Mild performance upgrades - 1998 Durango
#2832256
10/13/20 11:40 AM
10/13/20 11:40 AM
Posts: 8,171 Plymouth, MI
Blusmbl
Plymouth, MI
Quick one for the experts here. A friend got a 1998 Durango 5.2 in pretty nice shape and he is slowly building it into a trail rig. It has 33x10.50 BFG's now, a sweet homemade front bumper, a catback exhaust, and other real minor stuff. I've driven it offroad in a few different locations now and really like it. It runs fine but really is gutless above 3000 rpm. The engine only has about 100k miles on it but it is mostly idle hours (long story). Planning on a rebuild over the winter. In the meantime, are there any good bang for the buck performance upgrades? What is the preferred way to tune the ECU? Do they wake up well with a cam swap? I understand the heads are limited to 0.500" lift or less. I'll likely do some cleanup port work on it as well. Is it worth finding a 5.9 instead of rebuilding the 5.2?
Thanks!
Re: Mild performance upgrades - 1998 Durango
[Re: Blusmbl]
#2832291
10/13/20 01:20 PM
10/13/20 01:20 PM
Posts: 77 Mentor, OH
doggs330
Mentor, OH
Not sure if any place supports the magnum small blocks more than Hughes. There is a lot of reading to be done in their tech section. http://www.hughesengines.com/TechArticles/magnum_engines_articles.phpEither of these cams alone will increase low end torque considerably. We are talking in the neighborhood of 12-18 lb/ft of increased torque and it will continue to pull hard above 3000 rpm where the stock cam flattens out. No other modifications besides springs & retainer kit (part #1199) such as computer changes or tuners, will be required to use these cams. Need even more power? Check our cam list or give us a call.
[Re: A990]
#2833084
10/15/20 04:10 PM
10/15/20 04:10 PM
Blusmbl
Plymouth, MI
Thanks guys, I like the idea of a cam that doesn't require tuning!
[Re: Blusmbl]
#2833096
10/15/20 04:58 PM
10/15/20 04:58 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Get hughes smallest cam, clean up the ports with a good valve job run thinnest head gaskets you can find (I like to buy a single mr gasket MLS and use one outer layer for each side with some copper spray sealant for a very nice compression and quench bump). Ford 1997-2003 5.4 yellow injectors atomize the fuel better and flow a tiny bit more fuel and can be had dirt cheap at the junkyard.
On the other hand a 5.9 bolts right in with no other changes needed butt MPG will suffer a little bit.
The changes I listed will help MPG but could also be done to a 5.9 on a stand on the side while driving you durango till the motor is ready.
[Re: Blusmbl]
#2833101
10/15/20 05:16 PM
10/15/20 05:16 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Thanks! Yes. +35 lb/ft and a cheaper and more reliable way to go than spending money on cams, intake manifolds, headers and such. As for the "tuners", well, if that stuff actually worked there would be tons of them on the road......and there isn't. Don't rule out putting a cheap EBay turbo on it. Apparently, if you keep it under 7lbs of boost the factory system can work with it.
Mo' Farts
Moderated by "tbagger".
[Re: YYZ]
#2833160
10/15/20 09:02 PM
10/15/20 09:02 PM
Posts: 10,605 Freeport IL USA
poorboy
Freeport IL USA
IMHO torque will be your friend. The Durangos are heavy, my '99 4WD tipped the scales at 5500#
As others have stated, a low-mile 5.9 is probably your best bang-for-the-buck, along with shortie headers and some of the other tweaks.
Question for the other board members -- how difficult would a 5.7 swap be? Everything is different between a 5.2/5.9 and a 5.7. We did that swap on my son's ride (not a Durango). Wiring, computer, motor mounts, motor & trans, exhaust location, power steering pump, radiator and I'm sure I've missed something. The bottom line is, if you want a Hemi Durango, go buy one, you will be money ahead. For the record, I wasn't impressed with the performance improvement of a 5.9 over a 5.2 either, bottom end was a bit more fun, but above 3,000, I didn't see much difference, and that was in a light truck. Gene
