cam thrust plate #2829311
10/06/20 01:13 PM
10/06/20 01:13 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
just double checking bolt with oil hole goes upper left corner correct ?
and when mounting plate, flat surface is on outside of block ( dimples in plate towards engine ) ??
both when looking at front of block. Thanks Guys Kevin
sorry forgot to mention sm . block 340
Re: cam thrust plate [Re: B5TA] #2829524
10/06/20 07:22 PM
10/06/20 07:22 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Like this. Your engine may or may not have the drip tab
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: cam thrust plate [Re: RealWing] #2829542
10/06/20 07:50 PM
10/06/20 07:50 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Thank You ! That is exactly what I was looking for. No drip tab on mine . Thanks!!!!! Kevin
Re: cam thrust plate [Re: B5TA] #2829690
10/07/20 09:17 AM
10/07/20 09:17 AM
If the other top bolt hole also goes open into the valley you can drill an 1/8" hole in that bolt for additional drip oiling onto t he chain
