Re: Rollcage question-lateral supports
[Re: 70satelliteguy]
#2837824
10/27/20 12:24 AM
10/27/20 12:24 AM
Posts: 31,051 Oregon
AndyF
I'd go down to the frame connectors. Maybe even X them so they go to the opposite frame connector.
[Re: dvw]
#2837874
10/27/20 08:06 AM
10/27/20 08:06 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Mine are welded to a plate right in the corner of the floorpan and driveshaft tunnel.
#2837877
10/27/20 08:12 AM
10/27/20 08:12 AM
an8sec70cuda
Thanks for the reply's. Will it cert with plates? Mike Yes, mine is NHRA cert'd to 8.50. Well, it's expired, but it certified no problem in 2008.
[Re: AndyF]
#2837932
10/27/20 11:07 AM
10/27/20 11:07 AM
Posts: 22,696 Bitopia
jcc
Bitopia
I'd go down to the frame connectors. Maybe even X them so they go to the opposite frame connector. The solution pictured makes me a bit uncomfortable concerning based on what I see, with the bent ends on main bar x brace, and that the bottom of the main roll bar and the x brace ends are not substantially tied together, which makes for a weak design load path for any side impact loads on lower main roll bar. Might certify fine, but IMO, a lacking solution.
[Re: jcc]
#2838063
10/27/20 05:32 PM
10/27/20 05:32 PM
Posts: 11,635 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Plates on the driveshaft tunnel are legal. I much prefer frame ties sectioned into and welded to the floor with "outriggers" from the framerails to the rockers also through the floor. Then the main hoop and diagonals set directly on those frame pieces. This rather than floor plates.
And Xs and triangles are your friends in your efforts to stiffen the thing up.
