2004 Ram 2500 O2 Sensors & Exhaust Manifolds (FIXED)
#2820004
09/12/20 03:29 PM
09/12/20 03:29 PM
Posts: 2,373 White Plains, NY
VCODE
White Plains, NY
I have a nice 2004 Ram 2500 5.7 120K miles on it, which I only use for towing my 24ft trailer. Are these 5.7 Hemi's prone on having bad O2 sensors. The check engine light always on. I have changed Senors a few years ago. That only worked for a short time. Is something messing up my senors. I just changed the Spark plugs today. The right bank look great maybe a little lean, the left bank are running rich. The gas mileage is down a bit also. About 7.5 miles to the gallon with the trailer and Cuda. Anyone have troubles with this before Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 2004 Ram 2500 O2 Sensors
[Re: NITROUSN]
#2820034
09/12/20 06:07 PM
09/12/20 06:07 PM
VCODE
White Plains, NY
I know, I did not get codes yet. Bob
[Re: gtx6970]
#2820145
09/13/20 08:07 AM
09/13/20 08:07 AM
VCODE
White Plains, NY
Yep, Need the codes there Bob .
Or else anything is a guess
BUT, best I remember they're not known for repetitive O2 sensors failures Did you use OEM sensors or aftermkts Bill, actually it was done at the Dealer. So they must have been Mopar one's I was thinking there is also a small exhaust leak on the right bank. I do not use the trunk much. I will get codes next week Thanks Bob
[Re: VCODE]
#2820759
09/14/20 07:55 PM
09/14/20 07:55 PM
Posts: 21,405 It's a dry heat
gtx6970
It's a dry heat
BUT, best I remember they're not known for repetitive O2 sensors failures Did you use OEM sensors or aftermkts Bill, actually it was done at the Dealer. So they must have been Mopar one's I was thinking there is also a small exhaust leak on the right bank. I do not use the trunk much. I will get codes next week Thanks Bob Not uncommon for dealers to use aftermkt parts. So dont count on they did use OE Ps. Exhaust leak will cause o2 sensor issues
[Re: gtx6970]
#2820975
09/15/20 09:43 AM
09/15/20 09:43 AM
VCODE
White Plains, NY
BUT, best I remember they're not known for repetitive O2 sensors failures Did you use OEM sensors or aftermkts Bill, actually it was done at the Dealer. So they must have been Mopar one's I was thinking there is also a small exhaust leak on the right bank. I do not use the trunk much. I will get codes next week Thanks Bob Not uncommon for dealers to use aftermkt parts. So dont count on they did use OE Ps. Exhaust leak will cause o2 sensor issues Bill, I have found out that most if not all 5.7 hemi engines have this problem with the exhaust manifolds warping and breaking the bolts. Well after looking that is exactly what's wrong with mine.Rich spark plugs on the left side and lean spark pugs on the right side where it is leaking. I am going to get new Mopar gaskets, dorman bolt kit and have the original manifolds resurfaced to correct that problem. I think this will fix all of my issues. Thanks Bob
[Re: J_BODY]
#2821924
09/17/20 02:50 PM
09/17/20 02:50 PM
VCODE
White Plains, NY
I probably do 2-3 5.7 broken exhaust studs a week.... if your lucky it snaps near the top instead of even with the head. I’ve been using a step drill bit to hog out the holes on the sealing side of the manifold on the end ports. I also put a generous bead of copper rtv around the end ports on the gasket. Knock on wood I haven’t had a comeback doing it this way. I just purchased the Mopar gaskets,bolts and nuts. $250.00 with my discount. I am going to have the old manifolds resurfaced if out of spec before putting them back on. I got the Mopar gaskets which are a few layers thick. So you enlarge the inside end holes of the manifold to release some pressure on it. It looks like my right rear broke at the top of manifold but not sure yet. Thank Bob
[Re: VCODE]
#2823669
09/22/20 03:38 PM
09/22/20 03:38 PM
VCODE
White Plains, NY
I probably do 2-3 5.7 broken exhaust studs a week.... if your lucky it snaps near the top instead of even with the head. I’ve been using a step drill bit to hog out the holes on the sealing side of the manifold on the end ports. I also put a generous bead of copper rtv around the end ports on the gasket. Knock on wood I haven’t had a comeback doing it this way. I just purchased the Mopar gaskets,bolts and nuts. $250.00 with my discount. I am going to have the old manifolds resurfaced if out of spec before putting them back on. I got the Mopar gaskets which are a few layers thick. So you enlarge the inside end holes of the manifold to release some pressure on it. It looks like my right rear broke at the top of manifold but not sure yet. Thank Bob Thanks Guys and J Body. I finally got the manifolds off. Ended up with 5 broken studs. Got one out with welding the nut onto it flush with the head. Leaving the others for another day Bob
[Re: stumpy]
#2823693
09/22/20 04:18 PM
09/22/20 04:18 PM
VCODE
White Plains, NY
Most of the time you can just back them out easily. The aren't stuck in the head normally. I managed to remove mine with my fingers or a pair of pointed vise grips. Not mine, 2004 Ram, they are rusty and tight. Even the ones that came out without breaking I needed to pull as hard as I could on the ratchet. Thanks Bob
[Re: gtx6970]
#2823759
09/22/20 06:32 PM
09/22/20 06:32 PM
Posts: 18,409 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
We had a guy who was REALLY good with a mig welder. he would lay a nut over top of what ever was left of the stud . and 90% of them time he had them out in a few minutes Better yet start with a flat washer. Being thinner it is easier to get penetration to the broken stud. Then weld a nut with a larger hole to the washer. The heat will transfer and help loosen the stud. Aluminum heads usually will allow easier sud removal. We always removed the inner fenders for access.
Re: 2004 Ram 2500 O2 Sensors & Exhaust Manifolds
[Re: NITROUSN]
#2823783
09/22/20 07:21 PM
09/22/20 07:21 PM
VCODE
White Plains, NY
We had a guy who was REALLY good with a mig welder. he would lay a nut over top of what ever was left of the stud . and 90% of them time he had them out in a few minutes Better yet start with a flat washer. Being thinner it is easier to get penetration to the broken stud. Then weld a nut with a larger hole to the washer. The heat will transfer and help loosen the stud. Aluminum heads usually will allow easier stud removal. We always removed the inner fenders for access. Yes that's my next step with the washer first. Thanks Bob
[Re: VCODE]
#2824113
09/23/20 02:05 PM
09/23/20 02:05 PM
VCODE
White Plains, NY
We had a guy who was REALLY good with a mig welder. he would lay a nut over top of what ever was left of the stud . and 90% of them time he had them out in a few minutes Better yet start with a flat washer. Being thinner it is easier to get penetration to the broken stud. Then weld a nut with a larger hole to the washer. The heat will transfer and help loosen the stud. Aluminum heads usually will allow easier stud removal. We always removed the inner fenders for access. Yes that's my next step with the washer first. Thanks Bob Well I finally got all the broken bolts out .Let me tell you, two studs where so tight I needed to use my 1/2 breaker bar. I mig welded the washer on first then I welded a large nut onto that. This worked the best for me. Now off to have them machined flat. Thanks Bob
[Re: VCODE]
#2824181
09/23/20 03:59 PM
09/23/20 03:59 PM
NITROUSN
We had a guy who was REALLY good with a mig welder. he would lay a nut over top of what ever was left of the stud . and 90% of them time he had them out in a few minutes Better yet start with a flat washer. Being thinner it is easier to get penetration to the broken stud. Then weld a nut with a larger hole to the washer. The heat will transfer and help loosen the stud. Aluminum heads usually will allow easier stud removal. We always removed the inner fenders for access. Yes that's my next step with the washer first. Thanks Bob Well I finally got all the broken bolts out .Let me tell you, two studs where so tight I needed to use my 1/2 breaker bar. I mig welded the washer on first then I welded a large nut onto that. This worked the best for me. Now off to have them machined flat. Thanks Bob Glad it worked out. Years ago we went to the washer trick first and it worked almost without fail unless someone had previously buggerd the threads. We used to do the nut first and almost always it was 5 to 10 tries. The washer first about 50 percent or better come out on the first try.
[Re: NITROUSN]
#2824187
09/23/20 04:10 PM
09/23/20 04:10 PM
VCODE
White Plains, NY
Yes the washer first worked out way better than just the bolt welded on. With the washer you can get a better weld on the broken stud. But it takes time I still had a few welds break. No meat and a tight bolt Bob
