Page 2 of 3 1 2 3
Re: High compression in a big inch street motor [Re: rickseeman] #2835341
10/20/20 10:44 PM
10/20/20 10:44 PM
Livonia,MI
1968fury Offline
1968fury  Offline
Livonia,MI
Look into piston coating,cylinder head chamber and valve coatings, wide lsa cams to reduce cylinder pressure. Fuel injection setups that retard the timing if need be when it starts to detonate. $$$$$$ is it going to be worth it on a street car probably not.
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: High compression in a big inch street motor [Re: 1968fury] #2835632
10/21/20 01:34 PM
10/21/20 01:34 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Ive ran 12:1 on pump gas without any issues.... But pump gas varies from state to state, your camshaft will play a large roll in bleeding off some of the cylinder pressure... I usually use pumping compression for a good indication for pump gas. Ive seen multiple engines make a 1000 hp on pump gas naturally aspirated. Both were close to 600 inches.
Re: High compression in a big inch street motor [Re: cuda499] #2835948
10/22/20 06:33 AM
10/22/20 06:33 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
For what it's worth, my advice.....keep the compression on the low side. You will never hear the detonation before it breaks stuff. You also may not be able to always access the fuel your motor needs to stay happy. On a big stroker it will make WAY more power than you can safely use on the street, you'll never notice the difference in a point or two in compression.
My old truck tries to kill me on a regular basis just gently rolling into the throttle.
Re: High compression in a big inch street motor [Re: quickd100] #2835967
10/22/20 08:33 AM
10/22/20 08:33 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my engine responded well with a raise in compression from 11.25 up to 12.5:1. almost 4 tenths and 4 mph. I did also have a electric water pump and new shocks on the front. I'm guessing the compression increase alone was worth 2 tenths. Compression makes your heads flow/work better. old slip was 10.40@130 and new slip 10.06@134. Compression does make a difference, you just need the fuel to match.
Re: High compression in a big inch street motor [Re: quickd100] #2836069
10/22/20 12:39 PM
10/22/20 12:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have a customer with a Pettis 572 w/11.7 compression races on 94 pump and makes close to 1000hp based on it's 8.84 et at 151 mph at 3450 lbs with a pretty big 800 lift cam. so the RIGHT combo of parts can obviously work and his plugs look great so far......
Re: High compression in a big inch street motor [Re: rickseeman] #2836095
10/22/20 01:44 PM
10/22/20 01:44 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by rickseeman
I think you can run as high of a compression as you want with pump gas if you weren't ever going to get on it.
Some of the big hitters on Drag Week run 15:1 compression, but they run race gas on the street all week. Curt Johnson is a prime example of this, and his 632 CI engine with LOTS of compression, runs race gas all week. He told us if he tries to run any type of pump gas through it, it will wash the rings out right away. He changes oil every day as well.
69 GTX 68 Road Runner
Re: High compression in a big inch street motor [Re: JERICOGTX] #2836110
10/22/20 02:08 PM
10/22/20 02:08 PM
an8sec70cuda Offline
Wow, I can't imagine what it costs him to do Drag Week! That's ridiculous.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: High compression in a big inch street motor [Re: an8sec70cuda] #2836137
10/22/20 03:07 PM
10/22/20 03:07 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
LOTS!!! We figured it out, to around 3K for fuel alone. But he has won his class 7, or 8 times. He has the formula figured out. He one year built a Pump gas engine, to minimize maintenance. Won his class yet again. He got bored, and the next year he had a 15:1+ engine again. He told me they put a 3-4K chip on the high side of the MSD for street driving. Didn't leave any room for goofing off, and was easier on the valvetrain. If anyone ever gets a chance to talk with Curt, do it. You will not be disappointed.
Re: High compression in a big inch street motor [Re: quickd100] #2836155
10/22/20 03:46 PM
10/22/20 03:46 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
x2. Modern stuff does more than just retard timing to keep the engine from pinging, most of the engines that have high cylinder pressures (either high comp NA stuff or boosted applications) will limit engine load to keep them out of detonation. I don't know of any mass produced OEM car engine that is much past 12:1 NA. On a high output motor it isn't worth the risk.
Re: High compression in a big inch street motor [Re: Blusmbl] #2870603
01/07/21 06:57 PM
01/07/21 06:57 PM
pa
572charger Offline
572charger  Offline
pa
my hemi was 12.2 to 1 comp ran on pumpgas always 93 octane at 30 degrees of timming it ran 9.60s at 140+ mph i eaven sprayed it into the 8s on pumpgas and 22 degrees of timming
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: High compression in a big inch street motor [Re: polyspheric] #2870851
01/08/21 07:31 AM
01/08/21 07:31 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Originally Posted by polyspheric
W/r/t "big cam bleeding off cylinder pressure"
It does reduce CCP... all the way up to 3,000 RPM (more or less, depending on too many variables to list, but stops well before the torque peak).
After that, it increases cylinder pressure - that what it's for.
It doesn't always need 5 seconds to "build heat", the piston damage can occur in 1 second.
How True! Unless you have an unlimited supply of 'good' fuel to ALWAYS use you are playing with dynamite. You will never hear it detonate, the damage can occur in a blink of an eye. A big inch street motor with a sane compression ratio will make way more torque than you can stick to the ground. My 605 makes 750+ ftlbs at 3500 rpm.
Re: High compression in a big inch street motor [Re: an8sec70cuda] #2870863
01/08/21 08:26 AM
01/08/21 08:26 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Can Hemi's get away with more compression than a Wedge?
Re: High compression in a big inch street motor [Re: quickd100] #2870868
01/08/21 08:40 AM
01/08/21 08:40 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Compression will make a big difference in power and torque, at the track and in the street.
I live in Michigan so have only driven my cars in the summer, but, if given the chance, i much prefer running race gas. Its easy to get, consistent compared to pump swill with who knows what in it.iItsvnever hard to access
I drive a few hundreds of miles on the street every summer, typically not thousands of miles, so at 7 bucks a gallon the cost to run race gas isn't that big of deal.i figure if i cant afford to put fuel in it, i am probably involved in a hobby i cant afford.
I have had several engines where i raised compression and saw it immediately at the track.
My project over the winter here will yet again. Going from a 360 to a 418, Changing nothing other than the cubes and compression, little bit of head work. Heads will be way to small for 418 inches. But going from 10 to 1 to 12.5 to 1 compression. I am expecting big gains for primarily that reason. Figure the compression alone is probably 40-45 horsepower. Same cam, headers, carb, etc, etc
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: High compression in a big inch street motor [Re: B3422W5] #2870892
01/08/21 09:38 AM
01/08/21 09:38 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I would love to find out if I kept my high compression, would 93 octane and any of those additives work?
Re: High compression in a big inch street motor [Re: 73DAD] #2870926
01/08/21 10:20 AM
01/08/21 10:20 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
That's my understanding
2011 Drag Pak Challenger
Re: High compression in a big inch street motor [Re: rickseeman] #2870972
01/08/21 11:08 AM
01/08/21 11:08 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
605 Hemi, 11:1, no signs of detonation on the plugs or audible pinging on 92 octane and 32 degrees of timing.
[Linked Image]IMG_8495 by Greg Ault, on Flickr
Re: High compression in a big inch street motor [Re: 73DAD] #2871024
01/08/21 12:10 PM
01/08/21 12:10 PM
Dragula Offline
Dragula  Offline
Yes...Typically 12:1 is no issue on pump gas....I am at 11.6:1 on my big Hemi...No issues with that.
Re: High compression in a big inch street motor [Re: polyspheric] #2871058
01/08/21 12:51 PM
01/08/21 12:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
iagree
Dead on.
I've driven high compression motors on the street using not enough octane, with the plan being to stay out of the throttle. The question is do you have enough a self-discipline when an impromptu challenge arises? I don't.
It's like being alone in a motel room with a lingerie clad super model and agreeing not to look at her.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: High compression in a big inch street motor [Re: gsmopar] #2871377
01/08/21 09:51 PM
01/08/21 09:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What is your piston comp height? I have ta buy some pistons for my 572 Hemi (7.1 rod)
Re: High compression in a big inch street motor [Re: Hemi_Joel] #2871399
01/08/21 11:07 PM
01/08/21 11:07 PM
Dragula Offline
Dragula  Offline
iagree
Dead on.
Well I said earlier 12:1 Hemi on pump gas is no issue, save one, ever driven a +800hp on the street? And if there was a super model in the hotel room with me, in lingerie, I was only looking to make sure it was all female..I am on a budget after spending all that money on a Hemi...
Page 2 of 3 1 2 3
