Re: 250lbs of oil pressure, imposible?
[Re: DrCharles]
#2819996
09/12/20 02:45 PM
09/12/20 02:45 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Absolutely possible. I would think it would need more shim than that but Buddy of mine built a 440 many moons ago that only made 5 psi so he shimmed the pump up nearly solid. Still 5 psi. Discovered he forgot to put a plug back in and fixed it. Didn't take the shims out of the pump... Fired it up and the Lee Eliminator oil filter came out from under the front of the car like a rocket with 7 quarts of Valvoline Racing 50 right behind it. He said it instantly pinned the Stewart Warner gauge. Kevin
[Re: Twostick]
#2820009
09/12/20 03:59 PM
09/12/20 03:59 PM
fast68plymouth
So. Burlington, Vt.
I doubt I’d believe it unless it happened to me........ but I had a metal shaving get caught in the relief valve in my 340....... stuck totally closed. 125psi hot idle, 275psi at rpm.
[Re: dvw]
#2820015
09/12/20 04:53 PM
09/12/20 04:53 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
I've had the luck to buy at least three new Seal Power, maybe they where Speed Pro brand standard, maybe high volume, to many years ago to remember now, oil pumps that had the solid sided 440 bypass valve in them instead of the SB one with the holes in the sides Let us know what you find to fix it I drill a small hole in the cup and then a #8 sheet metal screw in that hole to pull the cup to find out if it was stuck and learned that they had the wrong valve in them from the factory
[Re: dvw]
#2820045
09/12/20 06:42 PM
09/12/20 06:42 PM
Posts: 4,210 New York
polyspheric
New York
I would guess 250 would expel all the gallery plugs.
Boffin Emeritus
[Re: dvw]
#2820051
09/12/20 07:28 PM
09/12/20 07:28 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
My first 440 build would idle 75 hot and peg a 150psi guage. I ran the black mp filters to keep them from blowing off. I put at leak 5k hard miles on it like that. It never went over 6500 and i ran an extra quart for good measure.
250psi...I am impressed lol
[Re: dvw]
#2820227
09/13/20 01:41 PM
09/13/20 01:41 PM
Posts: 19,591 north of coder
moparx
I'm a dumb ass. I assembled this pump about 9 months age. Just looked at a google pic of a pump. The service manual pic sucks. I put the core plug in backwards. The plug in that position depressed the spring approximately 1/4" + .100" shim. The spring is tensioned about 3/8" deeper than the factory position. Been doing this stuff 40 + years and still find ways o make mistakes. Fortunately I'm still smart enough not to start it until the issue is resolved. Doug don't feel bad. i did the same thing on a 2.2 engine one time. those have the same pump relief spring as a small block. when i fired it up, the wix filter [the 51515 standard size] and almost all the oil got pumped onto the ground. not sure why i put the cup in backward, but i did, and i had a 1/4" shim with it, so a MESS it made. oil pressure gauge was pegged WAY past high.
[Re: dvw]
#2820579
09/14/20 12:42 PM
09/14/20 12:42 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Thank you for following up and closing the loop.
If for some reason anyone ever asks what will happen with a 3/8" shim, we know the answer to that question!
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2820597
09/14/20 01:28 PM
09/14/20 01:28 PM
Posts: 9,871 MI, usa
dvw
MI, usa
1/2" Milwaukee. The part that surprised me is that the drill could possibly produce enough speed to provide enough volume to require the relief to even need to open. Doug
