Lightbulb differences between 3057 and 3157? #2822762
09/19/20 10:05 PM
09/19/20 10:05 PM
Cab_Burge Offline OP
I own a 2006 Ram 3500 4 door long bed, I notice two of the tail light brake lights and turn signal bulbs weren't burning correctly so I removed them to replace them and found one # 3057 in one socket and one 3157 in the other on the passenger side, the driver side had two 3057 in both sockets confused
I'm wonder why confused
My owner manual calls for 3057 in both tail lights, brake lights and turn signal sockets shruggy
Any one know the differences in them help
Thanks in advance for any help on this up
Cab
Re: Lightbulb differences between 3057 and 3157? [Re: Cab_Burge] #2822865
09/20/20 11:09 AM
09/20/20 11:09 AM
N
NITROUSN Offline
NITROUSN  Offline
N
3157 is slightly brighter on the park filament. Why they make so many is just confusing. I would use what it calls for. Most people find a bulb that fits and plug it in.
Re: Lightbulb differences between 3057 and 3157? [Re: NITROUSN] #2822900
09/20/20 01:05 PM
09/20/20 01:05 PM
5thAve Offline
5thAve  Offline
I think that's the same bulb my GMC uses. When one burnt out earlier this year the only one I could find in the store was the opposite as what it came with but it worked with no problems.
The factory bulb had double filaments on the same post on one side but there was no visual difference when it was lit.
Re: Lightbulb differences between 3057 and 3157? [Re: 5thAve] #2823508
09/22/20 02:24 AM
09/22/20 02:24 AM
I did a little research on them, as already said they are near the same and will fit in the tail lights and turn signals on my truck, the 3157 uses a little more current so it is a tiny bit brighter up
I'll stick with the 3057 OEM bulbs for now up
