Page 2 of 3 1 2 3
Re: Out with the old. [Re: T-bar] #2822138
09/18/20 05:43 AM
09/18/20 05:43 AM
Queensland,Australia
T-bar Offline OP
T-bar  Offline OP
Got an update. Motor is in, headers and full exhuast done. Had it on a hub dyno and had lean issues with the 1050 we had converted to E85 seems we couldn't get to run rich enough so we got a new billet 1250 from APD speced to the motor. It didn't work out really right so with another conversation with APD we got it sorted. 900 hp to the hubs on E85 through full 4" exhuast system with an x pipe to th er back bumper.
Re: Out with the old. [Re: T-bar] #2822141
09/18/20 06:17 AM
09/18/20 06:17 AM
AndyF Offline
AndyF  Offline
Yeah I can imagine that a single carb which feeds 1000 hp worth of E85 isn't going to be off the shelf! I'm surprised you even found a single carb that was up to the task. The needle and seats must be the size of a garden hose. Surprised you didn't go with EFI. High pressure fuel injection would make it easier to feed that much fuel.
Re: Out with the old. [Re: AndyF] #2822146
09/18/20 06:50 AM
09/18/20 06:50 AM
T-bar Offline OP
T-bar  Offline OP
I did think of injection but went carb way. Quite a bit of playing with the new carb to get it right. Couldn't get it to run without being lean. Kept putting fuel into it and still with 178 jets in the front and 198 in the back and still couldn't get it under 13.6 afr's. We looked at the fuel pump thinking it wasn't keeping up but did couple of different tests and that wasn't it. Put the pressure at the regulator up to 12 psi from 6 and that actually helped but not enough. Took the info back APD and they said convert it over to a 3 circuit and that fixed it, dropped the jets right down and could get the afr's a lot better but it doesn't like being too rich drops a bunch of power.
Re: Out with the old. [Re: T-bar] #2822169
09/18/20 09:28 AM
09/18/20 09:28 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Any pic's of the said street car?
Re: Out with the old. [Re: T-bar] #2822248
09/18/20 01:02 PM
09/18/20 01:02 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Those aren't jets..............those are pipe fittings. up
YOWZA !!
Re: Out with the old. [Re: tubtar] #2822348
09/18/20 05:42 PM
09/18/20 05:42 PM
T-bar Offline OP
T-bar  Offline OP
The air cleaner is out the top now
Re: Out with the old. [Re: T-bar] #2822350
09/18/20 05:53 PM
09/18/20 05:53 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice ride up
Looking forward to a track report.
Re: Out with the old. [Re: fast68plymouth] #2822416
09/18/20 08:44 PM
09/18/20 08:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Nice ride. Can't even imagine jumping through hoops to get this type of build done in Australia. Very impressive.
Doug
Re: Out with the old. [Re: T-bar] #2822427
09/18/20 09:15 PM
09/18/20 09:15 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Sweet ride ride man smoke And to think 900 horses to the hub Wow.
Re: Out with the old. [Re: racerx] #2822462
09/19/20 12:07 AM
09/19/20 12:07 AM
T-bar Offline OP
T-bar  Offline OP
Thanks everyone for their comments on the car. Getting the engine built and over here was pretty easy especially with Tom the original owner was awesome to deal with and did a lot of leg work to get the deal done. Next steps will be to get it teched then to the track.
Re: Out with the old. [Re: T-bar] #2822466
09/19/20 12:23 AM
09/19/20 12:23 AM
AndyF Offline
AndyF  Offline
Yeah a three circuit will dump fuel in like a fire hose. Okay for drag racing but you'll never want to drive on the street at part throttle with a three circuit! The engine will flood big time.
Re: Out with the old. [Re: T-bar] #2822480
09/19/20 04:45 AM
09/19/20 04:45 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Top job fella up Looks the dogs mate cool Got any pics of the engine bay / headers ? beer
Re: Out with the old. [Re: Tig] #2822481
09/19/20 04:46 AM
09/19/20 04:46 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Beautiful car and engine! I'll be looking forward to the track results.
Wow, dream build.
Re: Out with the old. [Re: ProSport] #2822752
09/19/20 09:34 PM
09/19/20 09:34 PM
T-bar Offline OP
T-bar  Offline OP
Re: Out with the old. [Re: T-bar] #2822757
09/19/20 09:53 PM
09/19/20 09:53 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Is this car caged?
Re: Out with the old. [Re: racerx] #2822771
09/19/20 10:32 PM
09/19/20 10:32 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Wow Tig, this is the first I have seen of this thread! I've been feeling like kind of an outcast here since I went with brand X. Your installation looks bad a$$ and I am sure you will get into the 8's with some chassis tuning. I would love to come visit and watch you smoke the competition. That wasn't my fastest Predator, but it was the best. I must say, it looks happy in the Cuda. I always wanted one of those! Keep us posted.
Re: Out with the old. [Re: camastomcat] #2822786
09/19/20 11:47 PM
09/19/20 11:47 PM
T-bar Offline OP
T-bar  Offline OP
Could not of got this far without your help Camastomcat. Yes it does have a cage that cert to 8.0. I think i have to the power to run in the high 8's but will take a bit of work with leaf springs and 275 radials but thats how i want to do it.
Re: Out with the old. [Re: T-bar] #2822832
09/20/20 09:37 AM
09/20/20 09:37 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Cool Good Luck up
Re: Out with the old. [Re: racerx] #2824351
09/23/20 10:28 PM
09/23/20 10:28 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Are you trying to take the Cuda out this weekend Tig?
Re: Out with the old. [Re: camastomcat] #2824400
09/24/20 03:18 AM
09/24/20 03:18 AM
T-bar Offline OP
T-bar  Offline OP
I took the car out Sunday arvo for a cruise and had cooling issues, but i do only have 2 x 10" fans so I'll try 2 x 12" fans and try them. I"ll be a few weeks off getting it to the track due to work commitments
Page 2 of 3 1 2 3
