Re: Camshaft theoretical questions [Re: turbobitt] #2829172
10/06/20 05:29 AM
10/06/20 05:29 AM
Guitar Jones Offline OP
Originally Posted by turbobitt
If you don't like the hydraulic rollers just put the solid rollers on the same cam. If its a true hydraulic lobe profile it will have aggressive lobes so it will probably make more power on a solid roller lifter with tight lash(.012-.016). I wouldn't worry about duration loss with valve lash on a solid roller profile because some of the solid profiles can have really slow accel/decel ramps and just add unwanted overlap at tight lashes and you wouldn't be doing yourself any favors tightening the lash. If you have lobe numbers and the manufacture of both cams it would be easier to make a more accurate determination.
AG.
I have thought of this and going to a 1.65 or 1.7 rocker.
Re: Camshaft theoretical questions [Re: Guitar Jones] #2829219
10/06/20 10:34 AM
10/06/20 10:34 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
This was going to be my recommendation.
Engine Masters has an engine that runs solid roller lifters on a roller cam and it worked well for them.
Re: Camshaft theoretical questions [Re: Guitar Jones] #2829274
10/06/20 12:37 PM
10/06/20 12:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been tightening up all of my Isky solids and solid rollers forever......my .026 lash request was too damn noisy so .014 cold gets me about .020-.021 hot and runs great.....
