Challenger Flip-top Gas Cap Differences
#2840698
11/02/20 01:42 PM
11/02/20 01:42 PM
Posts: 4,115 MD
floyd
MD
Looking at several original flip top assemblies I have and I notice two variations. One style has the metal tab screwed in place to pop the lid open. The other style has no provisions for the tab and instead uses a rubber grommet to pop the lid open. My originals have one type or the other. My assumption is that if you had the metal tab you wouldn’t have the rubber grommet. I’ve seen pics of restored cars with both the tab and rubber grommet but don’t know if those just got added during restoration.
It is my understanding that all Challengers optioned for the flip top cap also came with the locking gas cap. The locking cap does mate up well with the rubber grommet causing the flip top lid to pop open.
Anyone know if this was a design change, early vs. late thing?
ALSO... any recommendations on how to remove and replace a chrome flip top lid? I’m not sure what to call that pressed in pin, or how to get it out without damage to the lid.
Re: Challenger Flip-top Gas Cap Differences
[Re: floyd]
#2841241
11/03/20 01:07 PM
11/03/20 01:07 PM
Posts: 19,485 north of coder
moparx
that pin should just tap out with a pin punch. those punches are made with a ball on the end to center the punch in the hole of the pin. i would put the cap in a container of your favorite penetrate liquid for a couple days to ensure a little help with tapping out the pin. if this pin is NOT able to be removed as i stated, someone please correct me before floyd damages his cap due to me giving him bad info !
[Re: floyd]
#2841349
11/03/20 05:13 PM
11/03/20 05:13 PM
Posts: 117 SE-WI
skdmark
SE-WI
Thanks for the replies. I drilled and tapped the roll pin for a 4-40 machine screw. I need to run out and get some 4-40 screws and will try to pull it out/tap it out that way. I’ve been soaking it with kroil. Will report back with results. Run the 4-40 screw (with a washer) through the ratchet end of a 1/4" drive socket. Then thread the screw into the roll pin. As you tighten the screw the socket should bottom out against the frame and as you continue to tighten it will draw the pin up into the well of the socket. Used same method to pull blind threaded dowel pins on machinery all the time.
[Re: skdmark]
#2841351
11/03/20 05:27 PM
11/03/20 05:27 PM
Posts: 4,115 MD
floyd
MD
Thanks for the replies. I drilled and tapped the roll pin for a 4-40 machine screw. I need to run out and get some 4-40 screws and will try to pull it out/tap it out that way. I’ve been soaking it with kroil. Will report back with results. Run the 4-40 screw (with a washer) through the ratchet end of a 1/4" drive socket. Then thread the screw into the roll pin. As you tighten the screw the socket should bottom out against the frame and as you continue to tighten it will draw the pin up into the well of the socket. Used same method to pull blind threaded dowel pins on machinery all the time. Great suggestion. Thanks!!!
[Re: floyd]
#2841680
11/04/20 01:24 PM
11/04/20 01:24 PM
moparx
Thanks for the replies. I drilled and tapped the roll pin for a 4-40 machine screw. I need to run out and get some 4-40 screws and will try to pull it out/tap it out that way. I’ve been soaking it with kroil. Will report back with results. Run the 4-40 screw (with a washer) through the ratchet end of a 1/4" drive socket. Then thread the screw into the roll pin. As you tighten the screw the socket should bottom out against the frame and as you continue to tighten it will draw the pin up into the well of the socket. Used same method to pull blind threaded dowel pins on machinery all the time. Great suggestion. Thanks!!! i didn't realize it was a blind hole, and the above suggestion will work. i have done so many times as well. soaking will do wonders, as you are doing.
