Leaf spring pads #2829053
10/05/20 07:57 PM
10/05/20 07:57 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I need some, 3" axle tube, 2 1/2" spring. Very common.
But the center hole for the spring pin for some reason is top secret. Nobody shows it.
I need 1/2" center hole, who has bought these and where did you gettum ?
Re: Leaf spring pads [Re: hemienvy] #2829067
10/05/20 08:51 PM
10/05/20 08:51 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Hi Hemi , this topic comes up a lot . the 5/8 center hole spring pads are mopar P4120074 . the ones you want with the 1/2" center hole is mopar P5007857 . I think mancini racing has both as well as the other vendors . drive ronnie
Re: Leaf spring pads [Re: 1969ronnie] #2829084
10/05/20 09:23 PM
10/05/20 09:23 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks much Ronnie.
Now comes the phone marathon.
Re: Leaf spring pads [Re: hemienvy] #2829088
10/05/20 09:39 PM
10/05/20 09:39 PM
1969ronnie Offline
1969ronnie  Offline
Hi hemi , I agree . and whoever you try to order them from , make sure they are physically in stock . lot's of back orders and delays because of corona . and vendors saying you will have them in a week . wrench ronnie
Re: Leaf spring pads [Re: 1969ronnie] #2829124
10/05/20 10:52 PM
10/05/20 10:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
FWIW, Moroso spring perches are identical to the OEM Mopar Dana 60 passenger car pieces.
Re: Leaf spring pads [Re: DoctorDiff] #2829134
10/05/20 11:09 PM
10/05/20 11:09 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Doctor, are those pieces 1/2" hole or different ?
Re: Leaf spring pads [Re: hemienvy] #2829147
10/05/20 11:49 PM
10/05/20 11:49 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Moroso spring perches are made with a 1/2" center hole.
Re: Leaf spring pads [Re: hemienvy] #2829152
10/06/20 12:46 AM
10/06/20 12:46 AM
AndyF Offline
AndyF  Offline
Summit Racing has a large selection of perches. Calvert Racing has boxed perches. I'm sure Doctor Diff can sell you perches.
Re: Leaf spring pads [Re: DoctorDiff] #2829194
10/06/20 08:56 AM
10/06/20 08:56 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Doctor, I tried to PM you about this but your box is full.
Re: Leaf spring pads [Re: hemienvy] #2829598
10/07/20 12:38 AM
10/07/20 12:38 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I weld in a 1/2” inside tube, no biggie. Stock ones are very easy to get off, cut into the corners a little then knock em off with a big hammer. I got a pair from my buddy that had the big hole, fixed them but have never used them
Re: Leaf spring pads [Re: cudaman1969] #2829609
10/07/20 01:19 AM
10/07/20 01:19 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
If the 5/8 P4120074 hole will work for you here are new mopar for $23 shipped.
https://www.ebay.com/itm/MOPAR-PERFORMANCE-3-AXLE-TUBE-SPRING-PERCH-BRACKETS-SET-OF-2-OEM-NEW-MOPAR/191653904278?epid=675729092&hash=item2c9f767f96:g:2mgAAOSwjBNc4vUy
STOP POTATO HATE!
Re: Leaf spring pads [Re: Mr PotatoHead] #2829795
10/07/20 12:59 PM
10/07/20 12:59 PM
moparx Offline
moparx  Offline
