Page 3 of 3 1 2 3
Re: results of added compression to 511 [Re: Bad340fish] #2780379
06/01/20 03:34 PM
06/01/20 03:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What I learned at Pettis Performance years ago was that going from say 9.5 to 11.5 comp. made way more power than going from 12.1 to 14.1 fwiw. On another note however, I have a customer w/a 3450 lb Chevelle on 93 pump gas w/a 572 at 11.7 comp. that went a best of 8.84 at 151 w/a 2-circuit cast 1250 Dommy..........
Re: results of added compression to 511 [Re: Thumperdart] #2780457
06/01/20 06:15 PM
06/01/20 06:15 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Yes, it does work that way. The compression scale is shaped like a pyramid.
Re: results of added compression to 511 [Re: JD Dart] #2780597
06/02/20 09:15 AM
06/02/20 09:15 AM
Mt Morris Michigan
Mt Morris Michigan
He may get away with 11.5 on pump gas and run a whole lot better.
Re: results of added compression to 511 [Re: Bad340fish] #2780600
06/02/20 09:21 AM
06/02/20 09:21 AM
Mt Morris Michigan
Mt Morris Michigan
I think that's extremely lucky with 10:1 from what I have seen. Maybe you just have real good cylinder heads with high velocity ports? My old 408 went 10.38@131 on 11.25:1 at 3300# with a 268@50 roller.
Re: results of added compression to 511 [Re: mopar dave] #2822567
09/19/20 12:06 PM
09/19/20 12:06 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I just ran my 10.5:1 512 out at milan Wednesday. Car didn’t hook with the 6 year old drag radials. I gotta think it’s 3450 with me in it. All steel 69 dart except for the hood and front bumper. First time out with this combo, I have some work to do. I did make some other better passes earlier in the evening but the timing system was down. I think it’s more about combo than anything.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: results of added compression to 511 [Re: 68 HEMI GTS] #2822590
09/19/20 01:22 PM
09/19/20 01:22 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looks like there’s a “9” in it with some tires.
That’s Andy’s old cam, right?
Re: results of added compression to 511 [Re: fast68plymouth] #2822599
09/19/20 01:38 PM
09/19/20 01:38 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
it is, runs super hard!! Is that one of your grinds?
Re: results of added compression to 511 [Re: 68 HEMI GTS] #2822605
09/19/20 01:49 PM
09/19/20 01:49 PM
So. Burlington, Vt.
So. Burlington, Vt.
If it’s the 264/268-108....... then yes, it is.
Re: results of added compression to 511 [Re: fast68plymouth] #2822612
09/19/20 02:00 PM
09/19/20 02:00 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I thought I might be, damn good running cam.
Re: results of added compression to 511 [Re: 68 HEMI GTS] #2822614
09/19/20 02:08 PM
09/19/20 02:08 PM
I was very please with a Comp Cams solid roller similar to this one, it ran really good in my old pump Gas Duster good, 9.993 at 134.7 MPH through a complete to the rear bumper 3 inch exhaust system and air cleaner on at 3450 Lb. with me in it cork up up boogie
Re: results of added compression to 511 [Re: Cab_Burge] #2822644
09/19/20 03:20 PM
09/19/20 03:20 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Nice results definitely started making steam in 2nd half of the track
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: results of added compression to 511 [Re: 68 HEMI GTS] #2822693
09/19/20 06:57 PM
09/19/20 06:57 PM
Mt Morris Michigan
Mt Morris Michigan
Nice and congrats. Runs great on pump gas. What's the duration at .200 and what's the lobe lift on that cam? Thanks
Re: results of added compression to 511 [Re: mopar dave] #2822696
09/19/20 07:06 PM
09/19/20 07:06 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Thanks! I also had a mismatched wood carb spacer on it just to keep heat off the carb. Need to find one that fits the cloverleaf.
Re: results of added compression to 511 [Re: 68 HEMI GTS] #2822701
09/19/20 07:13 PM
09/19/20 07:13 PM
Mt Morris Michigan
Mt Morris Michigan
Re: results of added compression to 511 [Re: mopar dave] #2822830
09/20/20 09:35 AM
09/20/20 09:35 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Very nice improvement and congrats on the new bests! Did you change pistons for the compression increase?
2 kids and a dog
Re: results of added compression to 511 [Re: TonyS451] #2822870
09/20/20 11:25 AM
09/20/20 11:25 AM
Mt Morris Michigan
Mt Morris Michigan
No, i shaved the heads .45" i think. I will take off more next time they come off. It loves compression. No more pump gas motors for me, unless its E85.
Re: results of added compression to 511 [Re: mopar dave] #2823460
09/21/20 09:40 PM
09/21/20 09:40 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
You will love it punkrocka
Re: results of added compression to 511 [Re: mopar dave] #2823568
09/22/20 10:39 AM
09/22/20 10:39 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
e85 is awesome. I've been running it for years on my small block street/race car. 13:1 compression Eddy head motor, runs 10.19 at 130. If I recall corretly, my car picked up a little over a tenth when I made the switch to e85 on my old 10.8:1 compression small block.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Page 3 of 3 1 2 3
