Page 2 of 3 1 2 3
Re: A "Racing to the stripe" question #283639
04/10/09 09:37 PM
04/10/09 09:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Keep your foot in it..letting off or applying the brakes on the topend is the way SISSY race...and is not acceptable by many racers..
Guess you dont bracket race..... I must be a SISSY
As a matter of fact i do bracket race...
yea and how many races have you ever won?
Re: A "Racing to the stripe" question [Re: Quicktree] #283640
04/10/09 09:46 PM
04/10/09 09:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Don,Well I know you know my feeling on the subject. In a car like yours running in Pro you can get some pretty significant ET differences. Everybody does it there own way. I am not a big ET holder, we try to dial the car hard and the figure out what to do at the other end. I have an advantage sometimes of being the faster car but not so often around here at Infineon particlarly, lots of fast pipe racks for sure. Liek already stated you gotta know your car and what it can do, you gotta hit the tree consistently and you have to trust the car and your dial..
Good luck, BTW you gonna be out there tomorrow?
Re: A "Racing to the stripe" question [Re: Quicktree] #283641
04/10/09 09:48 PM
04/10/09 09:48 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: A "Racing to the stripe" question [Re: Al_Alguire] #283642
04/10/09 09:58 PM
04/10/09 09:58 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Isn't it stange, how many racers are "Holder's"? I definately do not fall into that catagory. I have to FORCE myself to dial soft. It's a double edged sword, and you will die from both methods. I guess I really am a high C person. (Max on systems and anal retentiveness.) Hey, I just let you know my weakness.
Re: A "Racing to the stripe" question [Re: Leigh] #283643
04/10/09 10:11 PM
04/10/09 10:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
One of the hardest things for me to get over was GIVING the stripe away. I learned after breaking out enough that you dont ALWAYS want it.
Re: A "Racing to the stripe" question [Re: Al_Alguire] #283644
04/10/09 10:19 PM
04/10/09 10:19 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Yes, so true.
Re: A "Racing to the stripe" question [Re: Leigh] #283645
04/10/09 10:32 PM
04/10/09 10:32 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
you better learn to play the topend .Beating a car to the strip and not lifting breakout by a thousandth will eat at you.If you drill the tree and he doesn't you'll be beat.
I've watch racers never look around and the other guys car died on the starting line then restart it and the dude broke out,he never looked back.Bracket racing is more than most think that it is.
Knowing how much et, mph you have then you scrub off just lifting its less with a faster car.
What about the other guy going through the traps first by a car you should lift not to take the chance of you breaking out.
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: A "Racing to the stripe" question [Re: Al_Alguire] #283646
04/10/09 10:48 PM
04/10/09 10:48 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks guys for your advice.. it will all be taken in..
What prompted me to ask this question was one of the races at MATS in Vegas last month.. My opponent was a very skilled racer and a true veteran of the sport..
I dont remember the specifics, but I dialed in a slightly faster time than he did.. Mine was an 11.48 to his 11.61.
At the tree, I got a jump on him by having a better light.. I think it was a .03x to his .07x... Within the first 100 feet or so, I caught him and took a slight lead.. By half track, I had a full car length on himm but he started to pull on me..
At the MPH lights, I knew he wasnt going to catch me, so because of being a rookie racer and because of everyones advice, I tapped the brakes lightly as we crossed the finish line.. As we crossed, his front bumper was even with my car doors, so there was no doubt I crossed the line first...
I got the win light, but when studying the time slip, something seemed funny to me..
I dialed in 11.48 and ran an 11.56
He dialed in 11.61 and ran 11.67
I had a .04 advantage at the tree..
He came closer to his dial in by .02... which by my math means the MOV should have been .02-ish in my favor.. yet according to the time slip.. it was an MOV of .0017
Does this make sense to anyone?
Re: A "Racing to the stripe" question [Re: Jeepmon] #283647
04/10/09 11:26 PM
04/10/09 11:26 PM
St. Louis Mo. USA
P
Pleaz Offline
Pleaz  Offline
P
St. Louis Mo. USA
Also be aware that lifting against a car that is a second or more faster than you can be tricky. The worse thing is misjudging a faster car, lifting, and watching him come around you at the line. I have done this, and it sucks!
Re: A "Racing to the stripe" question [Re: Jeepmon] #283648
04/10/09 11:27 PM
04/10/09 11:27 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
you have to take the lights into that equation
If you were 40 better to his lightthats why you were able to lift that much .But watch lifting to hard because the other car might not be scrubbing any mph off and come around you.
don
Re: A "Racing to the stripe" question [Re: 10 o to go] #283649
04/11/09 03:53 AM
04/11/09 03:53 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
don
exactly .
I know when ive cut a sh4t light , i can feel it. at that point its a quick decision at the stripe . dump the other guy can work......sometimes.....
However, a lot of times you think you hit the light hard and you get the dam timeslip and its a .075 or something...
Re: A "Racing to the stripe" question [Re: 493_DART] #283650
04/11/09 04:30 AM
04/11/09 04:30 AM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
This whole thread is the reason I built a car that will run 9's....but I dial 10.77....of course I can go 127-129 mph out the back......but it gives me plenty of closing speed on un suspecting cars...it also allows me to break out alot of 9 sec cars(when I'm pull the top that hard they tend to try to run me down.....everyone plays this game different....
Re: A "Racing to the stripe" question [Re: Chassisman] #283651
04/11/09 05:57 AM
04/11/09 05:57 AM
Arizona
Chris'sBarracuda Offline
Arizona
Here is an example of last week in Vegas 2nd round Super Street... 11.05 index
Close racing. Dwight has a stripe taker..
(W) Dwight Downing S/ST 11.05 0.034 11.054 0.004
(L) Gary Thompson S/ST 11.05 0.034 11.048 -0.002
Chris..
Re: A "Racing to the stripe" question [Re: MR_P_BODY] #283652
04/11/09 08:14 AM
04/11/09 08:14 AM
Johnstown, Ohio
fast383duster Offline
mopar addict
mopar addict
Johnstown, Ohio
I hold a few numbers (not a bunch) I like to know I am covered should the car spin... I have a brake pedal and can slow the car down, but nothing to make it go fast should I loose et at the launch.
Ryan Goodin S/Pro B386 High Speed Graphix T-shirts, Signs and More! www.highspeedgraphix.com
Re: A "Racing to the stripe" question [Re: Leigh] #283653
04/11/09 09:21 AM
04/11/09 09:21 AM
NC
440Jim Online work
440Jim  Online Work
NC
I wouldn't recommend holding anything. Dial what you think it will run. But you still have to drive the finish line. If you are dialed tight, any little thing can cause a break out (wind, pressure increase, temp drop while you are in the staging lanes, etc).
I never hold. I either dial exactly what I think, or give 0.01 safe. ie I think it will run 9.157, so I dial 9.15. If I think it will run 9.152 I can dial safe at 9.14
And IMO, when the two cars differ by 25 mph or more, it is hard to judge no matter which car is yours.
Re: A "Racing to the stripe" question #283654
04/11/09 09:44 AM
04/11/09 09:44 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
And you never let off the pedal or hit the brakes
That right keep my foot in it all the way...
Ooo Ooo I'll take that guy in the first round!!!
Re: A "Racing to the stripe" question [Re: dizuster] #283655
04/11/09 11:43 AM
04/11/09 11:43 AM
Q
Quicktree Offline
Quicktree  Offline
Q
thats about the only round you will find him unless they have buy backs
Re: A "Racing to the stripe" question [Re: Quicktree] #283656
04/11/09 12:13 PM
04/11/09 12:13 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: A "Racing to the stripe" question [Re: dizuster] #283657
04/11/09 02:32 PM
04/11/09 02:32 PM
TMP66 Offline
TMP66  Offline
Quack Quack
Re: A "Racing to the stripe" question [Re: TMP66] #283658
04/11/09 03:58 PM
04/11/09 03:58 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I agree with a lot of the responses here. It's a constant battle to play in your head before hitting the tree. I feel that if you dial what you think the car will run, minus .01 (example, car will run 10.98, dial 10.97.) you should be safe. If I cut a good light, I'm usually in good shape. I start looking over my shoulder before getting in high gear (I'm usually the slower car which I feel adds more of an advantage due to consistency). I will very rarely touch the brake pedal, as I feel I do not have to. If I lift gradually I can usually scrub some ET and stay safe doing it. By finding your competitor early in the run, you can do a constant evaluation on where they are compared to you. You need to keep looking back toward the finish line to make sure you are going straight, hitting your shift points, and looking for the stripe.
Being a machine, the car will do the same thing over and over again if all the conditions are the same. If your launch RPM is the same, shift point is the same, tire pressure is the same, engine temp is the same, and the car doesn't spin/bog/break, and the weather doesn't change, and noone spills fluid in your lane... it should run the same number over and over. There have been plenty of rounds where something above didn't happen the right way. If that happens, you KNOW you aren't going to run the number...So keep it to the wood and hope they break out.
Also don't be afraid to keep it to the wood if you feel it is going to bee too close to call. I heard an old drag racer say once..."I'd rather lose than lift". I think that he meant somewhat of a slam on bracket racing, but it holds true for the scenario above.
Take that for what it's worth. I am by no means good at the sport, but I believe in the program. The old "Bracket Racer Magazine" had great tips on index racing. If you get a chance the "Mr Dirt" series is especially good.
The biggest aid to a bracket racer's off-season regimen (to me anyway) is the use of a practice tree. You can run thousands of runs at night, in the rain, in the snow...whatever using a practice tree. Who wouldn't want to improve their chances on race day by buying a little device to put in the corner of the garage. I'll hit it while walking by over and over. They help more than anything else I have ever used, yet I hear of more racers that don't use one than I hear racer's that do. I guess that's better for us and maybe I shouldn't say it on here.
Page 2 of 3 1 2 3
