Page 2 of 3 1 2 3
Re: Stage V 440 to Hemi conversion heads [Re: Rug_Trucker] #282661
04/12/09 02:41 PM
04/12/09 02:41 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yes. Eric at Stage-V also makes his dual in-line 4 barrel manifold for low deck Hemis. I thought that was a really weird thing to do but it does make the Hemi a little narrower so it fits in smaller compartments.
Sometimes in the old days, I thought that Eric just had too much time on his hands. But I have one of his first low deck Hemi manifolds and it looks the same as his others.
Re: Stage V 440 to Hemi conversion heads [Re: Mad_Scientist] #282662
04/12/09 03:37 PM
04/12/09 03:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Would I just be better off to buy a crate Hemi
In a realistic senario?....Yes, while the stage 5 coversion heads were"great" back in their initial release, because Hemi blocks,heads,...generaly Hemi anything was scarce, and expensive.....these heads filled a niche,.......unless you really want something different, there's alot of work ahead of you, and $$$$$ to mount these heads on an RB or B motor.......plus down the road, if you need parts, they might not be available, readily?
you can save the up, and buy into a 426 crate for about $10K........or buy the peices as you can afford them from MP, or other Hemi suppliers, and build your own.........
Re: Stage V 440 to Hemi conversion heads [Re: Mopar_Rich] #282663
04/15/09 04:47 PM
04/15/09 04:47 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
so is there a "KIT" price for everything???
There was a hot rod artical that had a price breakdown a few years ago but I cant find it now.
I mean is it like $6K for everything except for pistons and intake?
and is the stuff available?? Ron...
and Dayclona where can someone get 426 crate for about $10K.. the cheapest I have seen lately is $12,900-$13,100 area do you have a connection
Re: Stage V 440 to Hemi conversion heads [Re: Mopar Ron] #282664
05/05/09 07:29 PM
05/05/09 07:29 PM
Mopar Ron Offline
Mopar Ron  Offline
just bringing this up one more time to see if there is any news on this subject Ron...
Re: Stage V 440 to Hemi conversion heads [Re: Mopar Ron] #282665
05/05/09 08:22 PM
05/05/09 08:22 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
I've always thought a low deck, short stroke hemi with a long rod and a light piston would be fun to build with a big set of twins hanging off the front of it.
Re: Stage V 440 to Hemi conversion heads [Re: Mopar Ron] #282666
05/05/09 08:50 PM
05/05/09 08:50 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
You know, 10 miles up the road from me is the guys that have the SB Mopar Hemi heads.
Never have heard of anyone running those.
Think it is www.rodandcustommachines.com
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Stage V 440 to Hemi conversion heads [Re: Rug_Trucker] #282667
05/05/09 09:16 PM
05/05/09 09:16 PM
Rug_Trucker Offline
Rug_Trucker  Offline
looks like they are gone
Re: Stage V 440 to Hemi conversion heads [Re: JohnRR] #282668
11/25/09 04:48 PM
11/25/09 04:48 PM
I JUST bought a set of these conversion heads from Eric at StageV came with rocker, shaft and stands, No valves or springs. Total package was $3990.00 SO YES these Heads ARE available!!!! SUPER Product!! And it doesnt take a BUNCH of machine work to the block. Most can be done at home with hand tools!! AND ONE MORE THING you can use stock A B or C body motor mounts, You have to grind the front 2 bosses off the block on the drivers and use the top back bolt boss, cut the motor mount as it interfers with the header pipe and weld a strap to the lower section of the motor mount that will bolt to the oilpump for the lower motor mount to hold firm in place, Hope this helps clear things up!!!!
Re: Stage V 440 to Hemi conversion heads [Re: Rug_Trucker] #282669
11/25/09 05:09 PM
11/25/09 05:09 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Their site is down/gone...
Here is the web archive of the small block hemi conversion heads.
http://web.archive.org/web/20070618120907/www.rodandcustommachines.com/smallblockhemiheads.html
Re: Stage V 440 to Hemi conversion heads #282670
11/25/09 05:10 PM
11/25/09 05:10 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Well it's good to see you got a set , the price to get in seems reasonable. Would you be willing to share the final cost after you get it assembled and running ?
These heads might be suited for someone with an RB megablock collecting dust , at least the block would be up to task if someone built one to the heads potential flow .
one thing I just thought about , that's incredibly cheap for the total including the rockers , shafts and stands considering a set of stage 5 rockers for a real gen 2 hemi isn't that cheap ... for just the rockers alone .... maybe I shouldn't have sold that megablock I had after all ???
Re: Stage V 440 to Hemi conversion heads [Re: JohnRR] #282671
11/25/09 05:39 PM
11/25/09 05:39 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
For those unaware, these are not a super simple bolt on, they require some block work that has to be done right. The rotating assembly will be custom to, no kits currently available will fit them. The oiling system will almost have to be an external one, and you will need a bigger pan. The heads will hold a lot of oil up top, and it can drain a stock pan in a hurry.
Also, because your using a 440 block, its weaker because its not cross bolted. You might not think that's an issue until you bolt on heads that flow in the neighbor hood of 400cfm and the thing revs like a prostock engine. So now you have this big stroker kit in the block that revs like wicked in a less than appropriate block.....Thoughts to be considered when going down that path!
Hmmmm...sounds like there are a few other things that i didnt think about when considering those heads.
Waaaay too much to change just to run those heads.
A person would be better off just buying a real Hemi block and regular Hemi heads since all those changes would need to be done.
WINNER ding ding ding ... WINNER ... ding ding ding ...
It would be way easier to start with a Hemi block.
From what I understood from the original post he was hoping to bolt the Stage V Hemi heads onto an already built wedge short block.
That would never work, wrong pistons.
Starting from scratch with a Hemi block would be far simpler.
Re: Stage V 440 to Hemi conversion heads [Re: Mad_Scientist] #282672
11/25/09 07:59 PM
11/25/09 07:59 PM
JohnRR Offline
JohnRR  Offline
How many people have these heads and what did you have to do to your block to make them fit? Is it feasible to make the modifications to an assembled short block, or are we talking major machine work? How was the pricing? Would I just be better off to buy a crate Hemi?
Current setup is a mild 440 that is set up for street use, but I really want a Hemi instead.
Stage V
I missed that the first time around , no it's not fesible to to the machine work to an assembled shortblock and what do you mean by ASSEMBLED , you already have a set of HEMI pistons in it or where you thinking you could put these on a 440 type build short block ? definitely NOT , with a flat top piston if you even had 7.0 compression I'd be surprised . Hemi combustion chamber runs about 170cc, never mind the valves would probably hit the pistons because the valve reliefs aren't anywhere where they need to be ...
Re: Stage V 440 to Hemi conversion heads [Re: camdog440] #282673
11/25/09 08:39 PM
11/25/09 08:39 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Interesting they had a Dickson TN phone number with a Knoxville address over 200 miles between the two locations.
Re: Stage V 440 to Hemi conversion heads [Re: Mad_Scientist] #282674
11/26/09 02:18 AM
11/26/09 02:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I talked to them about 15 years ago, considering the conversion also, but is was expensive I think over $5K, and I thought you had to drill and tap the head bolt holes for 1/2" bolts? I also think they required external oil return lines to the oil pan?
Re: Stage V 440 to Hemi conversion heads [Re: 451Mopar] #282675
11/26/09 02:33 AM
11/26/09 02:33 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
A buddy of mine has a set of the Stage V conversion heads installed on a (get this) 440 that was sleeved back down to a 426.
It was built back in the early 90's.
Yes there are external oil drain back on the corners of the cylinder heads.
I don't think the head bolt size was increased, but I could be wrong.
The ones that are usually studs at the top use allen bolts through the intake port with a plug from the top if I remember right.
He's the king of "different" combination's.
His 16 plug Hemi Dart used to run a de-stroke crank that made it 396ci. After blowing up the Frankenstein motor enough he finally built it to a 472ci.
Re: Stage V 440 to Hemi conversion heads [Re: Mad_Scientist] #282676
11/26/09 03:28 AM
11/26/09 03:28 AM
Stage V
Buy one of the new World Hemi blocks and get a real Hemi, not a wedge block with a set of adapt a heads on it
Re: Stage V 440 to Hemi conversion heads [Re: Cab_Burge] #282677
11/26/09 09:56 AM
11/26/09 09:56 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Re: Stage V 440 to Hemi conversion heads [Re: CRE2004] #282678
11/26/09 11:30 AM
11/26/09 11:30 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I thought of a 472 or 451 hemi-headed low deck for my 68 Formula S, but the intake & headers were the limiting factors. The 400's a strong block & w/a stud girdle & aftermarket caps, should be able to take mucho power. Would probably save 50 lbs or so over the 440 block. I remember Eric sent me an email last yr & w/ rocker gear, I think the bill was slightly over $5K.
Re: Stage V 440 to Hemi conversion heads [Re: Cab_Burge] #282679
11/26/09 11:33 AM
11/26/09 11:33 AM
Well considering a new world block is $3500.00 VS a used 440 block for $100.00 (which is good to 800 HP) without 4bolt mains You are already $3400.00 ahead. Real hemi heads (bare) with rocker assemblies are $3500.00 bare minimum. for a total of $7000.00 for a real hemi. for $4100.00 You can have a 440 with hemi heads. And about pistons, You can get ROSS ARIAS or JE in 4.350 which is .100 over 426 off the shelf piston. Total cost of a 440 wedge conversion is about $8000.00 HALF of what a real hemi crate motor is. The 440 ends up a 446 cu in. without stroking it and will make WAY more HP the a crate hemi. For those who are curious, go to "Converting a Wedge into A Hemi" on google or yahoo. This explains all the block work that is needed. Nothing major, most can be done at home with hand tools.
Re: Stage V 440 to Hemi conversion heads [Re: 451Mopar] #282680
11/26/09 11:43 AM
11/26/09 11:43 AM
JohnRR Offline
JohnRR  Offline
I remember reading about it so I'm trying to figure out how the price went down for these ???
Page 2 of 3 1 2 3
