Re: Mounting a fuel pump
[Re: mopar dave]
#2825821
09/27/20 08:36 PM
09/27/20 08:36 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Didn't know it was safe to put them in the trunk. It's probably safer in the trunk than hanging way down under the car where road debris and other bumps can knock it off ![work work](/ubbthreads/images/graemlins/custom/work.gif) Mine's in the spare tire well under the fuel cell.
[Re: mopar dave]
#2825852
09/27/20 10:26 PM
09/27/20 10:26 PM
Posts: 1,108 Massillon, Ohio
cudatom
Massillon, Ohio
Mine is a little above the outlet. The pump instructions suggested a 12qn line to pump and 10an out of the pump. I spoke to manufacture of the pump and they asked ho from the tank. Advised 16". Was told no problem.
As far as leaks my trunk pan under the fuel cell is not sealed(fuel sometimes can get spilled when filling a tank) so noticing a leak is not a problem. I would see it just as easy as if it was mounted underneath.
Ok
[Re: mopar dave]
#2825928
09/28/20 08:34 AM
09/28/20 08:34 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
FWIW...I don't think I've ever mounted one that was below the fuel level on my own cars. I always use the inner rear frame rail on the passenger's side. Never had a problem yet. Holley blue, Aeromotive street rod pump, and my current Aeromotive A1000.
[Re: an8sec70cuda]
#2825975
09/28/20 10:51 AM
09/28/20 10:51 AM
Posts: 16,556 On the run…
BloFish
On the run…
I put mine in the trunk as well.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2825997
09/28/20 11:59 AM
09/28/20 11:59 AM
Thumperdart
State of confusion
Race only or street because I would think that pump would get hot as hell in the trunk w/no air circulation.....
[Re: Thumperdart]
#2826003
09/28/20 12:16 PM
09/28/20 12:16 PM
BloFish
On the run…
Both. I have never had it get hot. I open my trunk to inspect things over before I fire it up after sitting for any length of time.
[Re: BloFish]
#2826016
09/28/20 12:51 PM
09/28/20 12:51 PM
Posts: 19,403 Las Vegas
Al_Alguire
Las Vegas
My Valiant was in the trunk and no issues. My Camaro is the same and it is a street car that sees the strip sparingly.
[Re: Al_Alguire]
#2826243
09/28/20 08:09 PM
09/28/20 08:09 PM
Thumperdart
State of confusion
Good to know cos my Mag 300 is a hot sucker after driving and it's in the wind outside.....
