Re: Engine block tumble deburr process [Re: fastmark] #2840118
11/01/20 12:39 PM
11/01/20 12:39 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Those look nice. Shops here give you your block back with paint still stuck in the corners, and a mixture of oil residue and black media pellets all over inside the lifter valley and crank case. Takes a whole day to clean a block up properly when you get it back from them.
Re: Engine block tumble deburr process [Re: Neil] #2840180
11/01/20 02:01 PM
11/01/20 02:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use to own and use a hot tank years ago, now I have a shop bake and blast them and then when there done doing all the machine work they put them in their spray washer before bagging and delivering them. The washing does make they make them duller looking than Andys blocks look in his pictures.
I do deburr and do a lot of cleaning before assembling them to make sure all the oil passages and every part of the block is clean enough for brain surgery whistling
AKA aside, you can not keep a engine to clean while assembling them twocents
Re: Engine block tumble deburr process [Re: A727Tflite] #2840579
11/02/20 10:30 AM
11/02/20 10:30 AM
an8sec70cuda Offline
Originally Posted by Transman
The Wheel-A-Brator I mentioned does exactly that - picture a rotisserie inside a cage with shot being thrown as the part rotates.
Never had issue with blast media left in the engine - rifle brush the oil passages, run water through the coolant passages.
I always knock out the core plugs and remove the gallery plugs before getting a block blasted.
The machines I have used did nothing that required getting the block machined again, just honing the bores. I think it relates to the media being used.
I have seen some blocks with mild peening of machined surfaces.
iagree I used this setup when I was doing machine work. Bake the block for about an hour to make sure all grease and oil was dried and turned to powder. After blasting, they come out looking like new castings.
If you don't bake them prior to blasting, the blasting media will just cake up and lodge in the oil galleys.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine block tumble deburr process [Re: an8sec70cuda] #2840966
11/02/20 09:47 PM
11/02/20 09:47 PM
A727Tflite Offline
A727Tflite  Offline
I should have stated that I always have the block baked before blasting.
