Re: Winter update for the Coronet
[Re: AndyF]
#2832428
10/13/20 07:14 PM
10/13/20 07:14 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Andy you should watch this video and it will give you an idea of what is happening inside your 5-speed shifting issues. https://www.youtube.com/watch?v=6UnFDaAdBaM I have done this repair on a few 5-speeds and it makes a night and day difference Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#2837743
10/26/20 08:24 PM
10/26/20 08:24 PM
fourgearsavoy
Rittman Ohio
Yeah that was very interesting. I don't think I have the gumption to tear into that Doug Nash though! Looks like a lot of work and some tools that I don't have but it is cool to know that there are parts available to fix the shifting. I'll check into buying the parts and then look around for someone who can do the work. The last one I done was a Richmond and I had a about $160 in parts and I charged $150 labor and it shifted like butter. He has it in a 528 Hemi Cuda Gus
[Re: AndyF]
#2839880
10/31/20 08:07 PM
10/31/20 08:07 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Cleanliness is not far from craziness. Must get that thing dirty. Soon.
[Re: AndyF]
#2839946
10/31/20 10:02 PM
10/31/20 10:02 PM
fourgearsavoy
Rittman Ohio
Yeah it would be nice to have a working speedo in the car. A guy at the track told me a 69 Camaro cable would be a bolt in replacement cable for my Savoy with the Richmond. Gus
[Re: AndyF]
#2839980
10/31/20 11:38 PM
10/31/20 11:38 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
No, the track didn't have any street legal sessions this summer. Couldnt you have just showed up on a bracket race day and made time trial hits and raced it a round or two? Just to see what it would run.
[Re: B3422W5]
#2884961
02/07/21 07:53 AM
02/07/21 07:53 AM
B3422W5
Portage,michigan
No, the track didn't have any street legal sessions this summer. Couldnt you have just showed up on a bracket race day and made time trial hits and raced it a round or two? Just to see what it would run. I take that as a no? Of course you could have
[Re: B3422W5]
#2946690
07/24/21 04:31 PM
07/24/21 04:31 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
"Sold the Duster so now.." Perhaps the new owner will test it out while it's still under warranty.
[Re: @#$%&*!]
#2946762
07/24/21 07:20 PM
07/24/21 07:20 PM
Posts: 1,030 ohio
67mprfan
ohio
What pulley are you using with the ATI damper and your low mount alternator setup..... Is that extra bracket needed to help stabilize the alternator
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2946795
07/24/21 09:44 PM
07/24/21 09:44 PM
Posts: 31,083 Oregon
AndyF
What pulley are you using with the ATI damper and your low mount alternator setup..... Is that extra bracket needed to help stabilize the alternator I'm using a March two groove pulley. The extra brace is just an idea. I use my own car to test new parts. Sometimes I put the new parts into production, sometimes I don't.
[Re: 67mprfan]
#2946959
07/25/21 12:38 PM
07/25/21 12:38 PM
Posts: 145 NJ
cb1289
NJ
Andy, where did you get the large diameter v belt pully for the alternator? Thanks.
62 Dodge Dart Wagon
65 Plymouth Satellite
