Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# #2818830
09/09/20 09:00 AM
09/09/20 09:00 AM
ghinmi Offline OP
ghinmi  Offline OP
It just keeps making more power. Current spec is 2010 5.7 and tr6060 out of a Challenger. Drop in pistons/rods, Cometic head gaskets, ARP head studs, VVT locked, 80 lb injectors. Factory cast crank. Race weight 4130 lbs
Turbo combo is a s480 feeding a s366.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# [Re: ghinmi] #2818922
09/09/20 11:55 AM
09/09/20 11:55 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
One of my absolute favorite G3 Hemi conversions that I’ve ever seen. Well done!
SuperBeast
An enforcer for the Mopar Mafia!
Re: Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# [Re: ghinmi] #2819200
09/10/20 08:50 AM
09/10/20 08:50 AM
State College, Pennsylvania
fatman Offline
fatman  Offline
My favorite thing ever.
Re: Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# [Re: fatman] #2819505
09/10/20 10:09 PM
09/10/20 10:09 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
That is a $hit ton of mph for those ET's....Congrats...Those MPH are showing you the real HP potential and its very impressive.
The reaction times need some work though.....
Re: Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# [Re: ghinmi] #2819508
09/10/20 10:11 PM
09/10/20 10:11 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
Ghinmi- How many pounds of boost are you running? That thing is flying.
Re: Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# [Re: 416challenger] #2819530
09/10/20 11:11 PM
09/10/20 11:11 PM
IL
furious70 Offline
furious70  Offline
IL
and what led you to switch to a compound setup?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# [Re: furious70] #2819582
09/11/20 07:37 AM
09/11/20 07:37 AM
ghinmi Offline OP
ghinmi  Offline OP
Yes, huge mph for the et. But ultimately it's not a drag car and I'm still working on the launch strategy. Being a clutch car, changing the launch makes huge changes to the reaction time so I don't try to hit the tree until I have the launch locked down. We do mostly flashlight starts anyway.
Those passes were on 21-22 psi in 4th. A little less in 1st and 2nd.
I wanted more power than the small single could make and I didn't want to give up the responsiveness or low end boost.
Re: Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# [Re: ghinmi] #2819624
09/11/20 10:45 AM
09/11/20 10:45 AM
IL
furious70 Offline
furious70  Offline
IL
Have you done testing to see how broad the boost range is then? i.e. boost comes in at 2000rpm and 'lasts' until 6000rpm based on exhaust backpressure that you deem acceptable? Are you desiring pretty low rpm boost for when you autocross? Still lots of work to do on my car but I settled on a VSRacing 76/75 with a T4 1.25 a/r to try to find one responsive but not choking.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Compound turbo 5.7 Eagle 9.97 @ 140 stick shift 4130# [Re: furious70] #2819692
09/11/20 01:41 PM
09/11/20 01:41 PM
ghinmi Offline OP
ghinmi  Offline OP
By adjusting the bypass gate I can make it do essentially whatever I want. The way I have it set right now it comes into boost 1300-1400 rpm and holds till the rev limiter at 6500. I can have it make 20 psi by 2000 if I want to. Or I can make it lazy like a big single turbo car. I had to do this on a very tight autocross course just to kill the power.
