Re: Engine block tumble deburr process
[Re: Neil]
#2840180
11/01/20 01:01 PM
11/01/20 01:01 PM
Posts: 44,244 Bend,OR USA
Cab_Burge
I use to own and use a hot tank years ago, now I have a shop bake and blast them and then when there done doing all the machine work they put them in their spray washer before bagging and delivering them. The washing does make they make them duller looking than Andys blocks look in his pictures. I do deburr and do a lot of cleaning before assembling them to make sure all the oil passages and every part of the block is clean enough for brain surgery AKA aside, you can not keep a engine to clean while assembling them
[Re: A727Tflite]
#2840579
11/02/20 09:30 AM
11/02/20 09:30 AM
Posts: 13,650 Marion, South Carolina [><]
an8sec70cuda
The Wheel-A-Brator I mentioned does exactly that - picture a rotisserie inside a cage with shot being thrown as the part rotates.
Never had issue with blast media left in the engine - rifle brush the oil passages, run water through the coolant passages.
I always knock out the core plugs and remove the gallery plugs before getting a block blasted.
The machines I have used did nothing that required getting the block machined again, just honing the bores. I think it relates to the media being used. I have seen some blocks with mild peening of machined surfaces. I used this setup when I was doing machine work. Bake the block for about an hour to make sure all grease and oil was dried and turned to powder. After blasting, they come out looking like new castings. If you don't bake them prior to blasting, the blasting media will just cake up and lodge in the oil galleys.
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
