Re: Header wrap on ceramic headers,
[Re: MoonshineMattK]
#2823265
09/21/20 12:56 PM
09/21/20 12:56 PM
Posts: 20,440 north of coder
moparx
as the tubes on several pipes are rusted at the flanges, i would suspect the rust, at minimum, has migrated several inches past where the wrap starts. it would be interesting to view what those tubes look like today under the wrap. i am not a fan of that wrap, just for the rust reason alone. double wall tubes being wrapped is another subject altogether, however.
#2823269
09/21/20 01:00 PM
09/21/20 01:00 PM
Posts: 23,410 Here
jcc
Here
Maybe I'm lucky. Set of hooker headers on my charger for over 25,000 miles and over 15 years. Wrapped from day one and no issues yet. This is a mild 440 Best then to never remove the wrap, you may not like what you find. Another telling sign that your situation might be different, and you didn't mention, but wrap, from my experience seldom lasts 25,000 miles. If you mean have I re-wrapped the headers the answer is no. Same wrap. Its a mild combination and the engine has not been apart since installing it. Well the, I might agree with your luck suggestion.
"When one’s appeal is emotional, it does not matter if there is no substance."
[Re: moparx]
#2823532
09/22/20 08:18 AM
09/22/20 08:18 AM
Posts: 724 Lake Villa Il
INTMD8
Lake Villa Il
as the tubes on several pipes are rusted at the flanges, i would suspect the rust, at minimum, has migrated several inches past where the wrap starts. it would be interesting to view what those tubes look like today under the wrap. i am not a fan of that wrap, just for the rust reason alone. double wall tubes being wrapped is another subject altogether, however. Double wall tubes? Do you mean like marine headers with water cooling?
[Re: INTMD8]
#2824138
09/23/20 02:47 PM
09/23/20 02:47 PM
moparx
as the tubes on several pipes are rusted at the flanges, i would suspect the rust, at minimum, has migrated several inches past where the wrap starts. it would be interesting to view what those tubes look like today under the wrap. i am not a fan of that wrap, just for the rust reason alone. double wall tubes being wrapped is another subject altogether, however. Double wall tubes? Do you mean like marine headers with water cooling? i was thinking of double wall motorcycle pipes. just basically a pipe over a pipe. i never gave marine headers a thought. good point you bring up.
[Re: migsBIG]
#2824529
09/24/20 12:16 PM
09/24/20 12:16 PM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
I use black VHT Hi-temp spray paint on my headers. Looks great, is cost effective, last for years and I can touch them up when needed with ease.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
