Re: Dual plug reasoning?
[Re: DemonDust]
#2835985
10/22/20 09:33 AM
10/22/20 09:33 AM
Posts: 3,510 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
There are several big power turbo builds running 1000+ hp using one plug. Don't some of the heads up series add extra weight on 16 plug engines?
[Re: Medlock51]
#2839257
10/30/20 12:33 PM
10/30/20 12:33 PM
Posts: 112 Michigan
ghinmi
One plug fires 20 degrees btdc...the second fires 5 degrees atdc to clean up the nox emissions. This is incorrect. They fire at the same time.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: Medlock51]
#2845327
11/12/20 01:43 PM
11/12/20 01:43 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
One plug fires 20 degrees btdc...the second fires 5 degrees atdc to clean up the nox emissions. Why would two plugs be needed for that? Just fire the same plug twice.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: GTSDart340]
#2853240
11/30/20 09:19 AM
11/30/20 09:19 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
One plug fires 20 degrees btdc...the second fires 5 degrees atdc to clean up the nox emissions. Why would two plugs be needed for that? Just fire the same plug twice. dwell time is too short
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 340Cuda]
#2853369
11/30/20 02:39 PM
11/30/20 02:39 PM
Posts: 54 VA Beach, VA
Runnoft
VA Beach, VA
There are several big power turbo builds running 1000+ hp using one plug. Don't some of the heads up series add extra weight on 16 plug engines? The class I race in adds 50lbs to dual plug applications. There are two or three people in the class running a 3rd gen Hemi and they claim it's unfair and would run the same with one plug BUT they haven't tried it yet. I would bet it changes their tuneup -both fuel and timing - and I'm betting power changes too. Just FYI, these are >2000hp engines on methanol.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
[Re: bobby66]
#2861289
12/17/20 01:30 PM
12/17/20 01:30 PM
Posts: 6,018 Morningside
AdventurerSport
waaaay out there in left field
Morningside
Ive seen those, big RB Hemi's with dual distributors, dual plugs.
of course, I've also seen that on other applications, including a 1991 Ford Ranger 2.3L, which had two distributors and two plugs per cylinder on it's 4 cyl engine. Pretty sure that was for emissions, kinda like the new 5.7L Hemi...:)
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
