Need 7.90 jr dragster head blueprint
#2841987
11/04/20 11:36 PM
11/04/20 11:36 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
Hi, does anyone have a head blue print for a big power junior dragster? Or even a good picture of the combustion chamber? Do these things use flat top pistons, or is there a dome? I'm planning to build a non-ford flathead and going for as much power as possible. The head will be custom built, the bore will be right around 3 1/2, so I thought that maybe I could copy the combustion chamber and piston top design from these 3.5 bore engines. Since they Make almost two horsepower per cubic inch naturally aspirated. Pretty amazing for a flat head
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Need 7.90 jr dragster head blueprint
[Re: Hemi_Joel]
#2842032
11/05/20 07:05 AM
11/05/20 07:05 AM
Posts: 10,032 MN
JERICOGTX
MN
Joel, Mike has a Jr. Dragster, and a spare engine. I can ask him if the spare engine is in pieces, or together.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2842064
11/05/20 10:02 AM
11/05/20 10:02 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Joel, Mike has a Jr. Dragster, and a spare engine. I can ask him if the spare engine is in pieces, or together. Joel should have no trouble making it turn into pieces if it happens to be together
68 Barracuda Formula S 340
[Re: Bad340fish]
#2842107
11/05/20 12:34 PM
11/05/20 12:34 PM
Posts: 10,032 MN
JERICOGTX
MN
Joel, Mike has a Jr. Dragster, and a spare engine. I can ask him if the spare engine is in pieces, or together. Joel should have no trouble making it turn into pieces if it happens to be together He has been known for that.
69 GTX
68 Road Runner
