Mild performance upgrades - 1998 Durango #2832256
10/13/20 11:40 AM
10/13/20 11:40 AM
Plymouth, MI
Blusmbl Offline OP
Blusmbl  Offline OP
Plymouth, MI
Quick one for the experts here. A friend got a 1998 Durango 5.2 in pretty nice shape and he is slowly building it into a trail rig. It has 33x10.50 BFG's now, a sweet homemade front bumper, a catback exhaust, and other real minor stuff. I've driven it offroad in a few different locations now and really like it. It runs fine but really is gutless above 3000 rpm. The engine only has about 100k miles on it but it is mostly idle hours (long story). Planning on a rebuild over the winter. In the meantime, are there any good bang for the buck performance upgrades? What is the preferred way to tune the ECU? Do they wake up well with a cam swap? I understand the heads are limited to 0.500" lift or less. I'll likely do some cleanup port work on it as well. Is it worth finding a 5.9 instead of rebuilding the 5.2?
Thanks!
Re: Mild performance upgrades - 1998 Durango [Re: Blusmbl] #2832291
10/13/20 01:20 PM
10/13/20 01:20 PM
Mentor, OH
doggs330 Offline
doggs330  Offline
Mentor, OH
Not sure if any place supports the magnum small blocks more than Hughes. There is a lot of reading to be done in their tech section.
http://www.hughesengines.com/TechArticles/magnum_engines_articles.php
Quote
Either of these cams alone will increase low end torque considerably. We are talking in the neighborhood of 12-18 lb/ft of increased torque and it will continue to pull hard above 3000 rpm where the stock cam flattens out. No other modifications besides springs & retainer kit (part #1199) such as computer changes or tuners, will be required to use these cams. Need even more power? Check our cam list or give us a call.
Re: Mild performance upgrades - 1998 Durango [Re: Blusmbl] #2832459
10/13/20 08:42 PM
10/13/20 08:42 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
This guy does good things with the 5.2/5.9 for offroad and towing
http://utawesomeperformance.com/kegger-vrp.html
Re: Mild performance upgrades - 1998 Durango [Re: A990] #2833084
10/15/20 04:10 PM
10/15/20 04:10 PM
Plymouth, MI
Blusmbl Offline OP
Blusmbl  Offline OP
Plymouth, MI
Thanks guys, I like the idea of a cam that doesn't require tuning!
Re: Mild performance upgrades - 1998 Durango [Re: Blusmbl] #2833096
10/15/20 04:58 PM
10/15/20 04:58 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Get hughes smallest cam, clean up the ports with a good valve job run thinnest head gaskets you can find (I like to buy a single mr gasket MLS and use one outer layer for each side with some copper spray sealant for a very nice compression and quench bump). Ford 1997-2003 5.4 yellow injectors atomize the fuel better and flow a tiny bit more fuel and can be had dirt cheap at the junkyard.
On the other hand a 5.9 bolts right in with no other changes needed butt MPG will suffer a little bit.
The changes I listed will help MPG but could also be done to a 5.9 on a stand on the side while driving you durango till the motor is ready.
Re: Mild performance upgrades - 1998 Durango [Re: Blusmbl] #2833101
10/15/20 05:16 PM
10/15/20 05:16 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Thanks!
Yes. +35 lb/ft and a cheaper and more reliable way to go than spending money on cams, intake manifolds, headers and such.
As for the "tuners", well, if that stuff actually worked there would be tons of them on the road......and there isn't. twocents
Don't rule out putting a cheap EBay turbo on it. Apparently, if you keep it under 7lbs of boost the factory system can work with it.
Mo' Farts
Moderated by "tbagger".
Re: Mild performance upgrades - 1998 Durango [Re: Grizzly] #2833117
10/15/20 06:39 PM
10/15/20 06:39 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
IMHO torque will be your friend. The Durangos are heavy, my '99 4WD tipped the scales at 5500#
As others have stated, a low-mile 5.9 is probably your best bang-for-the-buck, along with shortie headers and some of the other tweaks.
Question for the other board members -- how difficult would a 5.7 swap be?
Re: Mild performance upgrades - 1998 Durango [Re: YYZ] #2833160
10/15/20 09:02 PM
10/15/20 09:02 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Everything is different between a 5.2/5.9 and a 5.7. We did that swap on my son's ride (not a Durango). Wiring, computer, motor mounts, motor & trans, exhaust location, power steering pump, radiator and I'm sure I've missed something. The bottom line is, if you want a Hemi Durango, go buy one, you will be money ahead.
For the record, I wasn't impressed with the performance improvement of a 5.9 over a 5.2 either, bottom end was a bit more fun, but above 3,000, I didn't see much difference, and that was in a light truck. Gene
