2004 Ram 2500 4x4 Front U Joint #2829715
10/07/20 11:02 AM
10/07/20 11:02 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
So I just fixed the exhaust leaks and now I need to replace the front U joints. Not a hard job, well it turned into a real pain. So the rotor is rust on the hub, soak it and hit with the hammer, get my air hammer gun and try that.
No luck so I move on. Take the hub, axle and rotor off together by using the the power steering method to push the hub out. Not a chance everything is frozen solid. Any one have any other ideas. I don't want to damage and need to replace the rotors or hubs just to replace the u Joints.
Some help please
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 2004 Ram 2500 4x4 Front U Joint [Re: VCODE] #2829770
10/07/20 12:05 PM
10/07/20 12:05 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Soak the whole thing with WD and let it sit overnight. Especially the center.
The rotor has to come off somehow, they will take a decent beating, and the only way is with a BFH. Start lightly, rotate the rotor a lot and increase the hit as you need to. I've never wrecked a rotor with a hammer, but they are only $40 or so if you do.
To remove the hub bearing on yours, loosen the hub bolts about 3/4" off, put a socket you don't care about on the end of the bolt and beat on them. Alternate on ALL the bolts. It will break loose.
I know of no other way to do it when it's rusted together, and I've done a few of them. As a matter of fact I have a set of ball joints waiting for me on my Beater '01 to do one of these days. frown I put everything back together with anti-seize so I don't have to fight with it next time.
Mo' Farts
Moderated by "tbagger".
Re: 2004 Ram 2500 4x4 Front U Joint [Re: VCODE] #2830581
10/08/20 09:57 PM
10/08/20 09:57 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have a LARGE Mac air hammer.... hearing protection and the shop will hate me for 15-20 min at times. Flat hammer bit between the studs with lots of PB Blaster.
Re: 2004 Ram 2500 4x4 Front U Joint [Re: J_BODY] #2830677
10/09/20 09:15 AM
10/09/20 09:15 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Let me tell you, this is a real Bear. This has not been apart since 2004.I have tried everything, even used the large 3 foot sledge hammer on the rotor, did not loosen it at all. I will get it at some point.
Thanks Bob
Re: 2004 Ram 2500 4x4 Front U Joint [Re: VCODE] #2830681
10/09/20 09:28 AM
10/09/20 09:28 AM
Guitar Jones Offline
Time to break out the hot wrench.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 2004 Ram 2500 4x4 Front U Joint [Re: Guitar Jones] #2830699
10/09/20 10:51 AM
10/09/20 10:51 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
laugh2 2 days and you still haven't got it?
Maybe call someone to come do it for you? tonguue
Mo' Farts
Re: 2004 Ram 2500 4x4 Front U Joint [Re: Grizzly] #2830875
10/09/20 05:34 PM
10/09/20 05:34 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Got it off now. Took the cut off wheel to it. Grinded it until I could crack it off with the chisel on the air hammer.
Thanks Bob
