Re: Question on L2295F Pistons and 440 Source Stealth Heads [Re: moparx] #2822240
09/18/20 12:39 PM
09/18/20 12:39 PM
New Jersey, U.S.A.
FuriousMopar1968 Offline OP
New Jersey, U.S.A.
Originally Posted by moparx
i'm just guessing here, but i don't ever recall seeing a radiator cap with a pressure release lever having the double seal necessary for use in a recovery system.
does the overflow tube shown in your picture exiting to the drivers side of the filler neck run under the radiator and enter the overflow container from the bottom ?
beer
Yeah it’s ran very similarly to that, also that’s how I had a 383 ran & slant 6 as well. Red flags? Also where do you think the combustion gas could be coming from?
1968 Plymouth Fury - 440 Dual Quad Tunnel Ram
Re: Question on L2295F Pistons and 440 Source Stealth Heads [Re: FuriousMopar1968] #2822436
09/18/20 09:46 PM
09/18/20 09:46 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Blown head gasket or cracked head would be the most common source of combustion gas in the coolant. A cracked or pitted cylinder wall would likely drive oil into the coolant too so if the coolant is clean, not a likely source.
I didn't think a domed piston worked at all with a closed chamber head.
I think you'd be better off to find a piston with a CH that puts it as close to zero deck as possible and machine the block to square and zero it. .039 head gasket would set your quench perfectly.
Sounds like you're keeping the stock rods so you might even find a flatop hypereutectic cast piston that would accomplish that economically.
Kevin
Re: Question on L2295F Pistons and 440 Source Stealth Heads [Re: FuriousMopar1968] #2823021
09/20/20 07:31 PM
09/20/20 07:31 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Originally Posted by FuriousMopar1968
Once I get a chance to run the car again I’ll try to capture it on video and link it, it’s a very odd/confusing thing to see.
Here’s the chugging upper radiator hose and a possible valve train tick/knock.
- https://youtu.be/6lEKE8GadIM
- https://youtu.be/3udE4xoeF_I
Re: Question on L2295F Pistons and 440 Source Stealth Heads [Re: Twostick] #2823197
09/21/20 10:09 AM
09/21/20 10:09 AM
New Jersey, U.S.A.
New Jersey, U.S.A.
I’m going to start a new thread about the coolant and engine noise issues since it’s kinda off topic, thanks for everyone’s input on the L2295 and Stealth Head question!
Here’s the new thread: https://board.moparts.org/ubbthread...upper-rad-hose-chugging.html#Post2823199
