
PolyDart
Arizona
My book shows 3.73 gear as being best starting line ratio with 4.25 stroke, 28' tire and 3400# for my car. 3.73 probably would be a good ratio with a 28 inch tire. I decided that 3.90 was the best ratio for my Duster but I have a 29.5 inch tire in it. Andy Iām going to be changing to a 295/65 or a 29ā tire. So 3.91 may be my best bet. š I'm running the 295/65x15 MT SS with 3.73s. The converter is a 4200 8". There is no lack of low end torque!
[Re: moparx]
#2843162
11/07/20 06:55 PM
11/07/20 06:55 PM
Posts: 31,061 Oregon
AndyF
My book shows 3.73 gear as being best starting line ratio with 4.25 stroke, 28' tire and 3400# for my car. 3.73 probably would be a good ratio with a 28 inch tire. I decided that 3.90 was the best ratio for my Duster but I have a 29.5 inch tire in it. andy, isn't your duster an automatic ? if so, what converter do you have ? TIA as always. 10 inch street converter from Turbo Action. Part number is 17805ST-17022. You would have to call them to confirm exactly what it is and if it would work for you. Paul described it to me as the tightest 10 inch converter they build for Pro Street type cars. It is the only converter I've run in my Duster so I don't have any other data points. This one seems to work just like Paul told me it would. It is loose enough that the car idles down and it doesn't push against the brake at stop lights, but it only slips about 4 or 5% at freeway speeds. I don't know how much it will slip in high gear at the track since I haven't made any passes yet. It slips a lot when you go WOT from a standing start but it starts to catch up as you go down the road. I just don't know how long it has to go before it catches up at WOT in high gear.
[Re: PolyDart]
#2843163
11/07/20 06:56 PM
11/07/20 06:56 PM
AndyF
Sort of. I made some big changes since I put the ET in my signature. Our local track closed so I retuned the engine to run on pump gas. I went from 13:1 compression to 10.5:1 while at the same time ditching my OOTB Stealth heads for a set of TF 270s and the deep port matched intake. Cam is the same, but advanced 4 degrees at the recommendation of Bob George. The old combo would hit a wall at about 5500 rpm. The Stealth heads just wouldn't let the 512 breath past that. I have hit 7000 rpm with the new combo and it was just singing along. Not sure when I'll be taking it to the track to see what it will do. I have no doubt the car will now be in the 9s so I hope I can get one really good pass in before they kick me off the track for not having all of the "stuff" needed to run 9s legally. I'm done racing since I moved to this rural community specifically for it's race track. It's just going to be a fun street/show car now. I like that story. Moved to a rural area just for the track and now you're done racing. Funny how stuff works out sometimes. I understand completely.
[Re: AndyF]
#2843241
11/07/20 09:25 PM
11/07/20 09:25 PM
Posts: 2,141 junction city oregon
viperblue72
My book shows 3.73 gear as being best starting line ratio with 4.25 stroke, 28' tire and 3400# for my car. 3.73 probably would be a good ratio with a 28 inch tire. I decided that 3.90 was the best ratio for my Duster but I have a 29.5 inch tire in it. Andy Iām going to be changing to a 295/65 or a 29ā tire. So 3.91 may be my best bet. š You have a 8.75 rearend behind 700 hp? Andy my plan is a Dana from dr diff. 3.90 or 3.91 gear is available.
[Re: PolyDart]
#2843244
11/07/20 09:30 PM
11/07/20 09:30 PM
Posts: 43,275 Bend,OR USA
Cab_Burge
That looks like the Tucson ,AZ area, is it?
[Re: PolyDart]
#2843253
11/07/20 09:44 PM
11/07/20 09:44 PM
Cab_Burge
I use to have both types of M/T ET Street and ET Street Radials of the same size, 325x60x15 on the radials, the radials didn't hook worth a hoot on the street, the bias ply where way better on the street The radials where quicker and faster at a decent hooking track, not good at all on any semi slippery surface like most streets around here As far as rear gear ratio I tried 3.73, 3.91, 4.10 and 4.30 in my old pump gas Duster, almost no noticeable differences other than spending more time in high gear at 1/4 tracks with the 4.10 and 4.30 That motor started off as a 511 C.I. with 9.25 to 1 compression with big valve slightly ported 906 heads and ended up at 517 CI. by increasing the stroke from 4.25 with -.026 piston deck height to zero deck height with a 4.300 stroke crankshaft, which increase the compression ratio to 10.29 to 1 I really like that car, it far exceeded my expectations 9.993 at 134.7 MPH cork up with the full 3.0 exhaust system and air cleaner weighing 3450 Lbs. with me in it
[Re: Cab_Burge]
#2843256
11/07/20 09:46 PM
11/07/20 09:46 PM
Posts: 876 Arizona
PolyDart
Arizona
That looks like the Tucson ,AZ area, is it? I'm close to Wickenburg, AZ.
[Re: PolyDart]
#2843343
11/08/20 02:28 AM
11/08/20 02:28 AM
Cab_Burge
Boy was I wrong I caught a bus in Wickenburg to go visit my cousins who lived in North Las Vegas at that time, circa 1960. I lived in Blythe back then I drove through Wickenburg from up here in Oregon down through Kingman down to Tucson in 2013 to pick up my current S/P car, lots of change to the entire area since 1960 I raced at Speed World in the mid 1990s also back when i lived in Hesperia, CA To bad it is still closed now
[Re: Cab_Burge]
#2843414
11/08/20 11:24 AM
11/08/20 11:24 AM
Posts: 876 Arizona
PolyDart
Arizona
Boy was I wrong I caught a bus in Wickenburg to go visit my cousins who lived in North Las Vegas at that time, circa 1960. I lived in Blythe back then I drove through Wickenburg from up here in Oregon down through Kingman down to Tucson in 2013 to pick up my current S/P car, lots of change to the entire area since 1960 I raced at Speed World in the mid 1990s also back when i lived in Hesperia, CA To bad it is still closed now Speedworld had just celebrated it's 50th anniversary 2 years before it was shut down So depressing.
