Air Compressors #2819228
09/10/20 10:28 AM
09/10/20 10:28 AM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
I need a small like 20 gallon portable compressor for my hunting camp. It seems like most small compressors are oil less in design. I am old school and all my compressors had a crankcase. I am a little leery on the oil less design. Am I being to paranoid?
Re: Air Compressors [Re: NITROUSN] #2819240
09/10/20 10:59 AM
09/10/20 10:59 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Probably, I have a cheapo oil less unit I bought so long ago I can't remember when or where but it's at least 20 years now and it's probably chinese made.
Still works.
Re: Air Compressors [Re: Sniper] #2819247
09/10/20 11:17 AM
09/10/20 11:17 AM
moparx Offline
moparx  Offline
way too noisy for me, and i have hearing loss. biggrin
they also seem to take longer to pump up. but that may be because the noise they make is irritating to me.
beer
Re: Air Compressors [Re: NITROUSN] #2819250
09/10/20 11:20 AM
09/10/20 11:20 AM
Kirkland, Washington
Pacnorthcuda Offline
I wouldn’t buy an oiless. My compressor of 20 years is a 20 gallon oiled unit, a Craftsman. True 2 hp which is the most you can make with 120volt.
Re: Air Compressors [Re: Pacnorthcuda] #2819257
09/10/20 11:33 AM
09/10/20 11:33 AM
moparx Offline
moparx  Offline
i got a junky old craftsman portable at an auction a couple years back for $5.00 that had a broken handle and messed up wheels.
that thing pumps up fast and is very quiet. it's a 2hp/120v setup. i'm not sure what size tank it has though.
beer
Re: Air Compressors [Re: moparx] #2819294
09/10/20 12:43 PM
09/10/20 12:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
beer
If you want a quiet air compressor, I bought a California Air Tools unit, very very quiet and oil less too.
Re: Air Compressors [Re: Sniper] #2819322
09/10/20 01:36 PM
09/10/20 01:36 PM
5thAve Offline
5thAve  Offline
What do you need it for and how much is it going to get used? Unless you're regularely using it, and it doesn't sound like you are since it's for a hunting camp, an oil less one should be perfectly fine.
Re: Air Compressors [Re: 5thAve] #2819385
09/10/20 04:22 PM
09/10/20 04:22 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have two oil less compressors. I was told that oil less were not any good and to stay away from them. One is about 20 years old and I keep waiting for it to die. Both are still sunning strong. They are noisy though.
Re: Air Compressors [Re: mopars4ever] #2819449
09/10/20 07:55 PM
09/10/20 07:55 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks for the replies. I guess I can roll the dice on an oil-less style. My 40 plus year old compressor works fine but the tank is rusted through. I was hoping to find a newer style with a junk compressor and swap my components to it. Being the use is minimal I suppose a oil-less could work. I really do not have to have it but it sure is handy to have around.
Re: Air Compressors [Re: NITROUSN] #2819452
09/10/20 08:04 PM
09/10/20 08:04 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
My main compressors are piston type but I also have a couple of small oil less. One for my airbrush and the other just to fill tires when needed.
Slow and annoyingly noisy.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: Air Compressors [Re: NITROUSN] #2819457
09/10/20 08:08 PM
09/10/20 08:08 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If all you need is a tank, maybe one of those portable air tanks will work, maybe you could add the platform your motor and compressor are on to the air tank. Most of the time, the tanks are the problem with the small air compressors, people apparently don't think they need to drain the water out of those small tanks. Gene
