Re: B to RB intake adapters [Re: hp383] #2836313
10/22/20 09:28 PM
10/22/20 09:28 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Originally Posted by hp383
Anyone know where to locate a set of B to RB intake manifold spacer adapters?
I have a M1 tunnel ram that I really would like to use on the 440.
Since the M1 is impossible to find, complete, or just a base. I am hoping to find a set of spacers to complete my build.
I may be a little late to the parade, but I think I have a M1 tunnel ram base for a 440 in my storage garage. (base only)
I am not on here often, but I can be reached at ProStDodge@aol.com
Scott
Re: B to RB intake adapters [Re: moparmarks] #2836389
10/23/20 08:21 AM
10/23/20 08:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Originally Posted by moparmarks
When using the MP aluminum Stage VI heads on a 413-440 you need the spacers. On a 383-400 you use an RB manifold.
I'm not sure that is the same thing...
Coming soon!!!!
Re: B to RB intake adapters [Re: Mr.Yuck] #2845976
11/14/20 12:02 AM
11/14/20 12:02 AM
ProStDodge Offline
ProStDodge  Offline
Ok, I found this in my storage shed.
Re: B to RB intake adapters [Re: Mr.Yuck] #2846018
11/14/20 08:49 AM
11/14/20 08:49 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Why not. shruggy These spacers were the difference between B and RB manifolds. Years ago I used a set to install a B manifold onto a 440.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: B to RB intake adapters [Re: Mr.Yuck] #3012458
02/05/22 12:50 PM
02/05/22 12:50 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m just going to add this in case it might help someone in the future......
The stage 6 spacers can probably be made to work to install a B intake on an RB block, but will likely need to be modified some.
The stage 6 heads have raised ports, the stock heads do not.
I haven’t placed a stage 6 spacer onto a stock head, but I think the lower edge of the space would hang down below the lower edge of the head.
That extra material would need to be removed from the spacer so the stock valley pan(or other valley cover) would fit between the spacer and the head.
Even when used on stage 6 heads, these stage 6 spacers do create a little dog leg in the flow path.
