Headlight harness upgrade?
#2828777
10/05/20 06:13 AM
10/05/20 06:13 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Seems I remember someone on here advertising a headlight relay/bulb/harness upgrade, anybody know where to get one or have any recommendations or remember that seller? Looking to upgrade the headlights on my 76 D300, thanks
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: Headlight harness upgrade?
[Re: 3hundred]
#2828793
10/05/20 08:27 AM
10/05/20 08:27 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
He makes great, high quality products. I have his headlight relay harness upgrades on both my Mopars and one of his convertible top relay harnesses on my '68. Highly recommended.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jlatessa]
#2828824
10/05/20 09:33 AM
10/05/20 09:33 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I didn't make that diagram ¿?¿?¿?¿?, but is pretty much the correct way to make it ( including the alternator source )
LOL
however is pretty much easy to make a relay upgrade by yourself. And you can even make it without cut a single wire and install the relays into the cab, being protected from heat and oil, but just if you have your ammeter wiring upgraded, since you should take the power for relays from amm stud.
On my car I used halogen sealed beams. I hate HIDs, Leds and anything like that. Sure they suck less load than Halogens, But I'm stuck with the old fashion halogen "yellowish" light ( and sealed beams )
[Re: jlatessa]
#2828827
10/05/20 09:41 AM
10/05/20 09:41 AM
Posts: 2,592 None
71rm23
None
Found this from Nacho.... Daniel Stern made that diagram
[Re: 71rm23]
#2828829
10/05/20 09:43 AM
10/05/20 09:43 AM
NachoRT74
Valencia, España
Found this from Nacho.... Daniel Stern made that diagram yes definitelly not me. I could have forwarded or included on some thread or reply ( which I don't even remember either LOL ), but I didn't make it
[Re: NachoRT74]
#2828831
10/05/20 09:48 AM
10/05/20 09:48 AM
NachoRT74
Valencia, España
This is the one I made, with relays hidden down the kick panel. Didn't need to cut a wire, just remove terminals from floor dimmer switch plug and install on relays plug, and link the floor dimer switch and relays with a wire section on same color to still trigger the relay.
just needed the relays, plugs for relays, 8 packard 56/58 terminals, violet wire piece, red wire piece... 2 eyelet terminals, and red and black wires for positive and ground. Couple of fuses or even better a breaker.
It can be made also similar close to bulkhead into the cab side, just that the red and violet wires originally going to bulkhead will go to 86 terminal, and the wire piece to replace into the bulkhead will go to 87 terminal
[Re: NachoRT74]
#2828840
10/05/20 10:10 AM
10/05/20 10:10 AM
NachoRT74
Valencia, España
you can use interlocked sockets to make the block with a mount ear to attach it somewhere and reach the relays anytime ![[Linked Image]](https://images-na.ssl-images-amazon.com/images/I/51cj%2BpwNonL._AC_SY355_.jpg) Interesting, just found there are relays with serviceable fuses attached! This saves on installing process for the fuse. ![[Linked Image]](https://www.altecautomotive.co.uk/ekmps/shops/altecshop/images/4-pin-automotive-type-12-volt-30amp-relay-with-buit-in-fuse-holder-alt-ry28-02-3599-p.png)
[Re: TC@HP2]
#2828882
10/05/20 11:37 AM
10/05/20 11:37 AM
RapidusMaximus
Weatherford, Texas
Jeez, that's a lot of good info, thanks guys... ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) , I looked at all the options listed and have a message in to crackedback to see what he offers. Thanks again
[Re: Mattax]
#2829009
10/05/20 05:24 PM
10/05/20 05:24 PM
NachoRT74
Valencia, España
I knew that wasn't Nacho's diagram because he wouldn't normally show or recommend connecting the alternator to the battery.
OBVIOUSLLY LOL Looks like Nacho cut in in at or near the hi/low switch.
yes on kick panel area, but no, I din't cut any wire but untapped a bit of the harness there, removed the terminals from the dimmer switch plug and inserted to the relay socket 87 terminal. Then use a wire on same color ( violet for lows and red for highs as factory ) to link the floor dimer switch with the 86 terminal of relay at socket with new Packard terminals. Then taped everything back and it looks like nobody touched it LOL... except for ne new "pigtail" ( also taped along with teh rest of harness ) coming out from underdash harness around kick panel with the sockets and relays Something like this I made for the low and mid AC speeds... It seems as an untouched harness... but if you pull out the harness will find the relays. Not a single wire cut. ( I made this for all AC-Heater speeds and also headlights ). ![[Linked Image]](https://i.postimg.cc/0jVhCzsQ/Imagen226a.jpg) ![[Linked Image]](https://i.postimg.cc/rsVvWS73/Imagen227a.jpg) Sorry the blurry pics, they were made with an old Nokia 6125 phone maaaany years ago I Couldn't find interlocked sockets with the mounting provision in Vzla when I made the upgrade, althought they are interlocked, Will upgrade that some day in the future with fused relays too.
![Name: 3bb04ab0-c1c1-4e7b-856c-6a6691ed94f1_1.39555eb5466e7e50d16021faa2c3b3aa.jpeg
ID: 406484 3bb04ab0-c1c1-4e7b-856c-6a6691ed94f1_1.39555eb5466e7e50d16021faa2c3b3aa.jpeg](/ubbthreads/ubbthreads.php/ubb/download/Number/406484/filename/3bb04ab0-c1c1-4e7b-856c-6a6691ed94f1_1.39555eb5466e7e50d16021faa2c3b3aa.jpeg)
[Re: NachoRT74]
#2829027
10/05/20 06:07 PM
10/05/20 06:07 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Ive been running crackedback’s harnesses for years. Good quality product.
Abe Lincoln
[Re: jlatessa]
#2829188
10/06/20 08:39 AM
10/06/20 08:39 AM
Posts: 2,592 None
71rm23
None
I apologize for giving Nacho credit....I just assumed any wiring help was his...LOL He's been a wealth of help in this subject.
Joe No worries Joe. Both are a wealth of info and both diagrams will work. I do like Nacho's idea on the kick panel but I already installed mine under my battery tray and wired it.
[Re: BDW]
#2829191
10/06/20 08:47 AM
10/06/20 08:47 AM
Posts: 2,592 None
71rm23
None
It does take some work, but as always it’s a trade-off, your time or your wallet. I put my relay out of sight under the battery tray. Same here BDW
[Re: 71rm23]
#2829216
10/06/20 10:10 AM
10/06/20 10:10 AM
Posts: 1,319 Ohio
jlatessa
Ohio
Mine are under the battery tray too, but now visible with the battery in the trunk....
Joe
I'm going to have to tape all my new wiring like yours, the convoluted wire protection I used is clumsy looking.
