144.00 mph in FAST
#2836940
10/24/20 02:39 PM
10/24/20 02:39 PM
Posts: 490 St Clair Shores, MI
DonnyBrass
St Clair Shores, MI
I guess I have to update this picture
9.824 @ 144.0
Congrats to Dave Dudek and Rick Mahoney
Chevy infiltrator 12.34 @ 109.45 with a 1.73 sixty foot
Pure Stock
Re: 144.00 mph in FAST
[Re: AndyF]
#2837008
10/24/20 05:55 PM
10/24/20 05:55 PM
Posts: 1,841 South Bend
John Brown
South Bend
Donny, what day was this? Today?
[Re: Pacnorthcuda]
#2837015
10/24/20 06:09 PM
10/24/20 06:09 PM
DonnyBrass
St Clair Shores, MI
Dudek knows what he’s doing! That officially puts the Hemicuda as second fastest car ever in FAST behind only the 69 L88! You know he’s gunning hard for the 9.77!!! you can say that again, but he missed by .001
Pure Stock
[Re: AndyF]
#2837027
10/24/20 06:28 PM
10/24/20 06:28 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
[align:center][/align] 144 mph has to be getting hairy on stock brakes and tires! Do they allow an upgrade for brake safety or does the car have to run the original brakes? At 150 mph NHRA will require a parachute which won't look stock...... Maybe? Dont think they even require a bar in those cars... crazy
[Re: B3422W5]
#2837067
10/24/20 07:52 PM
10/24/20 07:52 PM
DonnyBrass
St Clair Shores, MI
[align:center][/align] 144 mph has to be getting hairy on stock brakes and tires! Do they allow an upgrade for brake safety or does the car have to run the original brakes? At 150 mph NHRA will require a parachute which won't look stock...... Maybe? Dont think they even require a bar in those cars... crazy the Cuda is certified to 8.50
Pure Stock
[Re: DonnyBrass]
#2837069
10/24/20 08:01 PM
10/24/20 08:01 PM
B3422W5
Portage,michigan
[align:center][/align] 144 mph has to be getting hairy on stock brakes and tires! Do they allow an upgrade for brake safety or does the car have to run the original brakes? At 150 mph NHRA will require a parachute which won't look stock...... Maybe? Dont think they even require a bar in those cars... crazy the Cuda is certified to 8.50 Is it a requirement in that class to have a bar at 11.50 or quicker?
[Re: 79410aspenrt]
#2837072
10/24/20 08:08 PM
10/24/20 08:08 PM
Posts: 4,693 Wichita
GY3
Wichita
looks like there is a bar in the picture posted running through the package tray? Yep, you can see the cage and a window net.
[Re: B3422W5]
#2837077
10/24/20 08:34 PM
10/24/20 08:34 PM
DonnyBrass
St Clair Shores, MI
[align:center][/align] 144 mph has to be getting hairy on stock brakes and tires! Do they allow an upgrade for brake safety or does the car have to run the original brakes? At 150 mph NHRA will require a parachute which won't look stock...... Maybe? Dont think they even require a bar in those cars... crazy the Cuda is certified to 8.50 Is it a requirement in that class to have a bar at 11.50 or quicker? While FAST does not enforce any safety rules, the tracks we run at do, We are not big enough and we encourage our racers to follow safety guidelines.
Pure Stock
[Re: Tempest]
#2837095
10/24/20 09:29 PM
10/24/20 09:29 PM
John Brown
South Bend
No doubt the mineshaft air helped to make the mph, but the cool track doesn't do a lot for traction. It's always a balancing act on skinnies.
[Re: John Brown]
#2837100
10/24/20 09:40 PM
10/24/20 09:40 PM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
I looked the car over today and liked how the X bars got around the door panels and if I remember right, column shift. Would fit right in the show car field. The black 63 Ply max wedge sitting next to it was no slouch either.
[Re: Neil]
#2837113
10/24/20 10:32 PM
10/24/20 10:32 PM
DonnyBrass
St Clair Shores, MI
Is this Cuda a replacement for the Road Runner, or is it a car Dave built an engine for, or something else? I know the Road Runner was sold, but I'm out of the loop on the rest of it. RR was sold, it raced at MIR today too. https://www.facebook.com/FASTRacingSeries/lots of pictures and timeslips
Pure Stock
[Re: John Brown]
#2837114
10/24/20 10:36 PM
10/24/20 10:36 PM
Posts: 9,863 MI, usa
dvw
MI, usa
[u][/u] No doubt the mineshaft air helped to make the mph, but the cool track doesn't do a lot for traction. It's always a balancing act on skinnies. I believe D/A was around 2000 Doug
