Page 2 of 3 1 2 3
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820875
09/14/20 11:31 PM
09/14/20 11:31 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
that just happened to my car last weekend .
not sure what the cause was ?
same motor been together sence 1986
maybe fuel pump ?
only have stock breathers / vale covers .
replaced dist cap , cleaned carb, replaced valley pan car runs but not like it should ! vac and idle not steady like it was before backfire .
Re: Valley Pan Inverted [Re: 3hundred] #2820876
09/14/20 11:36 PM
09/14/20 11:36 PM
New Jersey, U.S.A.
FuriousMopar1968 Offline OP
New Jersey, U.S.A.
The breather locks were bent and it is very loose/wiggly now in the tower. So it’s possible if it was just a push in it might of done that, but the pressure did have to make it through the cover baffle first too. First thing in the path is that valley pan and it’s got a lot of surface area, but I really have No idea haha.
1968 Plymouth Fury - 440 Dual Quad Tunnel Ram
Re: Valley Pan Inverted [Re: calrobb2000] #2820877
09/14/20 11:37 PM
09/14/20 11:37 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
That’s the odd thing I thought I’d see some lack of performance after, but it’s still a ball of fire. Did you compression test it?
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820899
09/15/20 12:49 AM
09/15/20 12:49 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
have not did comp test yet .
gona do all the easy stuff first ecu, dist change out ect as heders will be blocking some plug acces .
happened on race day 2 time runs at 109 mph, eliminations 1 st round big backfire with smoke out all sides of hood and filled driver compartment then suddenly takes off and runs 108 mph ?
3/4 sec. off my dial ?
now not running normal and exhaust not sounding right ???
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820916
09/15/20 03:17 AM
09/15/20 03:17 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Originally Posted by FuriousMopar1968
Do you think I should open up the flap on bottom and lose the baffle?
I always opened the slits in the breathers all the way to 90° on my dual 4bbl 383. Never had a valley pan grow into a hill pan.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Valley Pan Inverted [Re: hp383] #2820993
09/15/20 10:38 AM
09/15/20 10:38 AM
New Jersey, U.S.A.
New Jersey, U.S.A.
Yeah I think I’m just gonna open up the breather/baffles and run it. From what I hear I may have been somewhat lucky, though I do think I want to limit my Revs going forward haha. Does anyone know of a Rev Limiter set up that works with the orange box and OEM style Mopar Distributer? It definitely winds to quick for me to mechanically regulate with the 4.10 rear she’s got.
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821001
09/15/20 10:45 AM
09/15/20 10:45 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
There's a cpuple companies that make an ignition box with a rev limiter built in.
FBO is one, Rev-n-nator is another.
Re: Valley Pan Inverted [Re: calrobb2000] #2821023
09/15/20 11:46 AM
09/15/20 11:46 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Originally Posted by calrobb2000
hi
If it has cast pistons I would be looking for broken ring lands on the pistons.
Re: Valley Pan Inverted [Re: hp383] #2821058
09/15/20 12:47 PM
09/15/20 12:47 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Do you know if the Rev N Nator is still being made? It says out of stock on the site unfortunately. The issue with the FBO is that it doesn’t have the ability to limit lower than 5200 RPM. Does anyone know if the “Pertronix 600 Digital Rev Limiter” would work inline with the orange box?
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821102
09/15/20 01:56 PM
09/15/20 01:56 PM
On your deal having excessive crankcase pressure I would do a leak down test also now to see if it is possibly ring seal, especially after doing a good compression test twocents scope
Crankcase pressure ( a lot of it) is the only thing that will cause that to happen, invert the intake valley pan shruggy
Re: Valley Pan Inverted [Re: Cab_Burge] #2821110
09/15/20 02:15 PM
09/15/20 02:15 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
A Crankcase Evacuation System before the mufflers will do that also ! LOL
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821111
09/15/20 02:16 PM
09/15/20 02:16 PM
AndyF Offline
AndyF  Offline
A long time ago (high school actually) I installed a new set of valve covers on my car. The valve covers did not have breathers and I didn't think anything of it since that was how they came. The valley pan looked like a microwave popcorn bag after driving the car.
Engines build a fair amount of pressure in the crankcase, even if the rings are in good shape. It is fairly common to see engines push the dipstick out or push breathers off at WOT.
Re: Valley Pan Inverted [Re: AndyF] #2821123
09/15/20 02:42 PM
09/15/20 02:42 PM
My 1963 Plymouth 415 HP M.W. with 25,000 miles on the original pistons would push one or both stock breather caps off on almost every run, I ended up having them safety wire on so I didn't lose them after several times of having them fall onto the track during a run shock realcrazy
Re: Valley Pan Inverted [Re: SIKPUP] #2821124
09/15/20 02:44 PM
09/15/20 02:44 PM
AKA as a crankcase pressure system with mufflers on whiney shruggy
Re: Valley Pan Inverted [Re: Cab_Burge] #2821126
09/15/20 02:50 PM
09/15/20 02:50 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Hey every bit of change is useful to me with this issue haha. Thanks everyone for you help with this! Unfortunately there’s no access to air at the unit it’s at so it’s gonna be difficult to perform a leak down on her, and on top of that it’s not Insured/reg’d since it’s been sitting for over a year thinking I had a blown engine. Wouldn’t the grade A compression readings indicate good ring sealing?
Re: Valley Pan Inverted [Re: Cab_Burge] #2821130
09/15/20 02:54 PM
09/15/20 02:54 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Also she’s running single chamber Super 10 Flowmasters, do you think a Crankcase Evac to the header extensions would still build too much pressure? Those are barely even mufflers haha.
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821159
09/15/20 04:13 PM
09/15/20 04:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Why would you want a limit lower than that?
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821165
09/15/20 04:27 PM
09/15/20 04:27 PM
GomangoCuda Offline
GomangoCuda  Offline
Any rev limiter that says it will work with an inductive ignition will work. MSD 8728 is an example but a bit pricey. There should be others still available. Just don't get one that is made for any kind of CD ignition.
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2821168
09/15/20 04:37 PM
09/15/20 04:37 PM
GomangoCuda Offline
GomangoCuda  Offline
no
Re: Valley Pan Inverted [Re: GomangoCuda] #2821171
09/15/20 04:39 PM
09/15/20 04:39 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
I’d have it set to 4000ish RPM as a right foot limiter during break in process haha. Its all to easy to go light years past that just cruising with the low rear it has in it. Going 65mph on the highway on my way to work it would be spinning 3500 RPM, one accidental down shift from partial throttle kickdown and it would scream immediately. I know this current engine is already broken in, but in the worse case of something failing I want to not worry about the next one.
Page 2 of 3 1 2 3
